[Plugin] Projection Builder
Postby monkeybanjo » Thu Feb 28, 2013 11:53 am
Description
Builds a top, front and side projection from a model and arranges them onto a single plane for easy dimensioning and printing. The current version of the plugin only builds the projection from edges, not on groups/components. This means that groups need to be exploded before a projection can be built. Typically, I use my "Recursive Explode" plugin which I also uploaded to explode all groups and subgroups before creating a projection.
Installation
The zip file attatched should be unzipped into the plugins directory
How to Use
Simply select something, and then choose the Tools > Build Projection menu option.
Cheers,
Dave
monkeybanjo
Re: [Plugin] Projection Builder
Postby gilles » Thu Feb 28, 2013 12:44 pm
Is this different or better than TIG's Flatten to plane?
http://sketchucation.com/forums/viewtopic.php?f=323&t=31895#p281320
gilles
Top SketchUcator
Postby monkeybanjo » Thu Feb 28, 2013 1:17 pm
Not sure, I'll check it out, thanks :-)
monkeybanjo
Postby Archtiex » Tue Nov 11, 2014 4:47 am
Thanks.. but are you trying to get closer to RHINO MAKE 2D command??
If you work a litle bit more, you gone win on this. I which you could add choose layers when projection are done, because it is very dificult to diference VIEW LINES from a CUT Line. And try to get better performance, because i try it on a small example and it took like 1 minuto do complete. (and i have a great machine workstation and SU 2015 x64bits)
Archtiex
Return to Plugins
Users browsing this forum: No registered users and 15 guests
