[Plugin]Draw Slope Normals.rb-v1.4-Mar 28,2013.
Postby tak2hata » Sun Feb 10, 2013 8:11 am
Hi,All.
I create the managing tool for slopes like Site.
Name:Draw Slope Normals.rb
DOWNLOAD HERE:
Get the latest version from the PluginStore:
http://sketchucation.com/resources/plug ... pe_normals
or AutoInstall from within SketchUp using the SketchUcation Tools
update_v1.0b:Feb 13,2013:I correct mistake of dividing z value of curve.
Update_v1.1:Feb 19,2013:Improves_ for 000additionalpluginfolder.
update_v1.3:Mar 09,2013:Add tool bar.and small improve.
update v1.31:Mar 2,2013:Add code "require 'sketchup.rb'
update v1.4:Mar 28,2013:Bugfix.(Error with the vector(0,0,0) is exists.)
General disclaimer
I MAKES NO GUARANTEE OF VALIDITY about this script.
Please use this script at your own risk.
Enjoy!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]Draw Slope Normals.rb-v1.0a-Feb 10,2013.
Postby guanjin » Sun Feb 10, 2013 3:51 pm
Great, thank you! :fecstatic: :fecstatic: :thumb: :thumb:
I come from China, is to learn
guanjin
Postby sawaken » Sun Feb 10, 2013 4:54 pm
おお いつもありがとうございます。
sawaken
Postby antoniogulino » Mon Feb 11, 2013 12:10 am
Thank you very much for this new awesome plugin!
antoniogulino
Postby srx » Mon Feb 11, 2013 12:03 pm
:enlight:
I think it will be very helpful. Thanks a lot!
www.saurus.rs
srx
Postby dtrarch » Mon Feb 11, 2013 10:05 pm
OMG
Tak2 what a killer app :family: and just perfect for concept work when no 3d topo data is available.
A true "Sketch" tool and JF'n brilliant. :enlight:
WOW
Thank you so very much.
Hope things in Japan are better for all now. :thumb:
dtr
dtrarch
Premium Member
Premium Member
Postby seasdes » Mon Feb 11, 2013 11:15 pm
A trully awsome plugin that will be usefull to many thay need to model terrain.
Walter
Using Sketchup Pro 2019
seasdes
Postby pilou » Tue Feb 12, 2013 1:04 am
A new hit ? :enlight:
Speedy Galerie
Top SketchUcator
Postby Chris Fullmer » Tue Feb 12, 2013 1:20 am
This looks great! I hope I get a chance to use it soon, thanks!
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Re: [Plugin]Draw Slope Normals.rb-v1.0b-Feb 13,2013.
Postby tak2hata » Tue Feb 12, 2013 5:30 pm
I 'm sorry.I made mistake.
So I update this script to version 1.0b.in Feb 13,2013.
Now it calculate the dividing z value of curve from XY distance between vertices.
The previous version did from XYZ distance.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby unclex » Tue Feb 12, 2013 7:14 pm
it's wonderful
unclex
Postby dtrarch » Tue Feb 12, 2013 8:10 pm
Tak2
Sure would be nice to have the options rt click contextual once the script has been started. :idea:
Any chance please.
dtr
dtrarch
Premium Member
Premium Member
Postby Aureus » Tue Feb 19, 2013 4:38 am
Does anyone know why this happens?
[b]^Error Loading File draw_slope_normals.rb
private method `gsub!' called for nil:NilClass
Is this a plugin for Sketchup 7 or 8? I have both. S7 doesn't recognize it and S8 reports this error. I put it into the folder 'Plugin' after unzipping it. The folder 'draw_slope_normals_v1.0b' went to the folder Plugin but still doesn't work. I tried to put the sole RB file 'draw_slope_normals.rb' but nothing happened.
I use Windows XP S3.
Sorry for asking this but usually creators of plugins usually post these small accompanying instructions themselves. :)
Cheers to everybody.
Aureus
Re: [Plugin]Draw Slope Normals.rb-v1.1-Feb 19,2013.
Postby tak2hata » Tue Feb 19, 2013 9:45 am
Hi,i update this to version1.1.
This will work in additional plugin folder.
Hi,dtrarch.
I add context menu when tool is active.
Hi,Aureus.
I modified by replacing "gsub!" to "File.expand_path".
I did not test it on mac os,yet.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Aureus » Tue Feb 19, 2013 10:32 am
Thank you, tak2hata.
I haven't expected such a quick reply to my first question and post ever on this site.
It seems you did performed necessary corrections my case requested as I was perfectly able to install 1.1 version of your plugin. Now I'll give it a go and see what'll happen. At the moment I'm modeling a river bank and I hope 'Draw Slope Normals' will turn into a very handy tool. ;)
P.S. It's good that keyboard shortcuts can be given to the commands.
Greetings from Bosnia.
Aureus
Postby dtrarch » Tue Feb 19, 2013 7:02 pm
Tak
Breakthrough plugin IMO and thanks again.
You are truly the Miyamoto Musashi of code.
Dave
aka dtrarch
-1
dtrarch
Premium Member
Premium Member
Postby Ben Ritter » Tue Feb 19, 2013 7:50 pm
Thank you for your generosity.
