CFileException 0....
Found a bug in SketchUp? Report it here
Postby Seatales45 » Mon Dec 31, 2018 4:07 pm
Hello everyone,
Not sure why yet, but when trying to save a sketchup model, an error message comes up like the attachment.
This error is making a second model file with “-0” added to the end of the file name. So now you have two models, one named ABC and one named ABC-0 to choose from. When this happens while working with a LayOut file, the LayOut file gets disconnected from the original model and now I have to look at the time stamps in the file tree to make sure I am reconnecting the latest model to LayOut.
It's starting to severly affect the workflow. Any suggestions for workarounds, fixes, etc.?
Thanks in advance,
Velina (SeaTales45)
Seatales45
Re: CFileException 0....
Postby Dave R » Mon Dec 31, 2018 4:58 pm
The hyphen in the path could be the problem. Replace it with underscore. Any difference?
-1
Global Moderator
Postby Seatales45 » Wed Jan 09, 2019 5:29 pm
Dave R wrote:The hyphen in the path could be the problem. Replace it with underscore. Any difference?
Hi Dave,
Interesting thought, so I tried it, but there was no difference. Finally, our IT consultants had to list SketchUp and LayOut as some sort of exception in our webroot antivirus. We have been problem free since last Friday. (1-4-19)
Thank you though,
Velina
Seatales45
Postby Dave R » Wed Jan 09, 2019 5:39 pm
Thanks for reporting back Velina. That's something to keep in mind for future.
Global Moderator
Postby slbaumgartner » Wed Jan 23, 2019 2:54 pm
CFileException 0 is SketchUp's way of saying "something just went wrong with a file operation but I have no clue what it was". In many cases, and this likely includes yours, it seems to be caused by other agents such as remote file synchronizers or antivirus scanners that lock a file at the same time as SketchUp is trying to save to it.
slbaumgartner
PluginStore Author
PluginStore Author
Postby L i am » Thu Jan 24, 2019 12:27 am
If I am using sketchup a lot I get that windw an average of twice a day. I just ignore it with no consequences.
Premium Member
Premium Member
Postby jefu052018 » Fri Jun 14, 2019 1:54 am
to fix this problem just uninstal or disable antivirus ...like my case , i just disable byfence antivirus and its works ...i can save the file
jefu052018
Postby Didier Bur » Sun Jun 16, 2019 11:20 am
Hi all,
I was having the same message each time I worked on a model saved on the DESKTOP, and SketchUp trying to write a SKB there.
Check if your SketchUp executable has the right to write on your Desktop.
Just in case, also see this: viewtopic.php?f=11&t=68205
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby TIG » Sun Jun 16, 2019 6:16 pm
As Didier says, if you have not installed SketchUp correctly all kinds of unexpected file & folder permission issues can appear...
To repeat what has been stated in many places before...
To fix your installation...
Login to Windows as your normal user-account [NOT the specialized administrator account - BUT if your normal user has some admin-powers that is OK]
Ensure SketchUp is closed.
Find the SketchUp installer's exe file - usually in your Downloads folder.
Select its icon, right-click > context-menu > "Run as administrator"
When prompted choose "Repair".
When it completes retry SketchUp and see if these kinds of issues are improved...
Global Moderator
Return to SketchUp Bug Reporting
