Dotted lines in pdf export despite being solid in sketchup
Found a bug in SketchUp? Report it here
Postby john2 » Sat Apr 18, 2020 6:50 pm
SketchUp has this bug wherein if I select solid line from the dropdown menu in layers or tags, then the pdf export shows those lines as dotted. I exported this pdf from a new file where I drew a box from scratch.
testing 1.pdf
john2
Re: Dotted lines in pdf export despite being solid in sketch
Postby pbacot » Sat Apr 18, 2020 7:09 pm
Same here. But I only see the effect when--under the export options--I turn up the line scale above .5.
And this is v. 2019 on a Mac.Maybe that first pick never was solid. It just looks solid in SketchUP and you have to choose "default" (silly).
Top SketchUcator
Postby john2 » Sun Apr 19, 2020 7:35 am
pbacot wrote:Same here. But I only see the effect when--under the export options--I turn up the line scale above .5.
That's a great hack to solve this trouble! :ecstatic: :thumb: :thumb:
This has been tested on Sketchup 2019 and Sketchup 2020, Windows 10, 64 bit.
The default settings for pdf have been used to produce this error.
This qualifies as a bug. Right?
john2
Postby Dave R » Thu Jul 09, 2020 1:58 pm
Which version of 2020? I just did the same thing you showed and with the default export settings. Attached is the PDF I got using SU20.1.235.
Untitled.pdf
What graphics card are you using?
BTW, your profile says you're still using SU2017. Perhaps you could update it.
Global Moderator
Return to SketchUp Bug Reporting
