Construction & Working Drawings - Discussion
General discussion related to LayOut
Re: Construction & Working Drawings - Discussion
Postby pbacot » Tue Nov 13, 2012 11:58 pm
njh wrote:Hi folks
The plan shown by Sonder looks fantastic! I've tried to attach the one I'm talking about.
I'm just picking up Sketchup and Layout again after a lengthy absence and I'm hoping to adopt it as my full time design package rather than Vectorworks so I have a query about the electrical layout, fans etc on the drawing- are they part of the sketchup model or drawn "on top" of the view in layout?
Apologies if this is explained in the thread somewhere and I've not noticed it.
Neil
Screen grab.pdf
Curious to know why switch from VectorWorks (VW OR SU might be my options if my CAD expired--development ended).
The electrical layout by Sonder is done in LO. http://sketchucation.com/forums/viewtopic.php?f=12&t=15911&start=255#p392706
Top SketchUcator
Postby njh » Wed Nov 14, 2012 4:50 pm
Thanks for the link to the part if the post which explained about the lighting layout!
Quick answer is I hope it will be possible to increase speed and accuracy. At the moment I draw everything in 2D in Vectorworks (I'm running architect 2013) so I draw the plans, sections, elevations etc individually. This takes time and leaves me open to errors when updating a plan and not the corresponding section / elevation (or vice-versa). Vectorworks is great but I feel like I could work a bit smarter.
I know that I can model in full 3D in Vectorworks but the learning curve seems pretty steep and I understand from a couple of people who use Vectorworks and Sketchup that they find Sketchup and Layout the fastest way to draw. I'm pretty competent with Sketchup - if perhaps a bit rusty - and I'm beginning to feel my way around Layout.
I'm a sole practitioner and work mainly on domestic alterations and extensions (few new-builds here and there too) but I'm beginning to get involved in larger schemes (complete internal and external re-fit of a largely square 2000m2 office block) so I'm thinking Sketchup and Layout COULD offer me some speed and accuracy improvements for the type of work I do.
I VERY rarely need to share drawings with consultants etc so it seems worth a try?
Neil
njh
Postby dale » Wed Nov 14, 2012 5:21 pm
njh
I have been using Vectorworks since its very first MiniCad version, but stopped upgrading a VW 12.5 because it is so much easier to draw in SketchUp.
Unlike you though, I was doing full 3D in VW, and although I don't remember the learning curve, it was probably because I started so early with the software (or I'm old and my mind is failing)
Like you though, I am ready to make the jump to Layout, since I already do all my preliminary work in SketchUp, it seems a logical step. I currently still export dxf's back to Vectorworks for the final working drawings compiling.
There are a lot of things that I see as failings with Layout, but I was at baseCamp, and I can assure you that The folks at SketchUp are really listening when it comes to Layout.
It seems at the moment though you have to learn the workarounds, (many discussed in this thread), and accept the shortcomings, to get the job done.
There were a lot of folks at the Layout session, who seemed to want Layout to be nothing more than another Cad program. I think this would be a mistake, as Layout offers so much more in terms of presentation potential.
In my discussions, and my question at the session, was essentially asking if it would be possible for the Layout API to be offered to developers, much like the SketchUp API which has spawned so much Ruby brilliance.
In my opinion, this would allow the SketchUp Layout folks to concentrate on the larger picture, while I am sure that we would see ruby developers taking care of the requests for line weights, and arrow types and other details.
I really can't say if this is being seriously considered or not, but I am hopeful.
dale
Top SketchUcator
Postby njh » Wed Nov 14, 2012 6:44 pm
Hi Dale
Thanks for the comments and hopeful speculation about the future of the product. I'm hoping too that Trimble will pick up the ball and run with it to make it an even more useful combined drawing and presentation package.
Like you, I started off with MiniCAD but went to AutoCAD (job change forced it) before returning to Vectorworks at 2010 but in 2D only. Beginning to learn 3D in VW2013 seems a bridge too far...
Neil
njh
Postby ArCAD-UK » Wed Nov 14, 2012 7:43 pm
Hi Neil I've got an Archicad licence. Great piece of software if you do repeat style projects and don't want to do anything that isn't in the box. I'm migrating to SU as I think it is much more focussed as a design tool. Ok it needs development of the many well discussed shortfalls but fingers crossed we should see some great progress soon.
ArCAD-UK
Postby rtbuild47 » Tue Dec 04, 2012 6:07 pm
I use LO all the time for Building Regulation and construction drawings and my only
gripe is that to define materials have to use colors or shades, when hatching would be so much more professional.
artybuild
rtbuild47
Postby arcsurvey » Mon Jan 07, 2013 1:16 pm
This is my first attempt at a construction drawing for a simple UK lean to extension. I am quite pleased with it but it took a long time to achieve though with practice maybe I can get the time cut down. I find that I get bogged down with the outliner and it takes time to manage my groups. I need to make more use of layers maybe.
