Wish list for Sketchup 2018
Got an idea to improve SketchUp?
Postby jcharltoncarp » Wed Nov 16, 2016 9:56 pm
I will start out with a request for an automated migration tool so that I don't have to waste hours manually migrating form one version to the next.
4
jcharltoncarp
Premium Member
Premium Member
Re: Wish list for Sketchup 2018
Postby Pixero » Wed Nov 16, 2016 10:10 pm
jcharltoncarp wrote:I will start out with a request for an automated migration tool so that I don't have to waste hours manually migrating form one version to the next.
Loading a plugin bundle from a previous SketchUp version with the Sketchucation Plugin store is very fast.
You can also export your old shortcuts keys and import into the new version.
I was up and running in a matter of minutes.
Pixero
Postby bsfranza » Thu Nov 17, 2016 4:29 pm
now that we have new graphics pipeline in the back... give us ambient occlusion and maybe some other cool stuff that can be done :) like softshadows and the like
4
bsfranza
Postby Kuu » Mon Nov 21, 2016 2:08 am
+1 for all of the above.
Also (in order of importance IMHO):
  • DWG/DXF that doesn't break lines on 2D import. The current 2D export in particular is terrible, need to not break lines, preserve groups and components, layers and layer colors...
  • Fills / hatches on section cuts. (And a way to handle section planes better too... it becomes unwieldy fast)
  • Improved material browser / editor (macOS !!!) + basic texture mapping tools
  • Snap on imported vector PDFs. I could swear this used to exist and was removed some versions ago.
  • External Reference Manager, for Components / DWGs / PDF underlays so they can be easily reloaded / unloaded / replaced. Would be great for large projects and collaboration.
  • Multiple viewports / split screen. Like pretty much any other 3D modeling program out there...
  • macOS single window mode. Sometimes floating palettes are nice, but sometimes they make me feel like smothering kittens. Custom tool palettes would be nice too
  • Layer Manager
  • Improved dimensions and text
I know some of these things exist as plugins or workarounds, but they really should be added by Trimble, not force us to pay 3rd parties. Some of them have been requests for years since the early google era. :roll:
Crazy pipe dreams:
  • SketchupVR. I don't mean a viewer; I mean use sketchup in VR... That would certainly be an upgrade worth paying good $$$ for and prevent Sketchup from being abandoned in the future
Kuu
Postby bobrsta » Mon Nov 28, 2016 9:58 pm
I would really like the layer drop down in the entity info window to show more than 5 layers. I am organizing my models into 100 plus layers and when I create a component or group, there's a lot of scrolling through the list to find the layer on which I want to place it.
bobrsta
Premium Member
Premium Member
Postby Dave R » Mon Nov 28, 2016 10:49 pm
bobrsta wrote:I would really like the layer drop down in the entity info window to show more than 5 layers. I am organizing my models into 100 plus layers and when I create a component or group, there's a lot of scrolling through the list to find the layer on which I want to place it.
As a work around, bob, have you tried selecting the drop down menu and starting to type the name of the layer? When you highlight the desired layer, hit Enter.
Global Moderator
Postby bsfranza » Thu Dec 01, 2016 5:12 pm
now that the offset good improved .. why not make it work with multiple selections, inside and outside, with islands and so on.... same for push pull - this should also work for multiple selections imho :)
since trueoffset is appearingly devdead this would nice
bsfranza
Postby John Sayers » Thu Dec 01, 2016 7:38 pm
I would like the Windows version to have 2 or more files open at once - I gather the Mac version already has this feature.
John Sayers
Postby Dave R » Thu Dec 01, 2016 7:51 pm
John, you can have 2 or more SketchUp files open at once in Windows. I regularly have 2 or 3 going at the same time.
Right now on my PC.
Global Moderator
Postby TIG » Thu Dec 01, 2016 8:09 pm
John Sayers wrote:I would like the Windows version to have 2 or more files open at once - I gather the Mac version already has this feature.
On a MAC you only ever have one instance of SketchUp running - but then that one app can have several models [SKPs] open at the same time.
With Windows [PC] you have individual instances of SketchUp running - each is limited to have one model [SKP] loaded at any one time.
If you open another model from within an instance of SketchUp, then that instance's current model closes and the chosen model opens.
