Multiple Leader Lines for Single Text String
Postby plesiosaur » Fri Feb 22, 2013 10:02 pm
I am looking for plugin that creates multiple leader lines for a single line of text e.g.
I have an exploded view with numerous parts, some of which are am iteration of the same part, I want to use one text entry with multiple leaders pointing the different iterations of the same part. Any suggestions? Thanks.
User avatar
plesiosaur
Premium Member
Premium Member
Re: Multiple Leader Lines for Single Text String
Postby jeff hammond » Fri Feb 22, 2013 11:46 pm
kind of cheesy but i do it like this..
one text entry is what you want it to say..
the other text entry is a period which is positioned to overlap the 'T'..
maybe make the first two characters of each leader the same and try to line those up
meh..
User avatar
Global Moderator
Postby fredo6 » Fri Feb 22, 2013 11:55 pm
You may try to have a look at FredoTools::ReportLabelArea which has this capability.
Labels are created with the area of the elements selected but you are free to replace the text and move the anchors and text label by click and drag.
User avatar
PluginStore Author
PluginStore Author
Postby jeff hammond » Sat Feb 23, 2013 12:03 am
Fredo6 wrote:You may try to have a look at FredoTools::ReportLabelArea which has this capability.
:shock:
you need a marketing department
not sure how i happened to miss this one..
User avatar
Global Moderator
Postby nickchun » Sat Feb 23, 2013 12:37 am
Jeff Hammond wrote:not sure how i happened to miss this one.
Likewise. I guess I wouldn't have looked for it under the Label Reporting title. You can also do it using Copy in Place but can't remember quite how. There is a mini tut on another site under 'tips and tricks' I think, but it can be fiddly. Fredo's solution looks easier.
nickchun
Postby plesiosaur » Sat Feb 23, 2013 12:51 am
Thanks all, I use FredoTools as well but never thought to look there. Thanks again
User avatar
plesiosaur
Premium Member
Premium Member
Postby plesiosaur » Sat Feb 23, 2013 1:27 am
One note on Fredo Tools mentioned above: Be sure that the leader line format in the model info setting, Text>Leader Lines, the leader style must be set to Pushpin; if it is View Based you will get adverse results.
User avatar
plesiosaur
Premium Member
Premium Member
Postby fredo6 » Sat Feb 23, 2013 7:46 am
plesiosaur wrote:One note on Fredo Tools mentioned above: Be sure that the leader line format in the model info setting, Text>Leader Lines, the leader style must be set to Pushpin; if it is View Based you will get adverse results.
If you wish to move the labels, either anchors or text part, just do it with ReportLabelArea, not with the native SU Tool.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Chociej, marex05, parsifal and 6 guests
Visit our sponsors:
