Follow Me Funkyness
Found a bug in SketchUp? Report it here
Follow Me Funkyness
Postby fbartels » Mon Dec 10, 2007 2:51 am
I'm not sure this is a bug or just something I don't understand. I often use the Follow Me tool to extrude a face along a complex curved line. Sometimes this works like a charm and sometimes the dreaded "This does not appear to be a valid path" dialog appears. I haven't been able to identify a pattern. Can anyone explain why this happens and how to avoid it? Thanks, Fred
fbartels
Re: Follow Me Funkyness
Postby Gaieus » Mon Dec 10, 2007 10:16 am
Well, it is hard to tell for every case is a different one. Sometimes it gives this notification but stilll does the extrusion correctly.
There are certainly some oddnesses in its behaviour and improving this very important tool would add greatly to sketchup.
Postby brad » Wed Dec 12, 2007 12:00 am
Hey Fred,
The next time you come across this, will you please post the model so I could take a look at it?
Thank you.
Brad
SketchUp QA
brad
SketchUp Team
SketchUp Team
Postby alan wood » Wed Dec 12, 2007 9:12 am
Hi Fred,
I have found working on small measurements that the follow me and intersect with model tool do not work effectively.
My solution is to build the model, group it, then scale up x10 or 100 and it works a treat.
I then scale down again when the operation has been completed.
cheers
Alan.
http://www.hand-cut-dovetails.com
alan wood
Postby fbartels » Fri Dec 14, 2007 12:40 pm
Brad,
I placed three files in a zip file at the bottom of this page. The zip file is called follow_me_problem_files. These were the files I used to create the three long horizontal curved shapes in the image below. Each one gave me problems. The first worked from one end but not the other. The 2nd and 3rd had to be done in stages. I'd love to know how to avoid this.
Alan, I'm usually working at fairly large scales but I'll give your method a try. Should have done it yesterday but I forgot. Definitely will next time. Thanks for the suggestion!
Fred
fbartels
Return to SketchUp Bug Reporting
Users browsing this forum: No registered users and 7 guests
