Mac OS X Leopard and SU - text tool problem
Found a bug in SketchUp? Report it here
Postby MCN » Mon Nov 26, 2007 11:58 am
Good morning.
I have a lovely new Mac running Leopard, and have started to find problems with SU. In the main Leopard thread someone suggested starting a new thread for specific bugs, so here's mine.
The text tool has stopped working. Clicking it opens its usual little window, and clicking 'fonts' brings up the list of fonts, but it's not possible to select from this list.
The tool will create and place open-faced text but not filled text, and will only allow the default font (which seems to be Tahoma). Is this something to do with a change in the way Leopard organises its fonts library? I hope it gets fixed soon.
If there is an obvious fix for this then apologies, and please do enlighten me!
Matthew.
MCN
Re: Mac OS X Leopard and SU - text tool problem
Postby Gaieus » Mon Nov 26, 2007 12:13 pm
Yes that was Brad, I think, of the Google team.
If you don't mind I'm moving this thread into the Bugs forum immediately since they seem to be visiting that one more regularly than other forums.
User avatar
Postby mariocha » Mon Nov 26, 2007 4:52 pm
MCN wrote: will only allow the default font (which seems to be Tahoma).
Same problem here. Mac OS 10.5.1
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
User avatar
mariocha
Premium Member
Premium Member
Postby Mark Leichliter » Mon Nov 26, 2007 5:14 pm
I get this same behavior. It looks like SU uses a custom font dialog for this - not sure why they don't use the system default. I tried changing fonts using two methods: by just selecting the text, pressing Command-T for the font selection dialog, and making changes therein - nothing happens. Second method was using the model info window and utilizing the "select all screen text" and "update selected text" buttons - again with no effect.
Mark Leichliter
Postby davekn » Mon Nov 26, 2007 9:36 pm
Same problem here.
2.1GHz IMac
Mac OS 10.5.1
Sketchup 6.0 (6.0.1145)
davekn
Postby tim » Tue Nov 27, 2007 3:58 am
Weird; on my macbook I *can* do filled text ok but I do have the non-responsive font dialogue. *except* that I can type a font size value in the top-right field.
tim
Postby mariocha » Tue Nov 27, 2007 1:59 pm
and move the slider also.
But still cannot change font indeed.
Mario C.
User avatar
mariocha
Premium Member
Premium Member
Postby Mark Leichliter » Tue Nov 27, 2007 5:22 pm
Found this in my console (in case it helps):
11/26/07 9:03:34 AM SketchUp[2393] *** -[SkpFontPanel tableView:shouldSelectRow:]: unrecognized selector sent to instance 0x2223c00
Mark Leichliter
Postby brad » Wed Nov 28, 2007 2:42 pm
Hi Everyone,
Sorry for the late response on this topic.
The Font problem is a known issue with Leopard using the 3D Text Tool.
Here are a couple of other gotchas...All the problems are being worked on as I type and we hope to have this problems resolved soon.
http://sketchupdate.blogspot.com/2007/1 ... pdate.html
Hope this helps.
Brad
Google SketchUp QA
Brad
SketchUp QA
User avatar
brad
SketchUp Team
SketchUp Team
Postby MCN » Wed Nov 28, 2007 2:47 pm
Thank you, Brad. I'm glad to know it's being worked on.
Matthew.
MCN
Postby Gaieus » Wed Nov 28, 2007 2:47 pm
Thanks Brad for the reply!
User avatar
Postby mariocha » Sat Dec 15, 2007 10:10 am
Brad wrote:The Font problem is a known issue with Leopard using the 3D Text Tool.
Brad
Google SketchUp QA
It is not only 3D Text Tool, it is ALL Text tolls !!!
Hum... I hate a response which is off the matter. Feels like a quick "get it off my desk".
Mario C.
User avatar
mariocha
Premium Member
Premium Member
Postby Gaieus » Sat Dec 15, 2007 12:28 pm
Hi Guys,
Though I'm on Windows, I know that most recent maintenance release 4 covered some issues with Leopard.
Could you download and install and check back whether the problem still exists?
User avatar
Postby mariocha » Sat Dec 15, 2007 8:22 pm
Hey !!! After reading your message, I launched SU and, bing, it says a newer version is available.
And, YES ! the text problem is solved ! Mac v.6.0 (6.4.120)
Great Job guys !
Mario C.
User avatar
mariocha
Premium Member
Premium Member
Postby Gaieus » Sat Dec 15, 2007 11:28 pm
Ah, good news then.
Thanks for reporting back (they need reassurance at the very moment...)
:roll:
User avatar
Postby tim » Mon Dec 24, 2007 7:01 am
mariocha wrote:Hey !!! After reading your message, I launched SU and, bing, it says a newer version is available.
Hmm, I have that same version and although I can set the font and size of 3D text I can't do anything with dimensional or other text; the font dialogue is simply ignored and attempting to use the context menu and the font->styles option just makes a chirp.
tim
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Bug Reporting
Who is online
Visit our sponsors:
