Rotated Dimension  Topic is solved
Got an idea to improve LayOut?
Rotated Dimension
Postby pipingguy » Sat Feb 05, 2022 1:53 pm
I wish we had a rotated dimension tool like AutoCAD. As far as I can tell, the only workaround is to use the protractor in SKP to determine the angle of the dimension line relative to the objects, then switch to LO, set the linear dim as usual, rotate it and finally re-afix the points to the objects.
pipingguy
Re: ROTATED DIMENSION
Postby Box » Sat Feb 05, 2022 6:53 pm
Caps lock on your titles doesn't encourage interest in your posts.
Re: Rotated Dimension  Topic is solved
Postby Dave R » Wed Feb 09, 2022 9:03 pm
It can be done in LayOut.
At least in recent versions of LayOut. What version are you using? Your profile is incomplete.
Global Moderator
Postby samodelkin_77 » Thu Feb 10, 2022 6:43 am
in such cases, I use a line that helps me to set the size (then the line can be deleted)
samodelkin_77
Postby Box » Thu Feb 10, 2022 7:01 am
It's pretty simple in layout.
Postby pipingguy » Sat Feb 12, 2022 3:08 am
I use version 21. Thank you for the solutions. All that's left to do is adjust the left side extension line's end point to provide a gap.
pipingguy
Return to LayOut Feature Requests
