Export DWG  Topic is solved
Found a bug in LayOut? Report it here
Export DWG
Postby ArCAD-UK » Wed Dec 11, 2013 4:33 pm
Just had to export my files into DWG model space for use by others in AutoCAD. It hasn't gone well...
  1. The end user has to change their background to white if the exported text is black otherwise the text is invisible. Text also can't be changed to "bylayer" or any other colour without editing each piece of text.
  2. The text background masking boxes shrink to tiny rectangles
  3. All text is changed to "Top Left" insertion including text which should have been middle & centre resulting in numerous text clashes.
  4. Linetype scales are incorrect and need setting to drawing scale x 10 to look right eg at 1:50 LTSCALE needs set to 500
  5. Dimensions disintegrate into lines and text
  6. Angular dimensions vanish
  7. Clipped vector scenes unclip & explode
  8. Text leader line arrow heads explode
Anyone know if I'm doing something wrong or if there are workarounds before I'm forced by my client to move to exporting my SU models to DWG and abandon LO for Draftsight? :(
ArCAD-UK
Re: Export DWG  Topic is solved
Postby Krisidious » Wed Dec 11, 2013 8:46 pm
Nope... that pretty much describes it... useless.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Re: Export DWG
Postby ArCAD-UK » Wed Dec 11, 2013 10:27 pm
Oh POOP!!! This is taking me back 30 years to AutoBAD 2D land :evil: At least Draftsight is free for now...
ArCAD-UK
Re: Export DWG
Postby Krisidious » Thu Dec 12, 2013 12:35 am
yeah... Like SketchUp not importing text from autocad Layout doesn't seem to like exporting text to autocad. maybe they should send each other a text based email and fix it.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Re: Export DWG
Postby ArCAD-UK » Fri Dec 13, 2013 12:00 pm
And while Trimble are fixing this, would it be too much to ask to be able to export SU to DWG/DXF using SU layers rather than just line, profiles & section cuts?
ArCAD-UK
Re: Export DWG
Postby ArCAD-UK » Fri Mar 14, 2014 11:36 am
So we have SU2014 and no movement on this issue. Even changing the object output to colour ByLayer rather than (0,0,0) would be a huge step forward. HOW DO I GET TRIMBLE TO DO SOMETHING ABOUT THIS SIMPLE FIX!!! :evil: :evil: :evil:
ArCAD-UK
Re: Export DWG
Postby agrazdi » Wed May 14, 2014 2:50 pm
If i export it to a 2007 versión and open it in Autodesk Autosketch 10, everything works fine, then save it again and open it in Autocad, it works !!!
STRANGE or not ???
agrazdi
Re: Export DWG
Postby JasonWD » Tue Sep 29, 2015 2:40 pm
*puts hand up
This is the one massive issue that prevents my SU/LO workflow being usable for my clients.
SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
JasonWD
Premium Member
Premium Member
Re: Export DWG
Postby juju » Mon Dec 07, 2015 12:38 pm
JasonWD wrote:*puts hand up
if it's difficult to communicate with other consultants using the exports form software then, well, it's a problem for the person using SU + LO (and as such, less people will be inclined to use SU + LO).
What workarounds are people using?
juju
Premium Member
Premium Member
Return to LayOut Bug Reporting
