SketchUp 2018 shortcut key is invalid?
Found a bug in SketchUp? Report it here
Postby W56DU » Mon Jan 15, 2018 4:01 am
With SketchUp 2018, sometimes all shortcuts are invalid. Only restarting SketchUp can work properly. What is the reason?
W56DU
Re: SketchUp 2018 shortcut key is invalid?
Postby Dave R » Mon Jan 15, 2018 11:54 am
Very likely this is due to incorrect installation. On Windows, correct installation of SketchUp involves right clicking on the installer EXE and selecting Run as administrator. Did you do that? If not or you aren't sure, do it now.
If you don't use Run as administrator from the context menu during installation, you can get all sorts of strange results. Note: simply being logged in as administrator is not the same thing.
Global Moderator
Return to SketchUp Bug Reporting
Users browsing this forum: burkules and 2 guests
