Viewport has no reaction to mouse clicks  Topic is solved
General discussion related to LayOut
Postby pipingguy » Fri Nov 11, 2022 1:38 am
My viewport has no reaction to mouse clicks, despite the fact that other layout files linked to the same skp model work fine. Viewport layer is not locked. This particular LO file has been annotated in the past successfully and a PDF was generated. But it will not work now, even on a different PC. I can click the cursor all day on the VP with no reaction. Auto render box in properties is ticked. If I add a new VP to the page, linked to the same model, it works fine (the new VP). It must be something simple that I am overlooking, as usual.
pipingguy
Re: Viewport has no reaction to mouse clicks
Postby Dave R » Fri Nov 11, 2022 2:22 am
Most likely the viewport is undersomething else. If you were to share hte LO file we could tell you exactly what's wrong and how to fix it.
User avatar
Global Moderator
Re: Viewport has no reaction to mouse clicks  Topic is solved
Postby pipingguy » Mon Nov 14, 2022 5:58 pm
I cannot publish this company file. However, i restarted the PC and updated the reference and now the VP is NORMAL.
-2
pipingguy
Postby Box » Mon Nov 14, 2022 6:03 pm
Yet more time wasted on, have you turned it off and on again.
User avatar
Postby pipingguy » Tue Nov 15, 2022 4:11 pm
I turned LO off and on again and the VP remains functional. Is that what you meant, Box?
pipingguy
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to LayOut Discussions
Who is online
