[Plugin] 3d Shapes Tool (was: Pyramid Tool)
Postby Macs » Thu May 08, 2008 2:57 pm
Updated Version, now "3D shapes Tool"
1.0
shape: cone
shape: sphere
shape: rotated pyramid
1.1
+ shape: dodecahedron
+ shape: icosahedron
+ CTRL key to toggle between center or base first vertex.
+ varius minor improvement
Old starting post below:
Hello,
During my experiments with ruby programming for SU I've produced
this tool for drawing pyramids based on rotated rectangle tool.
Maybe it's useful to someone...
usage:
Menu->Draw->Rotated Pyramid
I think it's easy to use, but suggestions are welcome.
Note: that this is an OLD script, probably unsuitable for >v8 without some Ruby editing - why not look for SketchUp's own newer and more comprehensive Shapes tool at EW...
Macs
Re: Pyramid Tool
Postby juju » Thu May 08, 2008 3:37 pm
Hi Macs! Welcome to SCF, thanks for your contribution.
Please do the mods (and browsers) a favour, change the title to read: [Plugin] Pyramid Tool.
It makes it a lot easier to identify threads with plugins, as per the posting guidelines.
juju
Premium Member
Premium Member
Re: [Plugin] Pyramid Tool
Postby tomot » Thu May 08, 2008 9:10 pm
Thanks Macs, I have been looking for a code snippit for finding 3d mid points
and other points that work in all planes.
thanks also for not hiding the code, ala encryption.
tomot
PluginStore Author
PluginStore Author
Postby Macs » Fri May 09, 2008 8:51 am
Sorry for the title.. :) now it's correct.
@tomot: it's nothing, this is just my first experiment.. I'm happy if it could be of some help to others programmers.
Macs
Postby JClements » Fri May 09, 2008 7:06 pm
Good job and thanks!
JClements
Premium Member
Premium Member
Postby CPhillips » Mon May 12, 2008 6:07 am
Macs wrote:Hello,
usage:
Nice job! I think modeling tools like this are sorely missing from the basic Sketchup functionality.
Do you have any interest in expanding this to support other shapes? If so I would give you any support you need and I could provide a good head start on some of the other shapes (box, cylinder, cone, sphere, capsule).
Chris
CPhillips
PluginStore Author
PluginStore Author
Postby Macs » Wed May 14, 2008 4:28 pm
I've done some more work on it, completed a cone tool
and added a toolbar. I'm progressing with work, soon a new release
with more 3d shapes.
Well it's a sort of toolbar for newbies :)
who don't know how to draw more complex shapes in few steps.
I'm sure expert modelist know well how draw these shapes,
perhaps it will help when there are many to draw.
Macs
Postby urgen » Wed May 14, 2008 6:31 pm
Macs wrote:I've done some more work on it, completed a cone tool
...Marcs, it is very good and useful idea! :thumb: I thought of it and wished to ask about it Chris :? ... Success to you... It is necessary not only to beginners... really ! ;)
--pupil forever...------
urgen
Postby Gaieus » Thu May 15, 2008 10:15 am
Macs,
Before you invest much time in this project, have a look at shapes.rb (by @Last) downloadable from Didier's site here:
http://www.crai.archi.fr/RubyLibraryDep ... o_page.htm
It will create an item in the Draw menu.
I'm glad however that there are more and more ruby scripter around soo keep up the good work! :thumb:
Postby Macs » Thu May 15, 2008 4:36 pm
I've seen that script, mine is a little different, but it was useful to learn from it.
Macs
Postby Gaieus » Thu May 15, 2008 4:39 pm
OK then, I just wanted to let you know... ;)
Postby urgen » Thu May 15, 2008 10:40 pm
////MMMMM :roll: ...... shapes rb.- table skript :? ... SK-FIZ (shapes)-it only drawing tool, but it
does not work with the keyboard... :? Let's make that the keyboard there worked! It will
be excellent and very useful tool! :D :bounce:
urgen
Postby CPhillips » Fri May 16, 2008 7:47 am
In case you haven't seen it. Here is a demo of the shapes that are in the Solids toolbar of SketchyPhysics. It should probably be split out as a separate plugin. But I have too many plugins as is.
CPhillips
PluginStore Author
PluginStore Author
Postby Macs » Fri May 16, 2008 10:51 am
Ok! This is almost identical at what i'm coding... :lol:
I've missed this in SketchyPhysics.
I've seen there is some difference in how the shapes are drawn,
and I've inserted support for VCB input.
however here there is the new script, now "3D Shapes Tool"
Macs
Re: [Plugin] 3d Shapes Tool (was: Pyramid Tool)
Postby CPhillips » Fri May 16, 2008 8:33 pm
:ecstatic:
Looks like you are doing great. But feel free to copy anything you want out of SketchySolids. It is also based on the rotated rectangle code.
CPhillips
PluginStore Author
PluginStore Author
Postby urgen » Fri May 16, 2008 9:42 pm
...:thumb: :thumb: :thumb: don,t stop this work ,please! :D
urgen
Postby JClements » Sat May 17, 2008 3:00 am
Macs, nice work.
