[Plugin]Extend Trim Faces.rb(Mar27,2013.)
Postby tak2hata » Wed Mar 27, 2013 3:59 pm
I upload Sketchup Plugin"Extend Trim Faces" to here.
Extend/Trim 2 Faces each other.
General disclaimer
I MAKES NO GUARANTEE OF VALIDITY about this script.
Please use this script at your own risk.
DONWLOAD:
Get the latest version from the PluginStore:
http://sketchucation.com/resources/plug ... Trim_Faces
or AutoInstall from within SketchUp using the SketchUcation Tools
Enjoy!
4
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]Extend Trim Faces.rb(Mar27,2013.)
Postby pilou » Wed Mar 27, 2013 4:59 pm
Seems a cool one! :enlight:
Speedy Galerie
Top SketchUcator
Postby pilou » Wed Mar 27, 2013 5:32 pm
First bug? ;)
Seems there is more and not the good trimed face ;)
Speedy Galerie
Top SketchUcator
Postby srx » Thu Mar 28, 2013 8:45 am
:thumb: This is very useful. Deserves shortcut! I'd like to assign the same shortcut to this function and to 2d adjust (from 2d tools) which is doing the same for lines. So, by selecting lines it is adjusting lines, by selecting edges and faces it is adjusting faces...Please!
www.saurus.rs
srx
Postby Pixero » Thu Mar 28, 2013 9:09 am
Thanks! :thumb:
Pixero
Postby srx » Thu Mar 28, 2013 11:45 am
Working great! Very SU-like concept. Thank you very much!
www.saurus.rs
srx
Postby TIG » Thu Mar 28, 2013 11:56 am
srx wrote::thumb: This is very useful. Deserves shortcut! I'd like to assign the same shortcut to this function and to 2d adjust (from 2d tools) which is doing the same for lines. So, by selecting lines it is adjusting lines, by selecting edges and faces it is adjusting faces...Please!
You can set your own shortcuts to any native OR loaded tool. Open Preferences > Shortcuts and filter the list to help you find the entry. Select it and set a key-combo... Provided that a tool has a menu entry it is shortcut-able...
Some tools only appear in the list if a 'context' is met.
So for example, if you want to shortcut the 'Reverse' tool that flips a face over [available in the context-menu if you have selected at least one face] you must have a face selected when you open Preferences > Shortcuts... then 'Reverse' is on the list... This is a very useful shortcut, as is 'Orient'...
Global Moderator
Postby rv1974 » Thu Mar 28, 2013 12:11 pm
great tool, tak2hata! It deserves shortcut :thumb:
Thank you.
P.S. Humble request: 'extend to the edge' feature
rv1974
Postby srx » Thu Mar 28, 2013 2:45 pm
TIG, thank you for this. I guess I was misunderstood because of my not so good English. I know how to set shortcut, already done it...but what I'd had in mind was to make 2dadjust from your 2dtools :) integrated with this 3d adjustment as one plugin. For now I have ALT+X for 2Dadjust, and SHIFT+X for this, say "3Dadjust". But it would be more effective to have it under one shortcut, and the action would smartly depend on what is selected - 2D adjust for selected 2D elements (lines), 3D adjust for selected 3D elements (faces). Now when I think they are 1D and 2D elements, what we are missing is 3D adjust (maybe from Didiers Projections plugin) for adjusting solids. :)
www.saurus.rs
srx
Postby sumaster » Thu Mar 28, 2013 8:35 pm
HI tak2hata sir,
again great tool you build NICE work . . . .
THANK YOU,
Thank you,
SUmaster
sumaster
Postby Elibjr » Sat Mar 30, 2013 11:08 pm
Wow Thanks! it's like doing 2D CAD in 3d. This should be in the base commands! Extremely useful!
Elibjr
Premium Member
Premium Member
Postby simon le bon » Sun Mar 31, 2013 12:19 am
Simple and useful.
