[Plugin] Qpik::SimpleRays v1.0.1
Postby Dan Rathbun » Sun Apr 21, 2013 12:04 am
    Qpik::SimpleRays
    Jakub Kupikowski (qpik) is not a programmer, so I overhauled
    his plugin so it can be removed from the Quarantine List.
    (For more info see old post: Ambient Occlusion -> Simple Rays.)
    BEFORE INSTALLING, DELETE the old file "simple_rays.rb"
    Qpik_SimpleRays_1_0_1.rbz
    v 1.0.1 : 2013-01-05
      Corrected @@lang assignment in language file rescue block.
        simple_rays.rb: lines 109 and 111
        @@lang == 'en' # just use English
        should be making an assignment:
        @@lang = 'en' # just use English
    See Developers forum: [Talk] Qpik::SimpleRays Overhaul
    Notes:
    • All code within the Qpik::SimpleRays namespace
    • No longer modifies Ruby nor API classes.
    • Now cleanups the temporary image files and dirs after itself.
    • Remembers inputbox entries during the session
    • commented out the purge all materials
    • multi-language
    What I did not do:
    • Re-write methods for optimization
    :ugeek:
      I'm not here much anymore. But a PM will fire email notifications.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Re: [Plugin] Qpik::SimpleRays v1.0.1
      Postby renderiza » Sun Apr 21, 2013 3:15 am
      Thank you so much for this!
      Maybe in the future if I learn enough I'll try to make a plugin with couple render features and Ambient Occlusion is really useful to have.
      Cheers!
      renderiza
      Premium Member
      Premium Member
      Postby Dan Rathbun » Sun Apr 21, 2013 4:10 am
      Renderiza wrote:Thank you so much for this!
      Well I only fixed it (proper namespacing, etc.)
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby unclex » Tue Apr 30, 2013 3:47 pm
        It's Wonderful
        but how to use it
        unclex
        Postby Dan Rathbun » Tue Apr 30, 2013 4:32 pm
        unclex wrote:... but how to use it
        For more info see old post: [Info] Ambient Occlusion -> Simple Rays.
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby masterpaul » Sun Jan 12, 2014 1:15 am
          If this works with texture.... omg.
          Edit1:
          Downloaded.. works well, one step closer to baked lightning in sketchup. However I wish I could bake the lightning on to textured surfaces. This plugin has the potential to be amazing.
          Ill run a few tests and post them here
          Edit 1:
          Plugin crashes a lot on 10/10 settings. On a light geometry model.
          Edit 2
          Well the plugin crashes on models other then simple boxes, it also has problems with curves. I guess it still needs a lot of work.
          masterpaul
          Postby Dan Rathbun » Sun Jan 12, 2014 9:36 pm
          It is really at the conceptual stage.
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby crafty1980 » Sat Jan 18, 2014 2:10 pm
            How do I install this? I've moved the rbz file into the plugins directory but nothing appears in the program? Is it not compatible with SU2013?
            crafty1980
            Postby Dan Rathbun » Sat Jan 18, 2014 7:58 pm
            crafty1980 wrote:How do I install this? I've moved the rbz file into the plugins directory but nothing appears in the program?
            RBZ is simply a zipped archive that has had it's extension renamed to rbz.
            What most people do is put them in a subdir of their downloads dir, named whatever you wish.
            Mine is "<user path>/downloads/SketchUp/plugins", but you name yours whatever you wish.
            Then to install semi-manually, you go to:
            Window (menu) > Preferences (dialog) > Extensions (panel)
            Then click the Install Extension ... button.
            A file broswer window opens. Browse to the location where you normally save your zipped plugins.
            Hilite the one to install.
            Click OK.
            SketchUp unzips the plugin into the current SketchUp version's normal plugin directory. (The location varies from platform to platform, and version to version. ie, slowly resources are bing migrated to reside within the User's %AppData% [Windows] or "Application Support" [Mac] paths so as to avoid access permission issues.)
            If you wish a more automated plugin experience,... install the SketchUcation Tools plugin manager, and install it via it's interface.
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby qpik » Tue Nov 18, 2014 6:55 pm
              I'm back. Any questions regarding the plugin are welcome.
              qpik
              Postby Dan Rathbun » Wed Nov 19, 2014 3:24 am
              Welcome back, Jakub !
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby tamic » Thu Jan 07, 2016 11:47 pm
                Hi Jakub and Dan,
                I'd like to try it. What sketchup versions is this plugin compatible with?
                I have installed it on 2016, and I can get only options context menu. No result anyway. How to fire an output image? Would it save somewhere onto hdd or display only in viewport? Best regards from Poland!
                tamic
                Postby qpik » Sun Apr 30, 2017 2:55 pm
                tamic
                I use it with SketchUp 7.0
                It saves new textures either in the folder your model is saved or in a temporary folder and then replaces materials in the model so you should see it right away
                I just started a similar project but using Blender https://sketchucation.com/forums/viewto ... 80&t=67569
                qpik
                Return to Plugins
                Users browsing this forum: Alice ta, ewanMJ, rebeccagyo and 20 guests
