[Plugin] GOSU v1.1.1
Postby renderiza » Fri Apr 19, 2013 4:51 am
Authors:: Renderiza
Plugin Name:: GOSU
Version:: 1.1.1
Date:: 10/21/2013
Cost:: Free
GOSU
Link components to websites, proxy, layers, scenes, sounds, files, and folders.
Instructions
1. Select Set:: Options and click any component
2. Select ::GOSU:: and click component to activate action
Available at
sketchUcation
Plugin Store
click here
______________________________________________________________________
Extension Warehouse
click here
Note: If the latest version is not yet available at Extension Warehouse that means it is still awaiting to be approved by the quality assurance team to make sure extension meets the technical and security requirements.
Web-Dialog
renderiza
Premium Member
Premium Member
Re: [Plugin] GOSU :: v1.0.0 Beta :: 4/19/2013 ::
Postby thomthom » Fri Apr 19, 2013 9:51 am
@gosu_1_file = Sketchup.find_support_file(@@rnd_gosu, @@path ) ;
Avoid this way of determining where the plugin is installed - it could be installed outside the Plugins folder. Read more here: http://www.thomthom.net/thoughts/2012/0 ... -anywhere/
PluginStore Author
PluginStore Author
Postby Burkhard » Fri Apr 19, 2013 11:18 am
Well done...thanks.
Burkhard
Premium Member
Premium Member
Postby renderiza » Fri Apr 19, 2013 11:26 am
thomthom wrote:@gosu_1_file = Sketchup.find_support_file(@@rnd_gosu, @@path ) ;
Thanks thomthom I did what you suggested so the plugin is portable friendly now. :thumb:
Burkhard wrote:Well done...thanks.
You welcome!
:mrgreen:
renderiza
Premium Member
Premium Member
Re: [Plugin] GOSU :: v1.0.1 Beta :: 4/19/2013 :: (New Update
Postby renderiza » Sat Apr 20, 2013 4:10 am
New Update!
1.0.1 Beta:: 4/19/2013
* Set:: SCENE - Allows you to set specific scene to any component.
* ::GOSU:: - Now recognize between URL & SCENES
Hi, I am excited to release this new update for ::GOSU:: and hope you like it!
This new tool called Set:: SCENE allows you to link any component to a scene so that when you click it the scene will activate. Hope you find cool uses for this that will help ypu modeling, showcasing and what not.
Here is New Video explaining the new feature...
And here is the old video just in case...
http://www.youtube.com/watch?v=5ZnhhHra7ac
Cheers!
renderiza
Premium Member
Premium Member
Re: [Plugin] GOSU :: v1.0.2 Beta :: 4/20/2013 :: (New Update
Postby renderiza » Sun Apr 21, 2013 3:03 am
New Update GOSU v1.0.2 Beta:: 4/20/2013
* Set :: Layer - Allows you to set a specific layer to any component.
* If ::GOSU:: is active and component have layer set to it that layer will be active.
* If ::GOSU:: is active and you double click component with layer set to it then that layer will be isolated on & off.
* Tool will be desactivated if 'Escape' key is pressed.
Hi, this new update add a Layer tool that will hopefully be useful to have.
Enjoy
renderiza
Premium Member
Premium Member
Re: [Plugin] GOSU :: v1.0.3 :: 4/22/2013 ::
Postby renderiza » Mon Apr 22, 2013 2:00 pm
GOSU v1.0.3 Released!
Please look at first post for details.
Cheers!
renderiza
Premium Member
Premium Member
Postby iichiversii » Mon Apr 22, 2013 5:29 pm
That is fantastic, I'm all over this already, Cheers R
Bring on the Rain...
iichiversii
Premium Member
Premium Member
Postby pilou » Mon Apr 22, 2013 5:51 pm
If I well understand (for a PC user) it's a simulation of Microsoft Windows system inside SU ? :)
An Windows UI 3D ? :idea:
Speedy Galerie
Top SketchUcator
Postby renderiza » Mon Apr 22, 2013 11:26 pm
iichiversii wrote:That is fantastic, I'm all over this already, Cheers R
I am happy that you are using this plugin "iichiversii"! :mrgreen:
Pilou wrote:If I well understand (for a PC user) it's a simulation of Microsoft Windows system inside SU ? :)
GOSU tries to integrate tools that are indeed often used by "Microsoft Windows system" I guess you can say.
For the Windows UI 3D I guess that you an simulate this experience by using the Set:Scene and create your own UI 3d navigation kind of system.
