make_component_bug
Found a bug in SketchUp? Report it here
make_component_bug
Postby rhankc » Fri Jan 18, 2008 3:51 am
I think there is a fault in the Make Component command. 9 out of 10 times when I make a 4 line rectangle and make that box a component, in the proximity of other geometry (touching even just one edge) i have to erase a line to be able to edit the new component, Then i have to retrace an edge to skin the rectangle again. otherwise I just left click and right click on the edge and the MAKE component menu keeps coming up. This shows up in other areas also. When you have a wall face, and draw a window or door on the face of the wall, no matter how you select the lines to make the component, there are lines under/over the made component that must be dealt with first.
It behaves as if you did an Intersect With command and it intersects screen space and makes entities,
Hank
rhankc
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Bug Reporting
Who is online
Visit our sponsors:
