DOCUMENT UPDATE IN LO 2016  Topic is solved
Found a bug in LayOut? Report it here
Postby pipingguy » Sun Aug 28, 2016 12:08 pm
Document update normally is a 6 click procedure. (file>document setup > references > select file > update > close. Another way is to context click a viewport - but my viewports are often locked, thereby adding steps. I was happy to discover a shortcut as well as a tool to make it a one click procedure. However - they fail to work. :(
pipingguy
Re: DOCUMENT UPDATE IN LO 2016  Topic is solved
Postby brettsichellodesign » Sat Oct 29, 2016 12:45 am
This should speed up the process a little:
brettsichellodesign
Postby pipingguy » Tue Nov 01, 2016 12:43 am
THANKS...THEY FINALLY FIXED IT
pipingguy
Postby Dave R » Tue Nov 01, 2016 1:26 am
What do you mean they finally fixed it? It's worked that way all along.
Global Moderator
Return to LayOut Bug Reporting