I tried to create a hatch pattern rather than using colours to identify the brick and blockwork but it crashed each time I applied it. Not sure why that was.
I cannot decide whether to just model the exteriors in SKP to give the 3D and go back to CAD for the 2D plans or whether to stick with it and try to increase productivity.
arcsurvey
Postby porch_unplugged » Mon Jan 07, 2013 5:57 pm
arcsurvey wrote:This is my first attempt at a construction drawing for a simple UK lean to extension. I am quite pleased with it but it took a long time to achieve though with practice maybe I can get the time cut down. I find that I get bogged down with the outliner and it takes time to manage my groups. I need to make more use of layers maybe.
I'm finding that you do cut the time taken down a lot as you progress. You'll find quicker ways of doing things.
I'd try and stick with the sketchup for the plans as well. I find that clients really respond to the textures etc. of a sketchup drawing, rather than the cold crap look of CAD.
porch_unplugged
Postby Mike Lucey » Mon Jan 07, 2013 8:48 pm
Richard, you might check out Rich's YourTube tut, here, http://www.youtube.com/watch?v=3rZ9-o0vTAs&hd=1
Mike Lucey
Mayor
Postby arcsurvey » Wed Jan 09, 2013 11:41 am
Thank you both for your reply and the hatch plugin looks useful.
I have been creating a section cut slice from the competed model and then adding the detail such as cavity walls, tiles, etc. Is this generally considered the best way to do it?
I have found that creating 2D symbols from CAD blocks works well for doing the floor plan in 2D from the 3D section cut without adding a lot of weight to the model.
I have started my next project and it is going quicker already - I guess it will keep improving.
arcsurvey
Postby Mike Lucey » Wed Jan 09, 2013 1:46 pm
Keep us posted on progress.
Mike Lucey
Mayor
Postby sonder » Wed Jan 09, 2013 8:35 pm
rtbuild47 wrote:I use LO all the time for Building Regulation and construction drawings and my only
artybuild
Hmm, I think the opposite. Hatching was developed to identify and define perameters of materials or scope, while SU and layout do this in a method to me that is more clear and direct. I would rather see CMU that looks like CMU rather than a cross hatch pattern that is referenced in a schedule telling you it is CMU.
sonder
Premium Member
Premium Member
Postby bmike » Wed Jan 09, 2013 10:04 pm
artybuild
I also suspect that hatching was a product of the times - plotters and printers that handled lines, and PCs that did the same.
bmike
Postby sonder » Thu Jan 10, 2013 12:59 am
artybuild
Actually those plotters and printers were the hand and pencil days. Ouch I'm getting old. I graduated architectural school in 1987, so hand drawing was still the main course, with ACAD just really starting to move in the industry.
sonder
Premium Member
Premium Member
Postby bmike » Thu Jan 10, 2013 3:37 am
Sonder wrote:
artybuild
for sure. i was on the transition period when i dropped out. school was leaning towards a paperless studio for the 3rd year grads, but the first 2 years did a mix of traditional modeling, drawing, 3d, and bullshitting, i mean, critiquing. my prof in school was aghast that i wanted to learn autocad. guess he didn't have to work to put himself through school...
prior to grad school i came from an art school with a renaissance style traditional foundation program - so lots of life drawing - both human figure (i was marginal at it) and from observation - still life, landscape, architecture, etc.
lots of emphasis in design and painting coursework on sketching. i still have alot of my sketchbooks. flip through them every now and again...
bmike
Postby sonder » Thu Jan 10, 2013 4:17 am
Mike, where did you go to school. Sounds a lot like my school - RISD.
sonder
Premium Member
Premium Member
Postby bmike » Thu Jan 10, 2013 4:37 am
Sonder wrote:Mike, where did you go to school. Sounds a lot like my school - RISD.
Cleveland Institute of Art, BFA Sculpture, but I spent time in ID, Graphics, and lots of time working for carpenters and woodworkers.
Then to Columbia for Grad school in Architecture. Burned out after a year. Too much $$$$ for living in the city and going to school, and lots of folks who didn't seem to care about the art of actually building...
Had a good friend go to RISD for furniture. This would have been in mid 90s. Spent some time there hanging out, fun town. Will be there in 2 weeks visiting and engineer I work with and doing some warranty research on a project I designed a few years ago.
Also know a prof down at RISD via some artists I worked for as an assistant in NYC and a by way of a project that I worked on in Jamestown.
Small world.
bmike
Postby pbacot » Thu Jan 10, 2013 5:06 am
artybuild
Yeah, but in office work there is such a thing as standardization and efficiency. Hatches developed over time to have the consistent look and are easily identified (basic ones like wood, conc., earth anyway). And, of course it's something when done by hand you need the interns to learn, so it has to be easily defined and copied. It doesn't take an artist.
