Hi, I want to report a bug in value control box.
Normally when creating a rectangle or square, I would type in the values separated by a COMMA (,) in value control box to specify my measurement. Example: For a 100x300 rectangle shape, you will type in 100,300.
However, this comma doesn't work in my other workstation, and took me a year to figure out! (I accidentally observed the value control box while doing a rectangle and the preview values display semi colon instead of the normal comma). So I figured out that the Sketchup in this particular PC only accepts SEMI COLON (;) as separator, no wonder the comma won't work. Example: For a 100x300 rectangle shape, you will type in 100;300. Weird isn't it? I'm using same Sketchup 2018 pro.
I suggest, play around with the rectangle tool, and the first time you hit mouse button (starting point of rectangle)- values will be displayed automatically corresponding to your mouse movements, and notice the values separator, it may be comma, semi colon or something else. I hope this helps.
I tested in my 3 PC, only one have this issue.
All PC's have same region and keyboard/language input (US layout). Only difference is OS.
PC 1- Win 7 Pro - Sketchup 2018 Pro - comma worked
PC 2- Win 8 - Sketchup 2018 Pro - Semi colon worked
PC 3- Win 10 - Sketchup 2018 Pro - comma worked
For now, I will regard this as a Sketchup bug.
Hope Trimble can help fix, Thanks!
Also mentioned in this thread:
viewtopic.php?f=15&t=52893&p=638699#p638699
Value Control Box Measurement Typing in measurements
• Page 1 of 1
Value Control Box Measurement Typing in measurements[/hr]Dell Precision T5600. SKU 2018 Pro. AutoCAD 2013. Landscape design firm. Hong Kong Re: Value Control Box Measurement Typing in measurements
This is not really a 'bug'...
PC users split into two camps, those in the US/UK/AU/NZ/SA/etc who use a Stop . for the decimal separator and those from the EU/Asia/SouthAmerica/etc who use a Comma , as the decimal separator. Entering combo-numerical values needs a list-separator: so . decimal users will need a , and the , decimal users will need a ; [Semi-Colon] A user's PC will have 'Regional' settings, specifying what decimal point type to use etc. However, it's possible to override the system settings and in an otherwise . decimal setup to reset it to a , ! If you or someone with access to your PC has changed this, then confusion reigns as you now need to type , for a decimal point and a ; as a separator ! On a PC you have a Control Panel - it's name varies with OS version, called something like "Region and Language"... Here there will be settings for all manner of things like date/time/number-formats, and e.g. what decimal-point type to use ./, Here's a screenshot from my Win10 PC... TIG
Re: Value Control Box Measurement Typing in measurementsTIG, you're eagle eye to spot that, awesome thanks!
• Page 1 of 1
