Divide
Found a bug in SketchUp? Report it here
Divide
Postby Epix3D » Tue May 07, 2019 1:01 pm
In 2018 when you rightclick to divide a line a yellow box appear telling the measure of each segment..
This does not work in 2019..?
I need this function to work
Epix3D
Premium Member
Premium Member
Re: Divide
Postby TIG » Tue May 07, 2019 4:58 pm
This works fine for me in v2019, just as it did in earlier versions.
Do you have any other issues ?
Could be related to your Graphics Card drivers needing an update, or perhaps v2019 was not installed properly ?
To do a correct installation [or 'Repair' an existing one], do the following...
Log into Windows as you usual user-account - as normal.
Ensure that SketchUp is closed.
Find the v2019 installer exe file - it's usually in your Downloads folder.
Select its icon, right-click > context-menu > "Run as administrator"
When prompted choose "Repair" [for a new/re-installation choose "Install"].
When it completes restart SketchUp and see if that helped.
Installing any complex app in any other way will cause unpredictable issues - these often relate to file/folder permissions, extensions and sometimes on-screen graphics.
Never 'Run' and installer exe file by double-clicking it.
Having administrator-powers attached to your normal user-account is not a problem, but it is also no substitute for running the installer in the proper manner, as set uput above...
Global Moderator
Re: Divide
Postby Epix3D » Tue May 07, 2019 6:24 pm
Thank you TIG. Just remembered I am part of the Betatester program and it might be related to using a beta.
Epix3D
Premium Member
Premium Member
Re: Divide
Postby TIG » Tue May 07, 2019 7:16 pm
You can still install a 'beta' version in the correct way...
Or get the latest most current version and install that as I said.
Whenever I might have installed a 'beta' version I've done it as I explained and I've never had such problems...
Global Moderator
Return to SketchUp Bug Reporting
