edges and Hybrid transparency
• Page 1 of 1
edges and Hybrid transparencyI did not know this. If you choose to ues hybrid, arguably the better looking most useful setting in LO, edges seen through transparent surfaces disappear. That's not good. I guess i never needed it but now I have a model that does need the edges to show and there's no way to do that except by raster which is no good by default.
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: edges and Hybrid transparencyAs a workaround omit the transparent surface in SU but add a transparent shape in LO. Attached example LO. Not great if you have a lot of separate transparent surfaces!
Re: edges and Hybrid transparencyThere was a bug introduced that caused this. The LO team know about it and it's in the pipeline.
In the meantime, a work around is an option. Two scenes in SU. One with textures displayed but edges off. The other, Hidden line--black on white. Stack viewports in LO with the top one set to the Hidden line scene and rendered in Vector. The textured scene below rendered in Raster. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: edges and Hybrid transparencyDave and Brian,
Thanks for the ideas and examples. I'll try them out! Peter MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
• Page 1 of 1
