selection of objects not correct
Found a bug in SketchUp? Report it here
Postby luckyvac » Fri Nov 10, 2017 7:00 am
Hello, I changed my computer to solve the problem ...
Qosmio (After a crash on W10, W7 re-installed) > acer 7530G.
thank you
luckyvac
Premium Member
Premium Member
Re: selection of objects not correct
Postby Dave R » Fri Nov 10, 2017 2:52 pm
Disable MSPhysics and test it? DO you get the same result?
Global Moderator
Postby luckyvac » Sat Nov 11, 2017 6:25 pm
yes, the same ...but i have make the simulation with 1.0.2 and i have reinstal 1.0.3 .... I think, I check!
luckyvac
Premium Member
Premium Member
Postby Dave R » Sat Nov 11, 2017 6:36 pm
Did you install SketchUp correctly by right clicking on the installer and selecting Run as administrator? Or did you just double click on the installer?
Global Moderator
Postby luckyvac » Sat Nov 11, 2017 7:12 pm
indeed, I did not do it as an administrator. I must start again...
I do this... but it the same thing ! :?
luckyvac
Premium Member
Premium Member
Postby TIG » Sat Nov 11, 2017 7:24 pm
No need to
start again
Close SketchUp.
Find the installer exe file [probably in your Downloads folder?]
Re-download it if necessary...
Select its icon.
Right-click > Context-menu...
"Run as administrator"
When prompted choose "Repair".
When the installation is done try SketchUp again...
Any better?
Installing apps in any other way - even if you have admin powers - can lead to all kinds of unpredictable and weird issues...
Global Moderator
Return to SketchUp Bug Reporting