Nowadays we don't really want the "make-work"-let the computer do it. So eventually someone who has developed some nice detail textures will lead the way forward and set the standard. :x
Top SketchUcator
Postby sonder » Thu Jan 10, 2013 7:04 am
artybuild
Man I hope not. I think the beauty of SU textures is they look like real materials. They are not a hatch pattern, and are immediately recognized by all the contractors and laborers. Hatches are a cryptic way to depict materials, that are hopefully going to be gone by the way side. I get a lot of positive feedback on my details, especially from the Spanish speaking work force. In many cases, even the text isn't necessary.....a picture is worth a thousand words. Not sur you can say the same for a hatch pattern.
sonder
Premium Member
Premium Member
Postby bmike » Thu Jan 10, 2013 4:31 pm
+!!!! on this. Absolutely. At some point our machines will be fast enough and the reproduction quality of prints good and cheap enough to build virtually in the computer with 'real' materials. We are almost there...
I get similar comments when I send off sketches or details, even by using 'simplified' textures and image placement. Makes a whole lot of sense for a foundation contractor to see grey / stone colored materials with steel popping out than some sort of hatch pattern. And I'm not going using as realistic as an approach as Sonder...
bmike
Postby pbacot » Fri Jan 11, 2013 12:00 am
What do you hope not, Nick? Or you hope it is never standardized?
You mean each of us must create his or her own textures and these will always be recognizable by all, even neophytes?
I was hoping your pattern library would be available ($) ;) . (Though I am far from doing such details myself, this might get me there sooner).
Top SketchUcator
Postby sonder » Fri Jan 11, 2013 12:37 am
pbacot wrote:What do you hope not, Nick? Or you hope it is never standardized?
My thought is that a material image (photographic) is more telling than a hatch pattern used to define a given material. I don't think there is a need to standardize images used in defining materials. Concrete can look like concrete in many different images. What I love about SU is the customization allowed by the individual user. We are not bound by standards like this anymore.
Using concrete as an example, just search Google images and you will see hundreds of images of concrete. Most all would clearly be seen as concrete given the context of application to a given foundation model/section/detail. There is no need for a standard pattern any more. I would hate to go back to that, so I really hope that is not something Trimble deems necessary for either SU or LO. I would much rather the focus be placed on getting us even further beyond what has been the industry standard.
sonder
Premium Member
Premium Member
Postby sonder » Fri Jan 11, 2013 12:49 am
Small world.
I know, crazy. I see you are in Vermont. I went to Kimball Union Academy near White River Junction.
sonder
Premium Member
Premium Member
Postby ccaponigro » Sat Jan 12, 2013 12:00 am
To hell with the neophytes! (Ok just kidding, well sort of) I think simple hatch patterns will always have a place in architectural drawing. I like to just remove all the color from materials (will someone write me a plug in to change them back and forth from color to monochrome) What I want is copies of everybodies scrapbooks. How come there is no scrapbook warehouse ? (yes I'm lazy)
cfcaia.com
ccaponigro
Premium Member
Premium Member
Postby zx10r_Gaz » Sun Jan 20, 2013 7:01 pm
A long while since my last post. Here is the last job I did using only Sketchup & Layout from start to finish. I have only done a few jobs solely in SU LO, as most of my work consists of AutoCAD in one form or another. But I'm trying to avoid it as much as possible now.
One big help was making groups from slices. I saw this in one of Nick Sonders videos. I don't know how I missed that one in the past??? Also a good tip from Nick was try and do as little in LO as possible, basic text & line work etc. I think maybe this is where I was getting frustrated a bit!!! Trying to do to much in LO...?
A big thanks to Nick as his videos really are a help.
The job below is just a basic single storey extension (UK) There is more info on there "graphically" than I would normally supply in a set of AutoCAD plans, hence the time involved is also greater than I would normally take. I need to stop messing about and be more productive :D
Gaz...
zx10r_Gaz
Postby sonder » Sun Jan 20, 2013 7:34 pm
Very nice work!
sonder
Premium Member
Premium Member
Postby pier70 » Tue Jan 22, 2013 5:03 pm
many compliments very well done work
pier70
Postby pbacot » Tue Jan 22, 2013 6:12 pm
YES. This looks very advanced, even if you feel you spending too much time. (You're shaming the competition.)
Top SketchUcator
Postby Aureus » Fri Mar 01, 2013 5:00 am
How the height dimensions are done in Layout?
Aureus
Postby Krisidious » Fri Mar 01, 2013 5:43 am
Gaz...
I can't believe how much scaled information you can get on a sheet. very efficient. and yet still very attractive.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
PreviousNext
Return to LayOut Discussions
Users browsing this forum: No registered users and 6 guests
