Warning before a component is edited
Got an idea to improve SketchUp?
Postby pipingguy » Mon Jun 20, 2022 4:29 pm
We should be given a pop-up warning if we are about to edit a component - especially in a large model. Glancing at the Entity info inspector panel does not work well because the top of the panel is sometimes obscured and would therefore take an action to reveal it. And even if it's un-obscured, just glancing takes time when you are focused on the work at hand. If I edit a component without knowing it has copies elsewhere in the model, it creates a huge problem.
pipingguy
Re: Warning before a component is edited
Postby Box » Tue Jun 21, 2022 1:30 am
There was a plugin made for people that have this problem with their workflow.
https://sketchucation.com/pluginstore?p ... s_EditFlag
User avatar
Postby TIG » Tue Jun 21, 2022 3:50 pm
EditFlag has an issue with newer versions' stricter Ruby.
I posted a fix here:
http://sketchucation.com/forums/viewtop ... 83#p670883
which addresses it, but it does mean editing its RB file !
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Feature Requests
Who is online
Users browsing this forum: No registered users and 4 guests