Is there any way to allow the tools to respond to a User Defined Axis?
JClements
Premium Member
Premium Member
Postby CPhillips » Sun May 18, 2008 10:20 am
Loving the plugin dude!
Suggestion. Once you place the shape it is hard to set the height. You need to have something to infer the height and if nothing is available it is frustrating. My solution was to add a construction line to the center of the shape after the second click.
Try adding the following line to the the ConeTool::increment_state() function.
Code: Select all
def increment_state
   @moved = false
   @state += 1
    case @state
    when 1
      @ip1.copy! @ip
      Sketchup::set_status_text "Click to set the radius"
      Sketchup::set_status_text "Radius", SB_VCB_LABEL
      Sketchup::set_status_text "Move mouse", SB_VCB_VALUE
    when 2
        @ip1.clear
        Sketchup.active_model.entities.add_cline(@pts[0],@normal)
        Sketchup::set_status_text "Click to set the height"
        Sketchup::set_status_text "Height", SB_VCB_LABEL
    when 3
        self.create_geometry
Getting rid of the cline and having it work right with undo is a bit tricky, but if you are interested I can walk you through it.
Chris
CPhillips
PluginStore Author
PluginStore Author
Postby Jim » Sun May 18, 2008 10:58 am
Hi Macs,
Thank you for working on this. :thumb: It is a needed and important plugin, don't stop now!
Jim
Global Moderator
Postby dylan » Sun May 18, 2008 9:09 pm
This is really nice macs and very useful.
Thanks :thumb:
dylan
Postby Macs » Tue May 20, 2008 8:42 am
CPhillips wrote:Loving the plugin dude!
[CUT]
Chris
Strange.. on my system my tool works differently :(
when you do the second click with the cone tool it goes up
and down with the height without being locked on the surface.
I have to review the code to see if I made some mistrake invocking
some method without "self.".
thank you for the suggestion on the costruction line, I'll think about it.
Macs
Postby CPhillips » Wed May 21, 2008 6:57 am
I figured this out. In my case I build a lot of shapes on a big floor plane. When I draw a cone it infers the height from the floor. I don't think this is a flaw in your plugin. But the construction line is still useful in many cases.
CPhillips
PluginStore Author
PluginStore Author
Postby urgen » Wed May 21, 2008 8:16 am
....Please wait ....will be OK! ;) :D ..
urgen
Postby Macs » Wed May 21, 2008 8:18 am
You are right!
I've adde the construction line feature ( ripped from your tool :D )
It will be available in the next release, thank you.
Macs
Postby urgen » Wed May 21, 2008 8:32 am
Scripts is ready ;) , problems of translation(russian-english) :roflmao:
urgen
Postby urgen » Wed May 21, 2008 12:20 pm
...This is both very interesting and useful topic :thumb: …I wonder why the founders of SKETCH-UP haven’t done the 3d shapes (primitives) earlier :? …If we have raised such an issue and this caused that much interest, we have to finish it up… :!: I am not a script man, although many people say I would be capable of doing that quite a bit…unfortunately, quite poor knowledge of English and the tough schedule do not let me study RUBY in more details…I had a choice to make here: to draw or to write…I have chosen the 1st one…However, I do get the processes in scripts and can freely apply some changes for my personal convenience in my usage but not more than that…I quite like the style of painting the figures in SketchyPhysics ( Chris, I really appreciate it!) and the MACS style too… I have selected the files responsible for SHAPES building (from SketchyPhysics) and have made a decision to turn for help to one amazing Russian man Sahi (you possibly remember his name from the script “building a house”). In a few hours I got a response you can see below… :D …This is a Russian version and not everything works ideally, but much respect for his talent…he does not know English, but still manages to write English RUBI (imagine yourself writing RUBI in Russian or Chinese, which you do not know!!)… ..The many people the many minds, but the last thing I want is him to be remoted from the forum….thank you Sahi one more time! :ecstatic: .....all the parameters of the letters are ascribed with the help of the keyboards…very convenient! :thumb: ...MACS, I think that would be useful for you…And Chris---a comfortable supplementary for your SketchyPhysics. ;)
urgen
Postby CPhillips » Thu May 22, 2008 1:53 am
Thanks for doing that Urgen. But I recommend this only be used for reference. There is still a fair amount of physics stuff in there. And it that could conflict with future versions of SketchyPhysics.
CPhillips
PluginStore Author
PluginStore Author
Postby CPhillips » Thu May 22, 2008 2:01 am
I noticed you have the same problem I did when creating spheres. I was never able to figure out why they were sometimes reversed. I wound up doing my own sphere routine.
What other shapes do you plan to support?
CPhillips
PluginStore Author
PluginStore Author
Postby sahi » Thu May 22, 2008 12:14 pm
Corrected some errors
SketchyPhysics_1.zip
sahi
PluginStore Author
PluginStore Author
Postby lapx » Thu May 22, 2008 1:46 pm
Can parametric tool be added this. After or during adding shape you can change radius or height parameters. VCB stuff you know. Now this would be fantastic!!! :fro:
lapx
Next
Return to Plugins
Users browsing this forum: arqmelanie, bengpin, bonal78 and 16 guests
