Change material of multiple components
Got an idea to improve SketchUp?
Postby pohlr1 » Thu Feb 22, 2018 6:27 am
Now I know what you are thinking, there are already threads on this but I think what I need is a bit different, I have looked and looked on this.
See attachment, what I am trying to do is turn the geometry material of the bottom plates to treated. Sometimes I have douzens of these walls and doing this manually would take hours. I would also like to change some of the headers to LVL. We can even keep the color because why this is important is because I use a addon called cutlist and it works great except it lists materials as they are like material 9 for instance.
Thanks!
pohlr1
Premium Member
Premium Member
Re: Change material of multiple components
Postby pohlr1 » Thu Feb 22, 2018 6:46 am
HAHA I think i just found a slilght workaround, If I change the paint cutlist will actually use that name, works.
pohlr1
Premium Member
Premium Member
Postby Dave R » Thu Feb 22, 2018 3:59 pm
That's not a slight work around. CutList is designed to work that way.
You could make a set of colors with custom names to apply to the different components. If you apply them to the faces in the components, you only need to do that to a single instance and all other instances will get the same treatment. Save your collection of customized colors for later use.
Global Moderator
Return to SketchUp Feature Requests
