[Plugin] Clean Unwanted Edges
Postby a4chitect » Fri May 02, 2008 11:20 pm
Script explanation:
the loop goes through all selected geometry, check if the current entity is an edge, and if yes it erases this edge in 2 cases
1. it is an edge belonging to 2 faces at the same time, their normals are parallel (faces are coplanar) and their front color is the same
2. it is an edge which doesn't form any faces
this part is taken (after a little modification) directly from the script Skin by Darrel Belvin so all credit is his (hope he doesn't mind me posting this)
Warning: please save your model prior to running this
cleanup.rb
3
a4chitect
PluginStore Author
PluginStore Author
Re: [Plugin] quick cleanup of unnecessary lines
Postby keithp27540 » Mon Oct 04, 2010 1:21 pm
I've been using SketchUp for a few years now and have been using it to import STEP models of electronic components, all of which need additional cleanup to make them presentable. This plugin is going to save me a BOAT LOAD of time.
This ROCKS! :berserk:
keithp27540
Postby viv » Sat Mar 10, 2012 8:57 am
i cant seem to be able to download the plugin :(
viv
Postby TIG » Sat Mar 10, 2012 6:20 pm
viv wrote:i cant seem to be able to download the plugin :(
It should download [from the link]... BUT there are several 'better' tools available now - this is an old script...
I suggest you investigate some of Thomthom's toolsets - like Cleanup...
Global Moderator
Postby Gaieus » Sat Mar 10, 2012 7:09 pm
Are you saying that these download links do not work for you?
Postby cadmenow » Sat Jan 12, 2013 11:05 pm
I have SU8 for mac. I downloaded clean.rb and paste into plugin folder and restart my SU. But it did not work. I can not eve see the tool in my lists. This happened at some other plugins too. Maybe I am doing something wrong, has anybody can help me ?
ps: When I did the same thing into my SU8 for windows it is working. But not in mac :(
cadmenow
Postby TIG » Sun Jan 13, 2013 12:34 am
So... it looks like either you haven't got FULL permissions to read/write to the MAC's Plugins folder [fix them] OR you are using the wrong 'plugins' folder.
It should be the Macintosh HD 'plugins' folder NOT the 'user' one !
There are dozens of threads already about which is the correct MAC 'plugins' folder and 'permissions' :roll:
Search SCF for some key-words...
Incidentally there are now many scripts/toolsets better than this one...
Search the SCF Plugins Index - e.g. Thomthom's 'Cleanup'...
Global Moderator
Return to Plugins
Users browsing this forum: Google Bot, maxa, maxstudio and 16 guests
