New project, Advise on layout
General discussion related to LayOut
Postby caronte01 » Thu Dec 22, 2011 11:26 pm
Hey all!
I have a new project, a house. I have produced all the documents for client approval so far, using sketchup and layout. But now, it´s time to document. I have a choice of using archicad, or continue using sketchup/layout to finalize this project. Archicad would be the traditional route, and it is very good as far as documenting goes, but modelling anything not standard is a road full of workarounds and barriers. Sketchup certainly beats layout in ease of modeling and power (imo), but layout, though good, has it´s limitations. I´m esp. concerned with exporting drawings so that all the others involved can use.
I would be ok with creating non typical documentation (using 3d graphics, etc)
If you had a similar project, would you try and tackle it with sketchup/layout? Any good samples (i´ve seen greg lavardera´s work)?
Cheers and thanks!
s
caronte01
Re: New project, Advise on layout
Postby srx » Fri Dec 23, 2011 11:46 am
I like it. :thumb:
For final documenting I use AutoCad with input from Sketchup as reference...for now. I find Layout hard to work with...maybe becouse of long experience with AutoCad. Formthe small scale projects like this maybe U could try. I would be interested in your results :)
www.saurus.rs
srx
Postby bmike » Fri Dec 23, 2011 2:45 pm
Those are nice drawings! I love the soft style you are using.
Some great samples and discussion here:
viewtopic.php?f=12&t=15911
And some of my work:
viewtopic.php?f=81&t=38462
Currently working this project into construction documents:
bmike
Postby caronte01 » Fri Dec 23, 2011 5:26 pm
Hi Saurus, yes, that´s what i´ve been doing for other projects, but usually end up with an out of date model, elevations not matching floor plans etc.... Sketchup is not bim, but i would like to get the advantage of having coordinated plans, sections and elevations without the hassle of going back and forth, and redrawing.
Mike, your drawings are beautiful, and the projects you work on are very cool. I´ll certainly save a copy of those for inspiration. Do you exchange .dwg with consultants? Or do you send them pdf´s? Any tips?
I´ve used layout for details, but not yet for an entire project. I´m leaning more on the side of sketchup. I have a couple of weeks to think about this, and will let you know. I´ll try and keep you updated.
Cheers, and a merry Christmas to all!
caronte01
Postby pbacot » Fri Dec 23, 2011 5:35 pm
What do you mean? Are you leaning towards using SU rather than LO or...?
You're brave to consider using an untried workflow for a paid project. Look forward to seeing what you come up with.
These sheets so far LOOK GREAT! (Only I would not use the fat cut-out guys.)
Peter
Top SketchUcator
Postby sonder » Tue Dec 27, 2011 8:44 pm
I am doing this same thing right now with three home projects. I really like it compared to utilizing sketchup only for design. It certainly eliminates the potential for errors between the formats. I have found that limiting layout files to single pages really increase the speed drastically.
sonder
Premium Member
Premium Member
Postby caronte01 » Tue Jan 17, 2012 12:26 am
Not a lot of progress so far. For now, I´m testing dwg exports from layout. I don´t need them to be perfect, but I do need to have readable files so that external consultants have something to work from. One thing i found is that text export is not perfect as far as formatting goes, so a couple of workarounds have to be used so that dwg output resembles the original pdf/lo file:
- text exported to dwg will always become an mtext, top left justified. The origin of this text is set to the left upper corner of the text box in layout. So, in layout, try and make the text box as small as possible, to avoid having the text in the wrong place.
- Text background colors are not exported. An additional box needs to be used to achieve the same effect.
- Borderless boxes and shapes in layout export as hatches with borders. The workaround is to set the outline the same color as the fill and use the thinnest profile possible.
This so far. Will keep you updated.
caronte01
Postby thomaselsmore » Mon Jan 23, 2012 11:08 am
caronte01 those plans are really impressive! Amazing work! What style are you using?
Kind regards,
Tom
thomaselsmore
Postby caronte01 » Wed Jan 25, 2012 4:24 pm
Hi Tom,
Thanks!
here you go...
