Sketchup crashes when starting
Found a bug in SketchUp? Report it here
Re: Sketchup crashes when starting
Postby GhostFist » Fri Jun 07, 2013 4:51 pm
yup, really scratching my head on this.
GhostFist
Postby GhostFist » Tue Jun 11, 2013 3:29 pm
Problem resolved when rolling back the graphics driver
GhostFist
Postby TIG » Tue Jun 11, 2013 4:33 pm
GhostFist wrote:Problem resolved when rolling back the graphics driver
Out of interest, what is/was your GC / drivers set ?
It might help others to be forewarned...
Global Moderator
Postby GhostFist » Wed Jun 12, 2013 2:29 pm
Sketchup was running into problems using the Microsoft surface PRO after updating the graphics drivers from INTEL's site. Microsoft has written a custom driver for the surface pro's chipset and so a conflict was created. Removing Intel's generic driver and rolling back to Microsoft's resolved all issues.
GhostFist
Postby MILENIUMFALCON » Wed May 03, 2017 10:28 pm
hey tig i found the culprit rb folder crashing my sketchup and it was your axo+iso plugin. Any ideas how to make the plugin work? reply ASAP..
Thanks in advance.
MILENIUMFALCON
Postby TIG » Thu May 11, 2017 3:57 pm
I can't see how the axo-iso RB could do this...
It's very simple...
Does SketchUp crash when SketchUp is starting or when you try and run the RB ?
I have it installed in v2017 and it works just fine !
Global Moderator
Postby cyalumina109 » Fri Dec 14, 2018 4:29 pm
Hey TIG I have the same problem now, it crashes just after opening it
cyalumina109
Postby Dave R » Sat Dec 15, 2018 2:45 pm
cyalumina109 wrote:Hey TIG I have the same problem now, it crashes just after opening it
Crashes immediately after opening are typically related to issues with the graphics drivers. With SketchUp 2017 and later, the graphics card must be up to the task of properly supporting OpenGL. What is the graphics card? Try updating the graphics drivers. If the graphics card is not up to the task, you may need to go back to SketchUp 2016 which has the option to dump rendering duties to the CPU.
When you installed SketchUp, did you right click on the installer file and select Run as administrator from the context menu?
Global Moderator
Previous
Return to SketchUp Bug Reporting
