Sketch-Int    v25.09.24
This plugins aims at giving you a kick-start at modeling houses. It was first intended for interior designers, hence the name. And hence the method of always inserting an item from the inside of the building.
The generated components are managed not to cumbersome the browser.
The components only contains groups so you can edit them at will ( edits will be lost if the item is regenerated by the extension). Doors are exceptions because we want to edit only one when there are many. So they are components.
For walls : Draw a line, select it, hit the first button on Toolbar. For a perpendicular wall to that first one, select the vertical line at one end and the adjoining face. Hit the second button on Toolbar.
For doors & windows, the dialogs will display an Infos? button at the bottom. Read carefully.
2 Tags will be added: z-closed doors & z-opened doors.
First 30 days are free trial. Then subscription is required: 25$ for 700 days.
The dialogs will display an Infos? button at the bottom. Playlist. https://www.youtube.com/playlist?list=PLhKs1EtBRm-tzkby3ZOqZ9V1guzoZ11W4
  • 25.09.24 Small corr. to units
  • 25.09.01 Bug corr. in menu : UI::Command.new(LH['Interior Windos']. Better plug windo, any depth. Better HTML consistency. Better transm.
  • 25.05.15 Window top divider spacing corrected. Ext & Int
  • 25.05.12 Bug correction
  • 25.03.02 Small correction to outer frame
  • 24.02.14 Added some love.
  • 24.01.24 Trial bug correction
  • 24.01.08 Better move: decimal and fractions
  • 24.01.08 Minor HTML tweaks.
  • 23.12.12 Small correction to ext. door moulding.
  • 23.11.30 F3D_Move tool, and many corrections preventing bad opening.
  • 23.11.14 Transom & sidelights to Interior doors. Transom dividers to all.
  • 23.10.31 Correction to top dividers when multi.
  • 23.10.03 Ext door jambs = 1.5", trapz window glass, INTERIOR windows...
  • 23.05.05 Small corrections to side-lights.
  • 23.03.15 Linetowall correction.
  • 23.02.23 Added images for Sliding windows w transom.
  • 22-12-28 Added Frame1 and Multi-sash. Corr. to all grills. Edit cleans compos. New item are selected upon placement.
  • 22-12-20 Undo Edit windo in 2 steps. Added Top Dividers
  • 22-11-23 small Corr. for 2020 downward compatibility
  • 22-11-18 Corr. to Infos & grills 22-11-15 Added Circular - Polygonal windows. 22-11-11 Added Trapezoid windows. 22-11-03 Added 4th sliding door. Corr. to exterior. 22.10-30 Correction to SketchUcation check. 22.10-29 Correction to grills. 22.10.26 Check if SketchUcation plugin is present. 22.09.26 Better Exterior doors color to halves. 22.09-15 Corr for Exterior doors 22.09-02 All windos & exterior doors are now built in 2 parts for easy coloring of exterior / interior halves and mouldings. 22.08.14 English 'Infos' texts are back. 22.06.30 Added Sliding windos, with parametric stile width. 22.05.25 Better Undo Edit windo. 22.04.06 Multiple Open. Louver int. doors. New handles. 22.03.29 Added ajustable Stiles width for exterior doors.
