[Plugin] Sine Wave
[Plugin] Sine Wave
Postby Jim » Wed Mar 26, 2008 1:41 am
Draws a sine curve at the Origin in a Group.
Jim
Global Moderator
Re: [Plugin] Sine Wave
Postby stefx » Thu May 22, 2008 3:55 pm
Hi Jim,
How can I use this plugin?
I have installed it and I can see it in my plugin folder.
Could you give me some tips?
sorry....I'm a little bit new of sketchup.
stef.
stefx
Postby Jim » Tue May 27, 2008 9:50 pm
stefx wrote:Hi Jim,
stef.
Sorry stef, I am only seeing this post today. Does the plugin show up in your Plugins menu?
Jim
Global Moderator
Postby stefx » Fri May 30, 2008 9:54 am
Hi Jim,
Thank you for your answer.
I can see in my plugin menu.
when I insert the number in "lenght, amplitude and segment" I have the same straight line beginning from the centre....
I don't know...
Probably I have to play more with it.
stef.
stefx
Postby BobHewson » Fri Sep 26, 2014 4:49 pm
I am a novice using Sketchup make 2014 (free), but am slowly learning.
I have used your sine wave generator to create a repetative sine wave line successfully.
What I am trying to do is to take a rectangle and add the sine wave line within the rectangle and then erase excess material so my rectangle has a sine wave edge. I will then pull the shape up 1/2" to form my item.
The resulting form will be exported as a stl file for 3D printing.
My problem is that the sine wave form line will not join to the rectangle. When I select a section to erase it erases the entire rectangle. Is there some way to join the sine wave line to the rectangle?
Any suggestions will be appreciated.
Bob
BobHewson
Postby TIG » Sat Sep 27, 2014 2:10 pm
@Bob
The sine curve is made inside a group.
This allows you to position it after it's created - otherwise it might stick to other geometry.
You can Select that group and use the context-menu Explode, so it merges with any geometry around it.
Global Moderator
Postby BobHewson » Sun Sep 28, 2014 6:23 pm
Thanks TIG, that was pretty easy! Now I know a little more about Sketchup.
Bob
BobHewson
Return to Plugins
cron
Users browsing this forum: filipecadu, komac and 11 guests
