[Plugin] Divide script
Postby Didier Bur » Wed Jan 30, 2008 3:19 pm
Hi all,
Incidentally I had to write this little tool. It is similar to the "divide" command of Autocad, which doesn't break a line or segment into parts but insert points along a line, given the number of segments.
USAGE: Pick an edge, right-click and select "Divide by construction points". Enter the number of segments.
PS: New version from March 07, now works with arcs and circles.
Option to break line, arc, circle at construction points.
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: Divide script
Postby CadFather » Thu Jan 31, 2008 12:18 am
sounds good to me Didier, thanks......
CadFather
PluginStore Author
PluginStore Author
Re: Divide script
Postby 2myChaGrin » Tue Feb 05, 2008 4:05 pm
Thanks Didier! Should be helpful!
2myChaGrin
Re: [Plugin] Divide script
Postby Gschwartz9 » Tue Jun 21, 2011 11:00 pm
Speaking of AutoCAD, I could really use a routine equivalent to ACAD's "Slice" command.
Specifically, define a plane with any two intersecting straight lines. Any object intersected by this plane is sliced, with the user's ability to select the pieces retained ... either 'left', 'right', or both.
Applications = plumbing, carpentry, construction ...
Gschwartz9
Postby TIG » Wed Jun 22, 2011 10:20 am
Zorro2 ?
Global Moderator
Postby Chalkeia » Tue Nov 13, 2012 4:42 pm
Thanks Didier,
this is exactly the missing function I was looking for, but it does not work works under sketchup 8...
I posted too quickly and I did not put the script in the right plugins folder (damn Apple...)
Here is how to find it if you use a mac : http://sketchuptips.blogspot.se/2008/03 ... ugins.html
It works very well and save me a lot of work!!
Chalkeia
Return to Plugins
Users browsing this forum: dilaracira, Google Bot, HK6600, itachirao, mmiklaszewska, Nattias, rachidmustafa35 and 13 guests