Thank you both for the comments...Cheers!
renderiza
Premium Member
Premium Member
Postby iichiversii » Tue Apr 23, 2013 12:46 am
R I'm very impressed with this and see alot of potentional in it, ideas are flowing, never would of taught of it myself, I applaud you on a great plugin, well done and look forward to updates, seriously, well done.
iichiversii
Premium Member
Premium Member
Postby renderiza » Tue Apr 23, 2013 1:21 am
iichiversii wrote:R I'm very impressed with this and see alot of potentional in it, ideas are flowing, never would of taught of it myself, I applaud you on a great plugin, well done and look forward to updates, seriously, well done.
Thanks its really nice to read compliments like that... :mrgreen:
New Video for GOSU v1.0.3
renderiza
Premium Member
Premium Member
Postby Litchi » Tue Apr 23, 2013 5:19 am
Thanks for your present!
I would like to know whether we can be completely removed my settings
“Pause”is just only pause
Thanks!
Litchi
Postby renderiza » Tue Apr 23, 2013 6:28 am
Litchi wrote:Thanks for your present!
Thanks!
Hi, thanks for your comment!
Let me see if I understood correctly...
You want a tool that removes the Set:: Options that you previously added, more like reset everything button?
or
You suggesting for the pause button to be removed?
Again thanks!
renderiza
Premium Member
Premium Member
Postby Litchi » Tue Apr 23, 2013 7:11 am
Thanks!
or
Again thanks!
I'm sorry,My English is not good……
I mean if we can add a new function "Reset",remove my settings(Can select all or selected components)
thanks! :D
Litchi
Postby renderiza » Tue Apr 23, 2013 8:22 am
Litchi wrote:I'm sorry,My English is not good……
thanks! :D
I got it now and don't worry English is not my 1rst language as well. :thumb:
This is what I have in mind for next update...
Clear:: Selected
Clear:: All
Will remove settings on all or selected components but before doing so a messege will pop asking "Are you sure?".
In the mean time just in case all of the setting values are stored on component is name. You can access that by opening "Entity Info" window. There you can manually remove it or you can use Set:: URL and erase the content there I believe.
Cheers!
renderiza
Premium Member
Premium Member
Postby Litchi » Tue Apr 23, 2013 9:14 am
thanks! :D
Clear:: Selected
Clear:: All
Cheers!
that's great,thanks!
I look forward to your new works!
Litchi
Re: [Plugin] GOSU :: v1.0.4 :: 4/22/2013 ::
Postby renderiza » Tue Apr 23, 2013 12:53 pm
GOSU v1.0.4 Released!
1.0.4:: 4/23/2013
*Set :: Name - Allows you to set a specific name to any component.
*Set :: Empty - Allows you to clear the name of any component.
*Reset Button - This will remove the 'Set:: Attributes' of every component
Again thanks for the comments & suggestions!
renderiza
Premium Member
Premium Member
Postby Litchi » Tue Apr 23, 2013 2:16 pm
Renderiza wrote:GOSU v1.0.4 Released!
1.0.4:: 4/23/2013
Thanks,Your work with remarkable efficiency!
Do you agree with me to reprint your files to other forums?
I promise I will retain the original URL and the name of the author
I want to share it with more people
Again thanks !
Litchi
Postby renderiza » Tue Apr 23, 2013 10:24 pm
Litchi wrote:Thanks,Your work with remarkable efficiency!
Again thanks !
I will be happy if you shared this with other people on other forums. :thumb:
renderiza
Premium Member
Premium Member
Postby TECHDAVE02 » Wed Apr 24, 2013 3:00 pm
Am I right that GOSU will only do 1 function at a time??
If so what about a right click sub menu to choose function???
My pause button is not working
rest works great so far.
TECHDAVE02
Postby renderiza » Wed Apr 24, 2013 11:59 pm
TECHDAVE02 wrote:Am I right that GOSU will only do 1 function at a time??
Gosu can do multiple functions in some cases since it uses the same component name for all "Set::" parameters. The "Set:: Scene" and "Set:: Layer" are the ones that can be repeated with another "Set::" option withoud any issues...Let me give you an example;
Example A
1. Set:: URL = http://www.sketchUcation.com
2. Set:: Scene = http://www.sketchUcation.com
3. Set:: Layer = http://www.sketchUcation.com
^^When you use ::Gosu:: it will active URL,Scene and Layer at the same time.
Example B
1. Set:: Sound = C:\Users\name\Desktop\folders\audio.wav
2. Set:: Scene = C:\Users\name\Desktop\folders\audio.wav
3. Set:: Layer = C:\Users\name\Desktop\folders\audio.wav
Note: Again notice how Set:: Scene & Set:: Layer can be combine with other "Set::" Options.
