dimension at center
General discussion related to LayOut
dimension at center
Postby dieter10 » Thu Apr 27, 2017 8:27 pm
I have a trouble with Layout 2017.
When I want to dimension at the center of a hole, the dimension box always becomes red.
What should I do?
-Reconnect to model doesn't work
-The clipping mask is not the problem
dieter10
Re: dimension at center
Postby Dave R » Thu Apr 27, 2017 9:06 pm
The red box indicates that the dimension is disconnected from the geometry in the SketchUp file. Does selecting Reconnect from the right click context menu fix it?
Is the hole's edge a circle? Are you inferencing off the center of the circle?
If nothing else works, you could just right click on the dimension and choose Explode.
Global Moderator
Postby dieter10 » Thu Apr 27, 2017 9:32 pm
1) No
2) The hole edge is a real circle and not a polyline. I selected the center (blue dot appears), when selecting the edge of the circle its no problem
3) Explode works fine
Is this a bug?
dieter10
Postby Dave R » Thu Apr 27, 2017 10:39 pm
I doubt it.
Global Moderator
Postby GMthompson » Fri May 12, 2017 7:40 pm
smustard "set centerpoint.rb: is one of my most used plugins, may help if not you will find it useful anyways
you can learn something everyday by paying attention
GMthompson
Return to LayOut Discussions
