[Plugin] Automatic Face Reverser
Postby Didier Bur » Thu Jan 24, 2008 4:27 pm
Here is "yet another face reverser"...
This one tries to be automatic :ecstatic:
PDF doc included.
Enjoy,
Please get the latest version from the PluginStore
Download
5
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: Automatic Face Reverser
Postby Frederik » Thu Jan 24, 2008 4:39 pm
Didier, you're a true ruby-master..!! :D
Haven't tried if this works, yet - but if you've succeeded this will be helpfull to many... ;)
I remember back at the "old" SU forum, Todd was preparing a similar ruby for more than a year without success...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby CadFather » Thu Jan 24, 2008 5:24 pm
:o :shock: :mrgreen:
CadFather
PluginStore Author
PluginStore Author
Postby boofredlay » Thu Jan 24, 2008 9:19 pm
Thank you.
boofredlay
Global Moderator
Re: [Plugin] Automatic Face Reverser
Postby Dan » Wed May 28, 2008 5:51 pm
Thank you very much, Didier!
Much appreciated.
Very useful script.
Dan
Postby jim smith » Wed May 28, 2008 6:20 pm
Just wanted to add my thanks Didier - very handy tool to tidy up a model.
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
jim smith
Premium Member
Premium Member
Postby remus » Wed May 28, 2008 6:22 pm
have a :thumb: from me as wel, ive been using this ruby quite a lot recently.
remus
Postby ___olo » Thu Jun 12, 2008 3:11 pm
thanks you :ecstatic:
Xin chào nhau giữa con đường
Mùa xuân phía trước, miên trường phía sau
___olo
Postby digby dart » Sat Jun 14, 2008 4:08 am
This is a big time saver and a joy to use. Thank you very much. :D
digby dart
Postby pilou » Sat Jun 14, 2008 11:35 am
Tricky as usual! :thumb:
Speedy Galerie
Top SketchUcator
Postby arcano » Wed Jun 09, 2010 9:31 am
fantastic ruby ! Thanks a lot !
arcano
Postby TeKnoel » Thu Jun 10, 2010 8:33 pm
Wow! This is going to be great! :ecstatic:
TeKnoel
Postby SU Reviewer » Fri Jun 11, 2010 7:46 pm
This is definitely a useful plugin. But I noticed that if you already have textures applied to a face and then reverse the faces, the plugin reverses the texture as well. I realize that reversing the faces is the whole point of the plugin but is there a way to ignore it if a texture is present or move the texture to the new side (so it stays in the same location)?
Thanks for your hard work! :thumb:
Living Einstein's dream through SketchUp.
"Imagination is a preview of life's coming attractions" - Albert Einstein
Joe Simhon ~ SketchUp Plugin Reviews
SU Reviewer
Postby Didier Bur » Fri Jun 11, 2010 8:29 pm
Hi SUReviewer,
Good point. On the to-do list...
Didier Bur
Didier Bur
Postby Ruturaj » Sat Jun 12, 2010 6:23 pm
Hello,
yes this plugin is very useful....... :berserk:
Thank you Didier Bur :thumb: :thumb: :thumb:
Thanks,
Ruturaj
Thanks,
RuturaJ
Ruturaj
Postby honoluludesktop » Wed Nov 10, 2010 4:47 am
Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
honoluludesktop
In Remembrance
Postby lenova » Fri Aug 19, 2011 7:22 am
Thank you!
lenova
Postby orjinalp » Sun Jul 22, 2012 12:32 am
thanks...
orjinalp
Postby sijeljaaf » Sat Dec 08, 2012 2:05 pm
Thank you so much but it doesn't work with my sketchup pro 8
sijeljaaf
Postby TIG » Sat Dec 08, 2012 5:00 pm
sijeljaaf wrote:Thank you so much but it doesn't work with my sketchup pro 8
You have to explain how it doesn't work...
Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
Global Moderator
Postby JVT_LTD » Mon Dec 10, 2012 11:16 am
Many thanks to this... Its truly functional...
JVT_LTD
Postby unal » Wed Jan 23, 2013 11:02 am
teşekkürler:)
unal
Postby vaaron21 » Tue Jul 23, 2013 8:39 pm
It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
vaaron21
Postby Dave R » Wed Jul 24, 2013 12:32 am
vaaron21 wrote:It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
Global Moderator
Postby jorgesalros » Sat Dec 14, 2013 7:07 am
Works fine, well done
jorgesalros
Postby function » Wed Apr 16, 2014 6:25 pm
I'm not seeing the context menu in 2014... this plugin is great!
function
Postby baz » Tue Oct 07, 2014 11:34 pm
function wrote:I'm not seeing the context menu in 2014... this plugin is great!
Me too
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby Box » Tue Oct 07, 2014 11:58 pm
Baz, Didiers plugins haven't been updated to work with SU2014 but some of them can be fixed. This is one of them. It's a simple edit.
Tig explains how here.
viewtopic.php?f=323&t=12354&start=60#p513679
Postby TIG » Tue Nov 04, 2014 5:54 pm
Didier has agreed that I might update some of his Plugins available from the PluginStore...
Download
It is compatible with v2014 and v2015.
Global Moderator
Postby Emersonvip » Thu Mar 12, 2015 3:08 pm
thanks! very good. 5 stars.
Emersonvip
Next
Return to Plugins
Users browsing this forum: daica85 and 6 guests
