by tak2hata » Wed Mar 20, 2013 3:08 pm
Hi,All. I create a fly through plugin. Let's fly as a bird in sketchup. General disclaimer I MAKES NO GUARANTEE OF VALIDITY about this script. Please use this script at your own risk. DONWLOAD: Get the latest version from the PluginStore: http://sketchucation.com/resources/plug ... flythroughor AutoInstall from within SketchUp using the SketchUcation Toolsversion1.0 UPDATE:Mar21,2013. BUGFIX:Default value of "SPEED" was too small. BUGFIX:Could not hit [TAB] on Mac.so it replaced by[OPTION]key. IMPROVE:"Look around" and "Move" works simultaneously.
Version1.2 UPDATE:Mar23,2013. IMPROVE:Changing "SPEED" is placed in Context Menu. IMPROVE:"Look around" and "Move" works more simultaneously.
Version1.21 UPDATE:Mar24,2013. Add code "require 'sketchup.rb'"
Version1.4.0 UPDATE:Feb27,2014. small improve.Toggle Look around mode by one clicking.
- [Arrow] keys to Move.
- Drag mouse L button to Look Around.
- [Home] Key to UP(Windows)
- [End] key to DOWN(Windows)
- "[" key to UP(MAC)
- "]" key to DOWN(MAC)
- Press "SHIFT" key to Move fast.
- Context Menu to change SPEED value.
Latest Version:
----------- by TAK2HATA
tak2hata
- PluginStore Author
- Name: tak2hata
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
by mwm5053 » Wed Mar 20, 2013 4:32 pm
WOW thats's cool thanks
2011 iMac SU 2015 Pro, 2017 Make V2 Twilight macOS Sierra 10.12.5
mwm5053
- Premium Member
- Name: Walt M
- Operating system: Mac
- SketchUp version: 2014
- License type: Pro
- SketchUp use: hobby
by dtrarch » Wed Mar 20, 2013 5:11 pm
Tak2 Thanks and fun too. dtr
dtrarch
- Premium Member
by mwm5053 » Wed Mar 20, 2013 6:20 pm
Not Mac ready keys won't work.
mwm5053
- Premium Member
- Name: Walt M
- License type: Pro
by baldaman » Wed Mar 20, 2013 7:12 pm
Domo aligatou gozaimasu tak2hata ruby sensei!
baldaman
by small08 » Wed Mar 20, 2013 11:03 pm
Will try, thank-you!
small08
- Name: small08
by tak2hata » Thu Mar 21, 2013 4:23 pm
Hi,All. I update this to ver1.1 on Mar 21,2013.
Enjoy Flying. Thanks!
tak2hata
- Name: tak2hata
- License type: Pro
by Oxer » Thu Mar 21, 2013 10:23 pm
Hi, On Mac there is an error, you have to change the "." sign for the "," in flylenght, so it'll works fine. In ruby file lines 71 to 75:
"def initialize @flylength = 0,2.m a = Sketchup.read_default("TAK2_FLYTHROUGH","FLYLENGTH","0,2m") @flylength = a.to_l if a #@flylength = 0,2.m @lbtndn = false @cxy = [ 0,0 ] reset"
Another problem on Mac is that you obtain "[" "]" pushing "Option (Alt) +`" and "Option (Alt) ++" if you have assigned on Mac the Option (Alt) key to change the Speed, I can't use Up and Down.
Oxer
- Name: Oscar
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: illustration, cartoons
- Level of SketchUp: Advanced
by Box » Fri Mar 22, 2013 1:52 am
Oxer I don't think that's a mac error as such.
The "." "," issue is generally due to the global settings of your computer, whether it be PC or Mac. I imagine as you are from Spain you have your Mac using the common European system which uses the "," for example 2,5Deg Celsius, whereas a standard English based set up would write it as 2.5Deg Celsius.
Anyway, it's an unfortunate annoyance for all those who have the system set the "wrong way". Feel free to give me a slap if this has nothing to do with your problem.
- Name: Box
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
by Oxer » Fri Mar 22, 2013 2:52 am
Thanks for your answer, it's possible that the problem were in the metric units. Is there a solution for the "[" "]" signs on Mac?
Oxer
- Name: Oscar
by tak2hata » Fri Mar 22, 2013 4:48 am
Hi,Oxer and Box. Your advices are useful infomation. I will correct it later.
Thanks.
tak2hata
- Name: tak2hata
- License type: Pro
by tak2hata » Sat Mar 23, 2013 7:48 am
Hi,All. I update this to Ver 1.2 in Mar 23,2013. Changing SPEED is placed in context menu.
Thanks.
tak2hata
- Name: tak2hata
- License type: Pro
by Kiey » Tue Feb 18, 2014 6:27 pm
This plug-in is useful while in draw/edit objects, could it possble effect when I draw something or move something. just like autocad's Transparent command ?
Kiey
- Name: Kiey
- License type: Pro
by tak2hata » Thu Feb 27, 2014 4:00 pm
Hi,All. I update this to v1.4.0. small improve. Thanks.
tak2hata
- Name: tak2hata
- License type: Pro
by rogerionemesis » Thu Feb 27, 2014 7:07 pm
tak2hata wrote:Hi,All. I update this to v1.4.0. small improve. Thanks.
Thank you. The mouse single click makes it reallllly better.
rogerionemesis
- Name: Rogério Ferreira
- SketchUp version: 2013
- License type: Pro
by tspco » Sun Mar 02, 2014 8:46 pm
I tried this today, it worked well, but I have a suggestion, any way to ass a maintain camera height, say from the native su camera eye height? I do terrains a lot and it would be real cool to not look at the underside when moving across it. Floating Camera has this function, but the rest of the plugin has issues. Thanks Ryan
SU make 2017, /Twilight Render Hobby Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
tspco
- Name: Ryan
by tak2hata » Tue Mar 04, 2014 3:05 pm
tspco wrote:I tried this today, it worked well, but I have a suggestion, any way to ass a maintain camera height, say from the native su camera eye height? I do terrains a lot and it would be real cool to not look at the underside when moving across it. Floating Camera has this function, but the rest of the plugin has issues. Thanks Ryan
Hi,Ryan. I guess from your suggestion. Is it walk tool of sketchup? Or,Flying and collision with land and no gravity? Thanks!
tak2hata
- Name: tak2hata
- License type: Pro
by JClements » Mon Jun 02, 2014 5:51 pm
I downloaded and installed today. Running SU2014, Windows 7. END key did not move down (or any direction). SHIFT key did not appear to move faster.
John Illustrator Beaverton, Oregon
JClements
- Premium Member
- Name: JClements
- SketchUp version: 2016
- License type: Pro
- SketchUp use: engineering and mechanical design
- Robot
Return to Plugins
