SketchUcation Plugin Store
[Plugin] Plugins help script
Postby Didier Bur » Fri Jan 25, 2008 9:49 pm
As AdamB suggested, here is a script for quickly accessing plugins help files.
It searches in the Plugins folder and its sub-folders for pdf,doc,chm,html files and builds a list from which you can select the file to read.
Select Plugins menu > Plugins Help files
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Plugins help script
Postby TIG » Sat Jan 26, 2008 12:52 am
...{... if @ext.include? x.split(".")[1] }
works for files containing names IF you use this to strip off the suffix/extension
...{... if @ext.include? x.split(".").last }
Global Moderator
SketchUp version: 8
License type: Pro
Postby azuby » Sat Jan 26, 2008 1:38 am
OK, here is my try for accessing help files out of Sketchup. It uses the some technics as Didiers script for showing the files, but my attempt scans the Directories in another way and recursively builds a nested menu structure.
Unfortunately there needs to be a lot checking, because we all know, that we can not access existing menus later.
Go to http://www.errorinitus.de/ > Software > PluginsHelp
azuby
error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory* | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
Bad English? PM me, correct me. :)
azuby
Postby Didier Bur » Sat Jan 26, 2008 1:45 am
Azuby,
That's just what I wanted to do, you beat me on this ! :thumb:
Didier Bur
SketchUp version: 8
License type: Pro
Postby TIG » Sat Jan 26, 2008 12:05 pm
Your method fails to find 'help' files within the Plugins directory itself - only does sub-folders ? Should be easy enough to fix... BUT it is very slow at start up building the list. I still think a dialog solution that builds the list as you want it is better...
Global Moderator
SketchUp version: 8
License type: Pro
Postby azuby » Sat Jan 26, 2008 1:22 pm
Yes, it is slow. It is a try, not a well to use Plugin. And you are right with the Plugins and Tools menu :oops:
It is slow because of many checks for folder content and because I don't want to have empty submenus.
Figure that out:
- Plugins : check for contained help files in its subdirectorys *
-- a : check for contained help files in it and its subdirectorys *
--- a1 : check for contained help files in it and its subdirectorys *
---- a11 : check for contained help files in it and its subdirectorys *
--- a2 : check for contained help files in it and its subdirectorys *
-- b : check for contained help files in it and its subdirectorys *
* and if it containeds help files, build a submenu.
a11 gets checked 4 times if it contains help files. The more nested the folder structure the more time will be need.
OK, who's next with a solution? [b]Idea[b]: Scan the folders with Dir.glob and create a WebDialog containing links to the help documents in a frameset.
azuby
azuby
Postby TIG » Sat Jan 26, 2008 9:38 pm
Here's my reworking of Didier's script for a dialog version. It makes an alphanumeric list of any plugins' help files. in the resulting window it displays the path in the top bar etc. It appears in the 'Help' menu, but it is easily changeable to appear in 'Plugins'. It is fast...
Thanks Fredo6 - must've hit a key between testing it and uploading it !!! corrected script re-uploaded !
Global Moderator
SketchUp version: 8
License type: Pro
Postby fredo6 » Sat Jan 26, 2008 11:13 pm
TIG,
There is an error, due to a missing closing brace '}' on line 22.
Otherwise, it seems to work, though I may prefer to have the menu / submenu version (one suggestion would be to build the submenus at first call, rather that systematically at load time).
Thanks a lot
fredo6
Top SketchUcator
Postby TIG » Sun Jan 27, 2008 12:12 am
Fredo6 wrote:TIG,
Thanks a lot
Fixed it !
Global Moderator
SketchUp version: 8
License type: Pro
Postby azuby » Sun Jan 27, 2008 12:18 am
Fredo6 wrote:[...] though I may prefer to have the menu / submenu version (one suggestion would be to build the submenus at first call, rather that systematically at load time).
Please excuse, do you mean my version? A "build menu on demand" is possible. I'll do it soon, at this moment my Sketchup processes a really huge modell (250.000 points, 60.000 faces) and isn't usable ;)
azuby
azuby
Postby fredo6 » Sun Jan 27, 2008 1:31 am
Azuby,
In theory, we could imagine that a user would not call a PDF at each Skecthup session, and if he does, after all, he could wait a little bit.
But your macro is fast enough that this fine too. When we have hundreds of PDF and HTML documenting scripts, we could revisit the problem ;)
All this proves that we have a damned good team of Ruby script programmers on this forum, as it took less than 24 hours to get 3 good versions after the idea just popped up.
fredo6
Top SketchUcator
Postby azuby » Sun Jan 27, 2008 9:45 am
For this, the folder structure is also important, because the deeper the structure the slower tht menu building. So we really could do it better (because for the WebDialog frames version we only need ONE folder scan).
azuby
azuby
Postby watkins » Sat Feb 16, 2008 12:33 pm
Dear TIG,
Do you think you could modify your script to include simple text documents? I ask because when I install a plugin which isn't supplied with a help/readme document (more recently a .pdf file), I create my own help/readme document by making a simple text file and then cutting and pasting any explanation posted with the ruby script. I now have quite a few of these 'readme' files and it would be really useful if I could access them from the Help drop-down menu.
