2015 Can't anchor crossing Tape Measures
Found a bug in SketchUp? Report it here
Postby sunhome » Sun Jul 12, 2015 7:26 pm
On a flat surface I use Tape Measure tool to create a horizontal and vertical measure line.
I'm unable to get an anchor point when I move the Tape Measure tool where these measure lines cross each other. Sketchup 8 works fine this way, but Sketchup 2015 doesn't at all.
sunhome
Re: 2015 Can't anchor crossing Tape Measures
Postby Dave R » Sun Jul 12, 2015 7:41 pm
I just tried it and it works fine for me. Could you post an SKP file that has this problem?
Global Moderator
Postby cotty » Sun Jul 12, 2015 8:54 pm
You can control if they really cross if you draw a line along each of them and see if they are intersected.
cotty
Top SketchUcator
Postby sunhome » Mon Jul 13, 2015 1:28 am
cotty wrote:You can control if they really cross if you draw a line along each of them and see if they are intersected.
I tried it again with nothing else than single flat face and now it worked.
I take it that part of my model had screwed up one of the axis... has happened before.
Thanks for the tip.
Regards,
Tor Solheim
Norway
sunhome
Postby pipingguy » Mon Dec 28, 2015 1:16 am
I noticed an infinite length tape measure line [guide] and a finite length tape measure line with a point at the end [guide point] both stretched across a flat plane and crossing each other do not provide an intersection inference. A slight annoyance but not the end of the world.
pipingguy
Postby Dave R » Mon Dec 28, 2015 1:19 am
The finite length "tape measure" line is not a guideline as the infinitely long ones are. It is only a tail to show the reference origin for a guide point. The guide point is the only part that can be snapped to. That's normal behavior and not a bug.
Global Moderator
Postby pipingguy » Sat Nov 18, 2017 1:38 pm
to answer my own question in a topic now locked......tap the ctrl key when you stretch the tape measure across a group or component to avoid having to erase the guideline that remains after you resize.
pipingguy
Return to SketchUp Bug Reporting
Users browsing this forum: Google Bot and 3 guests