If you use Windows Explorer to open another model [SKP] - e.g. by double-clicking the model-file's icon in its folder, then you will get another instance of SketchUp started, using that chosen model loaded into it - and any previously open models will be unaffected by this and persist, each running inside their own instance of SketchUp...
In Windows it's just a matter of how you open each model which determines if any models that are already open survive ...
Global Moderator
Postby John Sayers » Fri Dec 02, 2016 2:27 am
Yes Dave - but you have to open separate sketchup programs - you can't just be on the one open sketchup and load another and have them both in the one open version and switch between the two.
John Sayers
Postby Dave R » Fri Dec 02, 2016 2:39 am
What difference does it make? As on the Mac, you can only work one of them at a time.
Global Moderator
Postby Box » Fri Dec 02, 2016 4:17 am
As I don't use a mac I'm just wondering if you have an advantage in that when you go from one model to the other does the current tool stay selected.
By that I mean, with windows each instance is a separate workspace, so if you have the move tool active in one it won't necessarily be active in the other and you need to change focus and then change tool.
Does it work the other way on mac, that you open two model in one workspace so swapping from one to the other is using the one toolset?
Postby JQL » Fri Dec 02, 2016 10:29 am
  • Layer Manager
Very nice list for us architects though I'd ignore section cut fills. I'd ask for that as a styles option as SectionCutFace manual filling is key to my workflow and detailing.
  • A scene manager to go along your layer manager and ability to customize which scenes show up on scene tab.
  • I'd like to have my materials linked to a texture file instead of always dealing with an embeded texture. They'd show a low res texture but when the file is changed the low res is changed. Renderers would work with the high res though.
  • I'd love to have linestyles for Sketchup and have all visual aspects of sketchup be controlled within layout. Dimensions would look the same as layout's, leaders too, texts, etc...
  • Layout could be a built in style manager for sketchup that would override all visual aspects of a sketchup viewport.
  • I'd also love that sections could be multiplanar and managed from Layout too. Add a section poly line in a Layout floor plan viewport and that multiplanar section would be created in Sketchup.
  • I'd like to be able to have multiple active sections simultaneously which is slightly different that a multiplanar section.
JQL
Premium Member
Premium Member
Postby Rich O Brien » Fri Dec 02, 2016 11:48 am
More love for StyleBuilder.
It could be the perfect portal to adding more visual fluff to your models.
Rich O Brien
Administrator
Postby baz » Tue Dec 06, 2016 2:58 am
I still cant get on with those darn trays!
I am not an early bird or a night owl, I am some form of permanently exhausted pidgeon.
baz
Postby Dave R » Tue Dec 06, 2016 3:11 am
Barry, where do you want the utility windows to be displayed?
Global Moderator
Postby baz » Tue Dec 06, 2016 5:10 am
Dave R wrote:Barry, where do you want the utility windows to be displayed?
Short answer... anywhere I want, with infinite sizeability and a lot of flexibility.
I know you will say all doable with new trays, but they are a pain to organize.
I spent 10 years with the old system. Did they ask us if we wanted a new one? Certainly didn't ask me.
Ok, I give in, I have just spent half an hour making a tray for each dialogue which is as close as I can get to the old GUI. I will see how I get on...
..OK, I already hate it...
3
baz
Postby Dave R » Tue Dec 06, 2016 10:53 am
Barry, I get it although I can't understand wanting the windows scattered all over the drawing space. Would you be constantly moving them out of your way so you can see the model? Ever since the stacking windows were released I've stacked them on the right side out side of the drawing space where they are neat and orderly and never covered any of the model. This is my SU2015.
[url=https://flic.kr/p/qpU5Ba]
For me, the trays are natural with the added bonus of more real estate for toolbar buttons at the top. I rarely need a window to be wider than the default but it's easy enough to drag the tray to make it wider when I do.
Global Moderator
Postby baz » Wed Dec 07, 2016 12:32 am
Oh well, guess I will have to learn to live with them, thanks Dave.
baz
Postby bsfranza » Wed Dec 21, 2016 10:41 am
somthing i would call DEEP SELECTION AND MOVE
say one has a window, door or anything else whichs is composed of multiple groups and components .. if one was to change the size one hast to go into each individual "object" and move stuff around...
what deep select and move would do, it would allow for multiple objects including nested objects to be preselected and then make it possible to select lines/faces or vertices (i look at thom thom here :)) of all objects and nested objects at once and move them...
this would make the process in su pretty damn nice
for the moment fredos stretch tool can do something like shit with stretch with reference point method but its a bit cumbersome...
if someone would find this as cool as i would - give me a +1 :)
thanks for your readers attention
bsfranza
Postby baz » Wed Dec 21, 2016 12:28 pm
bsfranza wrote:somthing i would call DEEP SELECTION AND MOVE
Sorry, I can't give you a thumbs-up because I have no idea what you are talking about :(
But I would be pleased to give you a serious THUMBS-UP for your beautiful English interpolated from, (I assume), German.
