JointPushPull 4.0g - Call to kind users for Evaluation
Postby fredo6 » Wed Oct 11, 2017 3:48 pm
I slightly re-engineered JointPushPull around 2 areas:
  1. The Selection Process, which is now based on a single-click method, that is, Hover face - Click - Drag, and you are done (i.e. no more green and red faces!)
  2. The Button palette, which is redesigned to be clearer, and has now a simple and an extended mode. There is also a new tool, called Thickener, which is simply a no-frill JointPushPull with NO button palette and fewer options.
At this stage, the new JPP 4.0 is packaged as a separate extension with name JointPushPull4. So it can coexist with the current version JPP3.
JointPushPull v4.1 is now released.
Please see here for download
Note that you need to install LibFredo6 7.8a, which is now on the PluginStore.
I'll be grateful to some kind users to have a look and give some feedback or report problems.
As many users don't take the time to read documentation or even watch videos when installing extensions, I deliver it here 'naked'. I will however publish soon a small video tutorial on the basic operations, in particular the new selection process.
Thanks for your cooperation
EDIT: Here is the video
8
User avatar
PluginStore Author
PluginStore Author
Re: JointPushPull 4.0 - Call to kind users for Evaluation
Postby Pixero » Wed Oct 11, 2017 4:55 pm
Looks great!
User avatar
Pixero
Postby srx » Wed Oct 11, 2017 5:54 pm
Just what it needs! Intuitive SU like interface. Thank you very much. :thumb:
www.saurus.rs
User avatar
srx
Postby JQL » Wed Oct 11, 2017 7:54 pm
The click+click operation is great!
User avatar
JQL
Premium Member
Premium Member
Postby filibis » Wed Oct 11, 2017 8:47 pm
Great to see already polished tool is getting even more update!
I give it a try and everything works flawlessly!
User avatar
filibis
Re: JointPushPull 4.0g - Call to kind users for Evaluation
Postby fredo6 » Wed Oct 11, 2017 10:09 pm
Just published an update, as v4.0g - 11 Oct 17
- fixing a few bugs
- introducing a transparency factor for wireframe faces (based on a bright suggestion by JQL).
Here is a short video on the transparency factor.
JPP4 Transparency.mov
I updated the main post with v4.0g.
User avatar
PluginStore Author
PluginStore Author
Postby Bob James » Thu Oct 12, 2017 2:27 am
Outstanding! Much easier to use. Thank you!
User avatar
Bob James
Premium Member
Premium Member
Postby cuttingedge » Thu Oct 12, 2017 5:39 am
even made more powerful!! Thanks Fredo!
cuttingedge
Postby pilou » Thu Oct 12, 2017 11:36 am
Excellent! :fro: :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby cotty » Thu Oct 12, 2017 8:15 pm
I've watched the basics video and enjoyed it!
User avatar
cotty
Top SketchUcator
Postby pbacot » Fri Oct 13, 2017 4:02 am
I watched the video and it looks excellent!
MacOSX (El Capitan) ShetchUp Pro v16 Layout Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby panixia » Fri Oct 13, 2017 5:17 pm
Thank Fredo for your precious work. I tested JPP4 a little bit and the interface seems to be a big improvement.
It also looks like in this relase, the text is always black, not "default line color dependant" as previous versions were. I tend to work with my custom sketchup style, wich uses white as default line color instead of black and having the white text in jpp/curviloft/roundocorner was a bit uncomfortable and hard to read. Now that's perfect!
I have a little request, if possible/not too hard: can you add an option to preserve/create quads? Curviloft and Trupaint already support it and can be integrated really well in a quad/sub-d workflow.. Having JPP with same capability would be a dream!
User avatar
panixia
Postby fredo6 » Wed Oct 18, 2017 10:28 am
panixia wrote:I have a little request, if possible/not too hard: can you add an option to preserve/create quads? Curviloft and Trupaint already support it and can be integrated really well in a quad/sub-d workflow.. Having JPP with same capability would be a dream!
I think there is the option, but for Normal PushPull. Not sure it makes sense for the other tools.
User avatar
PluginStore Author
PluginStore Author
Postby panixia » Tue Oct 24, 2017 7:56 am
I'll try to put togheter a simple example to show you why i think that could make sense both with NPP and regular JPP.
edit: I noticed this tread is about outdated version, so I posted my example here
viewtopic.php?f=323&t=54771&p=626639#p626639
User avatar
panixia
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: No registered users and 11 guests
Visit our sponsors:
