@#$%^&* edit SU model reference in LayOut  Topic is solved
Got an idea to improve LayOut?
Postby pbacot » Sun Apr 24, 2016 7:30 pm
Once again, please PLEASE just eliminate the double-click to edit SketchUp model reference in LayOut. Just bury that command somewhere. What a pain. Thank you.
4
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Re: @#$%^&* edit SU model
Postby Rich O Brien » Sun Apr 24, 2016 8:26 pm
The edit a component/group double click?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby pbacot » Sun Apr 24, 2016 9:00 pm
LayOut
User avatar
Top SketchUcator
Re: @#$%^&* edit SU model reference in LayOut
Postby Rich O Brien » Sun Apr 24, 2016 9:06 pm
I really should pay attention to where topics are posted....
User avatar
Rich O Brien
Administrator
Postby fouronethirty » Sun Jul 24, 2016 1:32 pm
pbacot wrote:Once again, please PLEASE just eliminate the double-click to edit SketchUp model reference in LayOut. Just bury that command somewhere. What a pain. Thank you.
its really painfull sir, . hopefully it goes away in the next ver. it does'nt help at all sir. only it changes is the view. but not a considerable aid in documents prep. i just hope it goes away in lo. its already good in scene selection to achieve the change in view of the model..
may the bright minds realize that sir. thank you very much..
User avatar
fouronethirty
Postby brettsichellodesign » Sat Oct 15, 2016 12:40 am
It is really annoying. I try and get round it by having all sketchup 'viewports' in a locked layer. This means you can't double click into them.
User avatar
brettsichellodesign
Postby utiler » Mon Oct 17, 2016 12:57 am
brettsichellodesign wrote:It is really annoying. I try and get round it by having all sketchup 'viewports' in a locked layer. This means you can't double click into them.
That's exactly what you should do. I import any Su reference on a layer called 'SketchUp Imports' and lock it unless I need to manipulate the viewport. That way working over the top of it is a breeze...
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Re: @#$%^&* edit SU model reference in LayOut  Topic is solved
Postby pbacot » Mon Oct 17, 2016 4:31 pm
Yes, that's what you need to do. It's still dumb.
User avatar
Top SketchUcator
Postby brettsichellodesign » Sat Oct 29, 2016 12:54 am
I have actually been using the click though viewport feature recently, here is why:
So I have a load of internal elevations of a building set up in parallel projection so I can dimension etc... However, I want to also have a 3D view of the elevations. I therefore, just make a copy of the viewport change it to ortho, and line it up as I want.
This means I don't have to go back to SU and make another scene. Saves time and scene space.
Just lock it after. The feature is still useful.
User avatar
brettsichellodesign
Postby pbacot » Sat Oct 29, 2016 3:47 am
No problem having the command, but making it a double click option was not good.
User avatar
Top SketchUcator
Postby JQL » Sat Oct 29, 2016 12:12 pm
brettsichellodesign wrote:I have actually been using the click though viewport feature recently, here is why:
That makes you loose link to sketchup scene. You get a model update, a camera update, but you have to manually update styles...I never do it as I also setup perspective scenes in su. I will try it again though as it has a lot of advantages.
That's what all of us MUST do, but locking a layer locks everything about a viewport. You can't scale it, rotate it, change scenes, not even reload it manually. It's not the solution.
Disabling the double click edit under preferences or specifically locking certain/all viewports edition, would be a fundamental change.
User avatar
JQL
Premium Member
Premium Member
Postby brettsichellodesign » Mon Oct 31, 2016 5:28 pm
Just have it in a right click menu would be a solution I think.
User avatar
brettsichellodesign
Postby JQL » Mon Oct 31, 2016 5:57 pm
brettsichellodesign wrote:Just have it in a right click menu would be a solution I think.
Agree!
User avatar
JQL
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to LayOut Feature Requests
cron
Who is online
Visit our sponsors:
