Extension Manager not loading
• Page 1 of 1
Extension Manager not loadingFor some reason, after opening up SU this morning and going thru the usual extension updates, I tried opening up EM and it's not showing up!. Extension WH and other side applications open just find, but not Ext. Mgr.
Any thoughts? If I make it look easy. . .then it probably is.
Re: Extension Manager not loadingWhat SketchUp version? What operating system? Please complete your profile.
Is it that the Extension Manager window isn't displayed or that it's just opening and is blank? Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: Extension Manager not loadingWin 10 Sketchup 2020. It just isn't loading period.
thx, D If I make it look easy. . .then it probably is.
Does that mean the window isn't appearing on screen at all? If that's the case first try Preferences>Work Space>Reset Work Space. If that doesn't work, you can either try editing the position for that window in PrivatePreferences.json which is in User/AppData/Local/SketchUp/SketchUp 2020/SketchUp. Mine looks like this: Edit the Left and Top values. Do this while SketchUp is closed. Or you could try repairing the installation by finding the downloaded installer, right clicking on it and choosing Run as administrator. If prompted, click Repair. If you don't have the most recent version of 2020 installed or don't have the installer, get the installer from sketchup.com/download/all Etaoin Shrdlu
Re: Extension Manager not loadingNope. Im running a repair right now. I will see what that does.
Stand by. I know you're waiting on baited breath. ![]() If I make it look easy. . .then it probably is.
That's what that taste in my mouth is! I thought my coffee was just bad. ![]() Etaoin Shrdlu
Re: Extension Manager not loadingwell . ..that didn't work.
Re: Extension Manager not loadingYou haven't answered my question about it not loading. Does that mean the window is opening but it's blank or it doesn't appear at all?
Re: Extension Manager not loadingdoesn 't appear at all. Zip. Nada. Nyet.
The thing that is odd about all of this is that it was working fine yesterday. Maybe i should do a re-install. Darn it. I was hoping to avoid that. D ![]() Last edited by david_h on Thu Jan 21, 2021 5:23 pm, edited 1 time in total.
Re: Extension Manager not loadingI sent you a PM.
Re: Extension Manager not loadingFIXED!
Dave R. . .you're my new hero! Thank you! D If I make it look easy. . .then it probably is.
Re: Extension Manager not loadingHappy to help David.
Where did you find that picture of me? ![]() Etaoin Shrdlu
Re: Extension Manager not loadingIt seems you are all over the interwebs.
I am just glad that the planet is in caring hands of those that are much smarter than me. If I make it look easy. . .then it probably is.
That's the problem. No privacy. ![]() I'm happy it was a pretty easy fix. Etaoin Shrdlu
I assume it was the alt space fix? Re: Extension Manager not loadingTried that. Wound up editing PrivatePreferences.json and setting the Left and Top to match the Extension Warehouse numbers.
Re: Extension Manager not loadingGood to know, it could be frustrating for others looking for an answer not actually finding one in the thread when it has a solution check-mark.
• Page 1 of 1