Ben Ritter
Postby Mra » Fri Feb 22, 2013 4:36 am
Thank you x1000000000000000000000000000000000000000
This is much needed in sketchup and for you to share with the community is so nice. Levels in SketchUp wohoo!
Mra
Postby Aureus » Fri Feb 22, 2013 10:24 am
What kind of logic is applied for indicating z value?
When I have the cursor over a single spot (the end of a line) the z value is displayed and everything seems fine. But when the cursor is over a line sometimes lower value is displayed and sometimes higher - or in other words, once indicating the value of lower end and on other occasion on some other line indicating the value of its higher end.
So far I couldn't figure out what value is indicated when having the cursor over a face and in what relation it is to actual values of its edges.
When you have a line with 2 ends one having z value of 1.7 and the other having z value of 1.9, whatever figure is displayed (1.7 or 1.9) for it when you write down a new value (say 1.5) both ends have that new and same value, putting your line in horizontal position.
It seems this plugin has no respect to the groups as you can edit a group 'from outside'.
At the end I have one actual proposal. When you undo a step (you are not satisfied with the result of just put z value) - you are out of the command. Then you must run the plugin again. Can you make it provide you stay in the current command when you undo a step? My opinion is that it would speed up your workflow since it's a bit annoying and time-consuming starting the plugin again over and over after undoes.
Aureus
Re: [Plugin]Draw Slope Normals.rb-v1.3-Mar 09,2013.
Postby tak2hata » Sat Mar 09, 2013 2:28 pm
I update this to version1.3 in Mar 09,2013.
Add Toolbar.
and small improve.
Hi,Aureus.
The logic of modifying Z value is simple.
If you click Vertex it change z value of that vertex.
If you click Edge it changes z value of the vertices connencted to that edge.
If you click Face it changes z value of the vertices connencted to that face.
When the same positon of vertices clicked,The vertex in active_ editing group/component is preferred.
But the vertices are not same position,the vertex that near to camera is preferred.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby mizar » Tue Mar 19, 2013 3:12 pm
it's wonderful
Thanks a lot
mizar
Postby Lillioso » Sat Mar 23, 2013 1:01 pm
I get this error when i startup Sketchup, and the Plugin wont load.
What am I doing wrong?
Lillioso
Postby tak2hata » Sun Mar 24, 2013 7:38 am
Lillioso wrote:I get this error when i startup Sketchup, and the Plugin wont load.
Hi,Lillioso.
I mistook about that "file_loaded".
It needs "require 'sketchup.rb' for first time.
I add the code,now in ver 1.31.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]Draw Slope Normals.rb-v1.31-Mar 24,2013.
Postby rv1974 » Sun Mar 24, 2013 9:20 am
There's some problem on 1.15- The arcs will be distorted (from plan point iof view).
rv1974
Postby tak2hata » Wed Mar 27, 2013 4:03 pm
rv1974 wrote:There's some problem on 1.15- The arcs will be distorted (from plan point iof view).
Hi,rv1974.
Watch this.Arc is not distorted in TOP View.
Please upload the picture or model that included "distorted arc."
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]Draw Slope Normals.rb-v1.4-Mar 28,2013.
Postby pbacot » Wed Mar 27, 2013 5:37 pm
That's SPECIAL Tak2hata!
Thanks!
Top SketchUcator
Postby rv1974 » Thu Mar 28, 2013 8:48 am
Tak2hata-san, I tested it in deep and this tool indeed keeps the plan outline. This is
AMAZING! :o
About your last video: I played with the similar shape and the result was a bit distant from 100% perfect (the left example); then I reshaped the curves with Fredo's skinning
(the right example) and it was closer to the desired. Could you take a closer look at this issue?
REALLY Thank you!
Offtop: yesterday I watched 'Jiro Dreams of Sushi' documentary. There are epic people in Japan!
rv1974
Postby tak2hata » Sun Apr 28, 2013 3:56 am
rv1974 wrote:Tak2hata-san, I tested it in deep and this tool indeed keeps the plan outline. This is
AMAZING! :o
REALLY Thank you!
Hi,rv1974.
Folding is works with Sketchup default function.
Freado' Skinning is smoother function.
I will connect to the skinning when fredo lib is loaded.
Offtop:Jiro's Sushi is expensive!I want to eat that!There is Great Sprits for Sushi!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby orchard collie » Thu Aug 22, 2013 11:52 pm
Hi TAK2HATA
I'm using SketchUp 2013 Pro on Mac OSX 10.8.4 - downloaded the plugin and unzipped it into the Plugins Folder.
Opened SketchUp went to Preferences - Extensions - Install extension - located the folder', opened it but could not select the draw slope normals.rb file to install it.
Any ideas what my problem is, apart from stupidity?
Cheers
orchard collie
Postby tak2hata » Sat Aug 24, 2013 8:21 am
orchard collie wrote:Hi TAK2HATA
Cheers
Hi,orchard.
Installing plugin was completed when you unzipped it into the Plugins Folder.
In case of installing from "*.rbz" file,
"Install Extension" in Preference menu works.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: arqmelanie, bengpin, bonal78 and 17 guests
