LAYOUT 2021
General discussion related to LayOut
LAYOUT 2021
Postby ulyssesrivera » Wed Feb 17, 2021 10:34 pm
Does enyone knows how to change text colour on dimention lines?
User avatar
ulyssesrivera
Re: LAYOUT 2021
Postby Dave R » Wed Feb 17, 2021 11:13 pm
Sure. Select the dimension(s), go to the Text Style inspector panel, click on the Text Color button (normally black), it'll open the Colors inspector panel. Set the color of the text as desired.
User avatar
Global Moderator
Re: LAYOUT 2021
Postby ulyssesrivera » Wed Feb 17, 2021 11:21 pm
Thanks Dave, I usually insert an additional "text" inside the dimension line context, and then change the colour, I mean the dimension remains black and the additional text on a differet colour.
This can be done perfectly on previous versions, but I cannot find the way on this 2021 version.
Thanks again for your help!
User avatar
ulyssesrivera
Re: LAYOUT 2021
Postby Dave R » Wed Feb 17, 2021 11:28 pm
That's a different question that your original post didn't even allude to.
In LO 2021 the text box for a dimension can only be one color. You would need to add a separate text box to be able to have the different color.
Alternatively you could explode the dimension so the text box is just that.
In LO 2020 and LO2019 you can't change the color of part of the text in a dimension text box either without exploding the dimension.
User avatar
Global Moderator
Re: LAYOUT 2021
Postby ulyssesrivera » Fri Feb 26, 2021 12:41 am
Yes, that was a second question.
Did you try LO 2018?
Well, non of your suggestions works for me, but thanks any way.
User avatar
ulyssesrivera
Re: LAYOUT 2021
Postby Dave R » Fri Feb 26, 2021 12:47 am
Not much point in trying it on LO2018.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to LayOut Discussions
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