TECHDAVE02 wrote:If so what about a right click sub menu to choose function???
This is great idea I will try to add it on next version...thanks!
TECHDAVE02 wrote:My pause button is not working
What the Pause button is supposed to do is deactivate tool be leave the web dlg window instead to closing it like the close button do. If this does not work try hitting 'Esc' key or Select another tool like the Select tool. I will see if I can find the issue...thanks.
Cheers!
renderiza
Premium Member
Premium Member
Postby smicha » Thu Apr 25, 2013 6:15 pm
I just watched a video tutorial - your plugin is great!
smicha
Postby renderiza » Fri Apr 26, 2013 2:18 am
smicha wrote:I just watched a video tutorial - your plugin is great!
Thank you sir for does kind words! :thumb:
renderiza
Premium Member
Premium Member
Postby smicha » Fri Apr 26, 2013 11:15 am
Rafael,
I have a very very very big wish, and I think you can introduce it into your great plugin. This would speed up sketchup many many times. You are a very talented programmer, so I truly think/believe that you can do it :)
I may say in advance that I saw such a solution in a very famous 3d software :)
The point is: let's assume I have a component (or a group, it should apply to both, but components are more important to me) and let's assume that this components have 1 million polygons. Now lets assume I have 100 copies of this component. Yes - 100 millions polygons altogether (BTW it's not a problem for Octane Render using instancing with great TIG's plugin - see Octane forum). We all know how such geometry may affect speed of SU - orbiting, zooming can be a real nightmare. Now imagine I select one copy of a component, go to your plugin, choose a new option eg. "Set:: bounding box" and only bounding boxes (frames only) become visible. Just 12 edges of a bounding box instead of millions. We can assign a shortcut key like "alt+B" to turn on/off this option. And now orbiting, zooming, navigation would be so fast.
An extra option would be to give a user a choice to turn on/off bounding boxes on all of same components or on all but the selected one.
Tell me what you think and if the idea is clear to you and of course if it is possible to code?
Kind regards,
Sebastian
PS. I attach some screenshots with the idea.
1. Copies of a component.
2. First version of a plugin function - frames on each copy of a component.
3. Second version of a plugin function - frames on each copy of a component but not selected one.
smicha
Postby renderiza » Fri Apr 26, 2013 1:45 pm
::smicha::
Hi, very clear explanation! :thumb:
Here is a video for "Bounding Box View" Plugin found here... viewtopic.php?t=21427
smicha wrote:An extra option would be to give a user a choice to turn on/off bounding boxes on all of same components or on all but the selected one.
I have not tested "Bounding Box View" plugin yet to know if your suggested extra options is available but for the most part its pretty close to what you asked I think.
Tell me if that plugins was what you wanted if not maybe something else can be worked out.
Cheers!
renderiza
Premium Member
Premium Member
Postby smicha » Fri Apr 26, 2013 4:27 pm
It's almost it. But selecting one component and running the plugin should also change all other components without a need of selecting them. And an option to have one selected component visible and rest in a form of frames would be so useful.
Perfect solution (for me) would look like this: select a component, apply the plugin - frames on all components, apply it again - frames on all but selected, apply again - go back to an original view. And a dream :) is to assign one shortcut, eg. 'F6'.
What do you think Rafael?
smicha
Postby renderiza » Sat Apr 27, 2013 2:04 am
smicha wrote:It's almost it. But selecting one component and running the plugin should also change all other components without a need of selecting them. And an option to have one selected component visible and rest in a form of frames would be so useful.
Sounds like a plan! I will put this things on my to do list and hopefully make it happen in a reasonable amount of time. I like to realease simple scripts that solve just a few of your suggestions and then refine it by updates.
No promises since I have extra work but I think is a good idea so I will try.
This is done already just need to check few thing so I can release it.
Cheers
renderiza
Premium Member
Premium Member
Re: [Plugin] GOSU :: v1.0.5 :: 4/26/2013 ::
Postby renderiza » Sat Apr 27, 2013 2:56 am
GOSU v1.0.5 Released!
1.0.5:: 4/26/2013
* Right click sub menu to choose functions.
Cheers!
renderiza
Premium Member
Premium Member
Postby renderiza » Sat Apr 27, 2013 3:37 am
Hey I stumbled upon this ... viewtopic.php?f=180&t=21334
Please tell me what you think...cheers!
renderiza
Premium Member
Premium Member
Next
Return to Plugins
Users browsing this forum: dezmo, fadynm, greg24k, pluginjazz, stephanebo and 22 guests