Many thanks,
Bob
watkins
Postby Jim » Sat Feb 16, 2008 12:45 pm
I would go a step further and automatically parse out the header text from the script itself.
In fact would go even further and suggest authors adopt RDoc, or a similar embedded documentation scheme. RDoc is pure ruby, can be included in the Plugins folder, and creates nicely formatted documentation.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Edson » Sat Feb 16, 2008 3:03 pm
didier,
look what happened to your script on mac: there seems to be a problem as it does not see all i have and does not return anything. after this post i there is one on TIG version of the script, that appears to be working.
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby Edson » Sat Feb 16, 2008 3:08 pm
TIG,
this is what happened to your script on mac: it seems to be working fine.
Edson
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Sat Feb 16, 2008 7:14 pm
Edson wrote:TIG,
So Edson, you are saying that my version works OK ?
Note: the reason mine lists one more help-file than the other version is that it looks in all of the sub-folders in the Plugins folder and lists any it finds in there too...
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Sat Feb 16, 2008 7:23 pm
watkins wrote:Dear TIG,
Many thanks,
Bob
The problem is that many people add a .txt suffix to the end of the name of any scripts they don't want to have always loaded - they can 'load "script.txt"' through the Ruby Console later if needed. If the help script listed all .txt files these would come up in the list too. The formats that are found and listed are pdf htm html mht and doc - so you could make the txt files into doc ones ? OR you could make your help files end with a suffix .bob and set .bob files always to open with NotePad.exe; then edit the script and add ".bob" to the list of files it finds - easy to see how it works - and off you go...
Global Moderator
SketchUp version: 8
License type: Pro
Postby watkins » Sat Feb 16, 2008 10:58 pm
Dear TIG,
Many thanks for your helpful suggestions. I will give it a go.
Kind regards,
.bob
watkins
Postby watkins » Sat Feb 16, 2008 11:08 pm
Dear TIG,
I wrote before thinking (not unusual). I simply added "txt" to the list as I almost never load scripts using 'load "script.txt"' through the Ruby Console. This is a quick fix, although I should think about doing what you suggested in the future and loading little used scripts via the Ruby Console.
Kind regards.
.txt
watkins
Postby Edson » Sat Feb 16, 2008 11:11 pm
TIG wrote:So Edson, you are saying that my version works OK ?
yes, it seemed to work fine but i was unsure of it since i did not know whether the result i obtained was the one to be expected from the script or not. is it what you expected?
Edson
Global Moderator
SketchUp version: 8
License type: Pro
Postby watkins » Sat Feb 16, 2008 11:30 pm
Dear TIG,
Its me again (bad penny and all that).
Okay, adding .txt works fine, except that for long text files I can only see what will fit on the screen (no vertical scroll bars). I note that .pdf files open with scroll bars and so viewing them is just fine. I also have a lot of .txt files in my plugin folder and so when I try to select a file I can only view/select those that are visible in the text window. It would be useful if your script could be made to work like the Plugin drop-down menu, viz. the window opens and stays open with a single click and then items on the list are accessed (if required) using up/down arrows. This might be a useful feature anyway as users are likely to accumulate lots of .pdf help files with time.
Kind regards,
Bob
watkins
Postby TIG » Sun Feb 17, 2008 12:36 am
Yes - all is OK.
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Sun Feb 17, 2008 12:43 am
Kind regards,
Bob
Making the top bar menu list is what takes the time and slows down any model opening - and it's what we are trying to avoid... It's a limitation of the current Ruby dialogs that long lists go off the screen. However if you type the first character of the likely file's name e.g. W for Windowizer_help then the list will jump to that (or at least near that) and scrolling down is then possible... This applies to lots of Ruby dialogs like ones listing layers or colours. It could be done better with a web-dialog... but others have that expertise (and time) - perhaps someone can clobber 'my' getting the list of files into 'their' web-dialog and make it run as a superior form of dialog... before the Ruby dialogs themselves get improved (if ever)...
Global Moderator
SketchUp version: 8
License type: Pro
Postby watkins » Sun Feb 17, 2008 8:27 am
Dear TIG,
Once again, thanks for giving my enquiries your consideration.
Kind regards,
Bob
watkins
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Return to Plugins
Users browsing this forum: thach and 4 guests