:thumb: :thumb:
baz
Postby Rich O Brien » Wed Dec 21, 2016 3:47 pm
baz wrote:Sorry, I can't give you a thumbs-up because I have no idea what you are talking about
I think he means to not have to click continuously to dig into groups/components.
If you ever used Fredos Animator you are able to select deep into a component from a dropdown list.
I think this is requesting similar behaviour to save the digging to get to the meat.
Rich O Brien
Administrator
Postby andybot » Wed Dec 21, 2016 4:50 pm
Isn't this a bit like what outliner does?
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby baz » Thu Dec 22, 2016 2:35 am
Aha, OK got it.
baz
Postby Nauzer67 » Sat Dec 24, 2016 4:39 pm
I would like to see a lockable inference for angles with the line tool
Nauzer67
Postby Mike Amos » Sat Dec 31, 2016 10:58 pm
Introduce the option to switch OFF the new inferences, they are a pain and I for one would like them gone.
Premium Member
Premium Member
Postby jcharltoncarp » Fri Feb 10, 2017 5:30 pm
I have seen so much criticism of the tray system, introduced in SU 2015, that I must come to the defense of the trays. If you use two monitors as many of us do it's a great way of organizing windows for quick access. Even with one monitor the trays can be hidden with the auto-hide feature.
Also the biggest advantage of SU is it's basic simplicity -no new tools please. That's what plugins are for! And finally please don't change nomenclature - I still call it the VCB whatever SU has changed the name to.
jcharltoncarp
Premium Member
Premium Member
Re: Wish list for Sketchup 2018: Total Revamp of Layer Mana
Postby JClements » Sun Mar 05, 2017 3:04 am
LAYER MANAGER
The Layer Manager organizes geometry for user convenience which it does well. However, SU is being used for a variety of different purposes by so many people/disciplines.
I feel Layer Manager redesign needs to be a primary target of SU 2018. It could alleviate a lot of frustration for many users and facilitate modeling efficiency.
My contention is that it needs to be far more flexible/configurable, with hooks in the API that will allow developers to do their thing.
So, trash the UI.
Use the Spreadsheet paradigm. The current fields/columns would would remain the same (and perhaps unconfigurable ?) so that templates and models from previous versions would remain in tact.
The UI would be user modifiable. New Columns could be added which could be assigned properties which could be sorted alphabetically, numerically, etc., for instance: a project phase assignment and I suspect many other useful category designations needed for different disciplines.
Column order would be changed by merely dragging column headings with the mouse. They could be assigned a background color. Perhaps styles could be assigned to columns which could be toggled on or off for specific layer(s).
Layers could have sublayers ( a sublayer "level" would be assigned as a "child" column with the ability to control the indentation of each child column by allowing the user to drag the sublayer column borders sideways).
Layers could be put into groups (for 4-d construction phasing, progressive disclosures, project phasing, assigning the background color of layers in the Layer Manager. Layer Groups could be used to override certain properties of the layers contained within them. Layer Groups (and layers) could be manually reordered by dragging the layer vertically
Layers could be *locked*.
There would be a *SOLO MODE* for layers. When toggled on to Solo Mode, all other layers would be temporarily hidden. This would facilitate editing of complex models and quickly verifying that geometry has been assigned to the proper layer.
I guess you could consider this suggestion to be a Data and Geometry Management system with a Layer Manager contained within in it.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
Postby GMthompson » Mon Mar 06, 2017 7:14 pm
i am voting for the use of dwg's with layout insertion of pdfs into layout and sketchup, also coming from a non developer or programming knowledge why do dimensions not import "if you have turbocad pro you can workaround that dimensions import"
you can learn something everyday by paying attention
GMthompson
Next
Return to SketchUp Feature Requests
Users browsing this forum: No registered users and 0 guests