PRESENTACION.style
caronte01
Postby caronte01 » Wed Jan 25, 2012 4:28 pm
Hi Sonder. I really like those elevations! How are you achieving the fog effect? Section planes?
Are you using hybrid or raster for sketchup views?
Thanks for sharing
caronte01
Postby sonder » Wed Jan 25, 2012 6:11 pm
caronte01 wrote:Hi Sonder. I really like those elevations! How are you achieving the fog effect? Section planes?
Thanks for sharing
The fog is in sketchup saved settings specific to the scene. I use raster rendering, edit quality low, export quality high.
sonder
Premium Member
Premium Member
Postby thomaselsmore » Thu Jan 26, 2012 11:11 am
caronte01 wrote:Hi Tom,
Thanks!
here you go...
PRESENTACION.style
Thank you very much for the style! Keep posting up your work as it is inspiring!
Kind regards,
Tom
thomaselsmore
Postby Richard » Tue Jan 31, 2012 2:04 am
caronte01 - stunning use of Layout there mate!! VERY well done!
Richard
Postby caronte01 » Tue Jan 31, 2012 6:13 pm
Thanks Richard!
Here's some of the components used for furniture. I like them because they are very simple graphically.
BLOQUES.skp
Cheers
s
caronte01
Postby caronte01 » Wed Mar 21, 2012 10:18 pm
Quick update.
I´ve sent dwg´s to consultants already. They were not the prettiest dwg´s I´ve seen, but they worked.
So far, layout has done it´s job perfectly well. That does not mean i´d like to see some improvements.
Floorplans:
caronte01
Postby caronte01 » Fri Mar 23, 2012 10:44 pm
Elevations and sections:
caronte01
Postby sonder » Fri Mar 23, 2012 10:55 pm
Looking beautiful Pablo! Very nice work.
sonder
Premium Member
Premium Member
Postby pbacot » Sat Mar 24, 2012 3:23 am
Bellissimo! Go SU + LO! Peter
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby Richard » Sun Mar 25, 2012 6:24 am
Mate these plans are stunning! Really GREAT WORK! :berserk:
Mate the only thing that I wonder and would love to see a version of - without so much background! There is a relevant graphic term - "make white space your friend!".
Richard
Postby caronte01 » Wed Mar 28, 2012 8:55 pm
Thanks guys! I´m now starting details, after that i will return to the main model and update/reference all the changes made.
Richard, I removed the sky from sections and elevations. I like them!
caronte01
Postby Richard » Thu Mar 29, 2012 10:32 pm
caronte01 wrote:Richard, I removed the sky from sections and elevations. I like them!
Yeah me too mate - just cleaner! And more ESD - less ink! ;) We have to be mindful of contractors writing notes on the plan, often some printers add such gloss to printed areas that the surface doesn't take a pen well. Looks like you still have a background.
Hey you checked tones in greyscale as this is always 99% of printing throughout the job!
Richard
Postby caronte01 » Fri Mar 30, 2012 4:09 am
Richard wrote:
caronte01 wrote:Hey you checked tones in greyscale as this is always 99% of printing throughout the job!
I did print some elevations in greyscale, to see how they looked. I had to increase contrast a bit. In color, they appeared ok, in bw they looked a bit washed out. Also, elevations looked great with shadows on; sections, I turned them off.
caronte01
Postby sonder » Fri Mar 30, 2012 4:38 pm
For BW increase brightness along with contrast at the printer level. I only print my color sets for the permit sets, 1 for the owner and 1 for the contractor. The rest are all BW and look really good with both fog and shadows on. Thankfully my printer has it down now, so I just send over the files and order at will. They are really good at making adjustments and testing before final printing.
sonder
Premium Member
Premium Member
Postby Richard » Fri Mar 30, 2012 9:52 pm
Sonder wrote: Thankfully my printer has it down now, so I just send over the files and order at will. They are really good at making adjustments and testing before final printing.
Look after that one mate! My printer hands me stuff with huge lines across it smiles and hands me the bill!
Richard
Return to LayOut Discussions
Users browsing this forum: No registered users and 4 guests
