Repeat last command
Got an idea to improve SketchUp?
Repeat last command
Postby alz » Wed Mar 26, 2008 5:05 am
A simple one from Maya -- it repeats what you last did (whatever that may be). It was very handy at times.
(This could probably be an easy Ruby script to make)
alz
PluginStore Author
PluginStore Author
Re: Repeat last command
Postby pav_3j » Thu Mar 27, 2008 12:16 pm
yeah that would be pretty useful, i use that function a lot in maya and autoCAD.
good shout
pav
Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
pav_3j
Postby icepam » Thu Apr 17, 2008 11:22 pm
absolutely - been looking for that too. repeat last command is a wonderful tool, i use it a lot in coreldraw, e.g. CTRL-R
the way it works in coreldraw is for example if you duplicate an element then move it, then adjust it a bit, it will remember the offset, so tapping CTRL-R will repeat the duplication, with the same distance.
the trick is to only save the state of the change after a second or two it has been done, to make sure the command repeats relative to the original and not just the fine-tuning.
icepam
Postby mirjman » Thu Apr 17, 2008 11:45 pm
this exists as a double click for most things, like offset and push pull, just double click the next surface and it remembers your offset. for moving things, usually your cursor will snap at the previously entered dimension the next time you draw.
mirjman
Postby Alan Fraser » Fri Apr 18, 2008 7:25 am
The CorelDRAW function works very well for dynamically producing arrays too. For instance, you don't always know how many repeats (of fixed spacing) it's going to take to get from A to B, so typing something into the VCB is just guesswork. It's so much easier to just keep your fingers down on Ctrl+R until you get there.
FormFonts
Alan Fraser
Top SketchUcator
Postby Aris » Wed Sep 26, 2018 10:43 pm
10 years later and still no repeat command?
Is there any chance somebody might spend some time and make it?
Rhino has it as well and once you get used to it it's verrry handy!!!
Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
Aris
Premium Member
Premium Member
Postby numerobis » Thu Sep 27, 2018 10:19 pm
numerobis
Return to SketchUp Feature Requests
