HYPHEN  Topic is solved
General discussion related to LayOut
HYPHEN
Postby pipingguy » Wed Nov 15, 2017 8:39 pm
I wish the hyphen and chevron characters would line-up in LayOut's text like in Sketchup's 3D text. I use them as flow arrows. --->
pipingguy
Re: HYPHEN  Topic is solved
Postby pbacot » Wed Nov 15, 2017 8:47 pm
Could be the font you are using?
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Re: HYPHEN
Postby pipingguy » Thu Nov 16, 2017 10:36 am
You are correct sir. Tahoma is the better way to go.
pipingguy
Re: HYPHEN
Postby pipingguy » Mon Dec 04, 2017 4:55 pm
Now I remember why I switched to Arial - it's because certain subsequent Tahoma characters, such as RA and TT, touch each other. :o So when I convert the 3D text component into a group, those faces get left behind. I wish Trimble would separate the letters or allow 3D text to form a group vs. component.
pipingguy
Re: HYPHEN
Postby Dave R » Mon Dec 04, 2017 6:55 pm
This has been explained before. The spacing is determined by the font, not by SketchUp.If you must use a font that has narrow spacing, you have several options. Make and place the glyphs one at a time, edit the font with a font editor to add more space between glyphs, or conact the designer of the font and try to get them to make the modification for you.
Maybe you should find a mono-spaced font to use instead.
User avatar
Global Moderator
Re: HYPHEN
Postby Dave R » Tue Dec 05, 2017 1:25 pm
pipingguy wrote:Subject: HYPHEN
Thanks for the workarounds Dave. But in all honesty, I don't want to go down the unfamiliar path of font editing. I just hope that Trimble reads our posts and puts it on their to-do list to weed out the troublesome default fonts...and they should really remove all the arcane ones that nobody uses.
Evidently you have missed a very important fact. The fonts available in the 3D Text tool are system fonts. SketchUp doesn't supply any fonts whatsoever. If you are seeing "arcane" fonts in the list, they either came with Windows, were installed by some other program, not SketchUp or LayOut, or you installed them yourself. You can edit the Windows Fonts and delete them.
It isn't the responsibility or even within the capability of Sketchup to modify the fonts on your computer. Expecting them to do anything about this is unrealistic.
User avatar
Global Moderator
Re: HYPHEN
Postby pipingguy » Tue Dec 05, 2017 1:42 pm
wonderful
pipingguy
Re: HYPHEN
Postby Dave R » Wed Dec 06, 2017 12:05 am
pipingguy wrote:wonderful
Most applications that use fonts use the system fonts. SketchUp and LayOut aren't unique in that. There are a few that add some fonts but for the most part, they all come with the operating system unless you install them yourself.
As I said, if you really must stick with the font you've chosen, you can edit it. A great tool for that is FontCreator which will let you create your own fonts as well as edit existing ones. And it really isn't all that difficult to do.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to LayOut Discussions
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