"Very SU-like concept" -> +1
another nice one.
downloaded.
thank you a lot Tak2Hata
++simon
simon le bon
Postby jpalm32 » Sun Mar 31, 2013 2:30 pm
Nice. This should help will fix my screw ups.
jpalm32
Premium Member
Premium Member
Postby Kiey » Sun Mar 31, 2013 3:50 pm
Great tool, it's useful.
Kiey
Postby Trogluddite » Sun Mar 31, 2013 11:32 pm
Very nice plugin :D
I think, this will save me much time messing around with construction lines and the protactor tools.
Many Thanks.
Trogluddite
PluginStore Author
PluginStore Author
Postby designforgood » Mon Apr 01, 2013 10:30 pm
This looks to be a very helpful plugin. Thank you tak2hata!
designforgood
Postby dem » Tue Apr 02, 2013 6:07 pm
Thanks! Great plugin! But one nuance. Does not always get on the right plane when I click near the edge. Is it difficult to make the backlight of planes when cursor is on the small distance near the edge?)
dem
Postby tak2hata » Sun Apr 28, 2013 3:47 am
dem wrote:Thanks! Great plugin! But one nuance. Does not always get on the right plane when I click near the edge. Is it difficult to make the backlight of planes when cursor is on the small distance near the edge?)
Hi,dem.
I think it difficult.
But I want it, too.
I will consider it well.
Thanks All!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby ishining » Wed Feb 05, 2014 3:06 pm
very easy to use, thks
ishining
Postby rv1974 » Thu Apr 17, 2014 9:55 am
tak2hata, is it possible to add those standard SU\Acad selection options:
with Shift- select additional areas to be stretched
with Alt- DEselect affected areas
with Cnrl- precisely select or deselect (Cnrl+Alt) separate points.
Thanks.
rv1974
Postby Ben Ritter » Thu Apr 17, 2014 2:47 pm
Awesome. Thank you again for sharing the fruits of your talent.
Ben Ritter
Postby sumaster » Tue Sep 23, 2014 6:00 pm
I am using this plugin every day and I have some difficulty in a single selection. Each edge select and click one surface, it's wasting modeling time can you change single click to multiple edges selection or viewport selections. . . .
Thank you,
SUmaster
sumaster
Postby JQL » Tue Sep 23, 2014 7:01 pm
SU master you could do that easily with the move tool on the very selection you have. Why don't you try?
JQL
Premium Member
Premium Member
Postby sumaster » Tue Sep 23, 2014 7:34 pm
Hello JQL,
Yes, you are right. But when you find a triangular shape wall.
And when I move current selections, then the result is below. . .
But I want this result. . . . .
Thank you,
SUmaster
sumaster
Postby pbacot » Tue Sep 23, 2014 7:47 pm
Yes, that is only an example. And what if some of the faces to be moved are not aligned with others? The move function wouldn't help speed things up. I could see how this would be helpful. This tool looks to be a more specific version of some of the TIG's Extrusion tools ( extrude edges to face), which can move multiple disconnected edges. Some version of either of these tools really belongs in the basic SU toolbox.
Top SketchUcator
Postby TIG » Wed Sep 24, 2014 10:45 am
My snappily named 'ExtrudeEdgesByVectorToObject' would take all of the selected edges and moved their vertices along a picked vector stopping at the end of the vector OR the first face[s] that were met it the vector passes through some intervening object[s]...
http://sketchucation.com/pluginstore?pln=ExtrudeTools
http://sketchucation.com/plugin/1103-extrudetools for feedback link...
See near the end of the movie of an example of its simpler sibling 'ExtrudeEdgesByVector'...
3
Global Moderator
Postby sumaster » Fri Jan 23, 2015 7:02 pm
yes TIG sir right i use this but when ExtrudeEdgesByVectorToObject complete operation extruded edge loop not fill means not create face
Thank you,
SUmaster
sumaster
Return to Plugins
Users browsing this forum: adriancba, ob0653 and 11 guests
