Line spacing - Interlignage
General discussion related to LayOut
Postby Eskarpe » Thu Oct 06, 2022 4:20 pm
Bonjour à tous,
Est ce qu'il est possible de modifier l'interligne des textes dans Layout ?
Lorsque nous créons des plans, il est parfois nécéssaire d'avoir un interlignage serré pour des légendes par manque de place.
En vous remerciant d'avance,
Alexis
__________________
GOOGLE TRANSLATE
Hi there,
Is it possible to change the line spacing of texts in Layout.
When we create plans, it is sometimes necessary to have tight line spacing for captions due to lack of space.
Thank you beforehand,
Alexis
Eskarpe
Re: Line spacing - Interlignage
Postby Dave R » Thu Oct 06, 2022 5:08 pm
Yes, you can control text line spacing in LayOut. Look in the text options.
Global Moderator
Postby Eskarpe » Thu Oct 06, 2022 5:13 pm
Hello,
I looked but couldn't find it, is it possible to have a screenshot?
Thanks in advance,
Alexis
Eskarpe
Postby Dave R » Thu Oct 06, 2022 5:25 pm
I don't have a Mac anymore to be able to make a screen shot for you. In the meantime check out the Help files on the topic of formatting text in LayOut. https://help.sketchup.com/en/layout/formatting-text Specifically under Setting paragraph formatting.
Global Moderator
Postby Eskarpe » Thu Oct 06, 2022 5:36 pm
I looked in these two panels but I don't see the line spacing option.
Eskarpe
Postby Dave R » Thu Oct 06, 2022 6:08 pm
Eskarpe wrote:I looked in these two panels...
Did you follow the link and read this?
'Line spacing: From the menu bar, select Text > Spacing and choose the Single, One and a Half, Double, or Custom option from the submenu that appears. If you select Custom, a Text Spacing dialog box appears, where you can also set spacing as a fixed point size and set how much spacing appears before and after a paragraph.'
Global Moderator
Postby Eskarpe » Thu Oct 06, 2022 6:19 pm
I just looked but couldn't find the Spacing option... I must be blind! It may not exist on mac. On the other hand I found how to manage the interlettering, thank you ;)
Eskarpe
Return to LayOut Discussions
