[Plugin] fixSolid v1.7 - updated 20/10/2012  Topic is solved
Postby GWD » Fri Dec 17, 2010 11:34 am
This Plugin try to fix problems with groups that suppose to be solids but don't show up like a solid in SU.
fixSolid fix the following problems:
* heal missing faces
* remove single edges
* remove separate faces
* remove edges between coplanar faces
* remove innerfaces
* remove all edges with only 1 face connected (RISKY FIX)
Usage:
1. Select solid
2. Right-Click Context-Menu. If the solid is broken the option 'FIX SOLID' is present. If the option isn't present there are no problems with he solid.
3. Select 'FIX SOLID'
4. You can set two options:
- Risky fix: if you choose a risky fix it's possible that a part of the solid wil be deleted. This action can be undone with the normal SU undo function. The risky fix try to fix all problems, the normal fix only fixes problems with no risk.
- Fix coplanar faces: If you choose no, the edges between coplanar will not be removed.
NOTE:
A newer version [posted under the OP's new login] is available here...
viewtopic.php?p=436001#p436001
GWD
PluginStore Author
PluginStore Author
Re: [plugin] fixSolid v1.3 - updated 19/12/2010
Postby GWD » Sun Dec 19, 2010 12:41 pm
No feedback?
GWD
PluginStore Author
PluginStore Author
Re: [plugin] fixSolid v1.3b - updated 19/12/2010
Postby thomthom » Sun Dec 19, 2010 1:18 pm
Nice plugin. :thumb:
Got a couple of notes:
1. It's advisable to wrap your plugin into a module and use module variables instead of global variables - this ensures there will be no conflict with other plugins.
2. Detecting edges between co-planar faces: You are using this: if faces[0].normal == faces[1].normal then
I used that for CleanUp, but I ran into issues where it's either erase edges between non-coplanar faces or leave some edges that should have been erased in some cases. As it turns out, the correct way - according to the Googler I spoke to - is to take all the vertices of the two faces you compare and check if they all lie on the same plane.
3. e.typename == "Edge" - .typename is very slow because you do string comparisons. Instead, compare it's class: e.is_a?( SketchUp::Edge )
PluginStore Author
PluginStore Author
Postby driven » Sun Dec 19, 2010 2:00 pm
hi Guy,
I'll give it a try...
it's good to see another solid/manifold ruby
over the next week I should get some time to give you feedback, I'm on a mac so sometimes I have varying results to pc's
john
driven
PluginStore Author
PluginStore Author
Postby EscapeArtist » Sun Dec 19, 2010 9:41 pm
Looks like a good plugin. Will give it a try as it progresses with TT's suggestions.
EscapeArtist
Top SketchUcator
Postby vidy » Sun Dec 19, 2010 10:28 pm
thanks Guy, for the plugin, but is it only for SU 8?? can not see it in the plugin menu? im using SU 7.1
regards,
still so much to learn..
vidy
Postby Pherim » Sun Dec 19, 2010 10:39 pm
That's because solids had not been included in SU 7 and are only available since SU 8.
Pherim
Postby thomthom » Sun Dec 19, 2010 11:33 pm
Pherim wrote:That's because solids had not been included in SU 7 and are only available since SU 8.
Should be able to work anyway. There is not difference in the geometry, it's just that SU8 knows how to recognize solids.
PluginStore Author
PluginStore Author
Postby GWD » Mon Dec 20, 2010 1:33 am
The plugin works only on SU 8, because the function i use the check if it's a solid is a new function in v8.
GWD
PluginStore Author
PluginStore Author
Postby GWD » Mon Dec 20, 2010 3:32 am
thomthom wrote:Nice plugin. :thumb:
ThomThom,
1. How can i wrap my plugin in a module?
2. OK -> v1.4
3. I tried to switch .typename == "Edge" but then I get errors, i also can't find info about the .is_a? function?
regards,
Guy
GWD
PluginStore Author
PluginStore Author
Postby derei » Mon Dec 20, 2010 4:39 am
GWydouw wrote:3.can't find info about the .is_a? function?
http://ruby-doc.org/core/classes/Object.html#M000373 -first result after search on google :mrgreen:
DESIGNER AND ARTIST DEREI.UK
derei
Postby thomthom » Mon Dec 20, 2010 7:59 am
GWydouw wrote:3. e.typename == "Edge" - .typename is very slow because you do string comparisons. Instead, compare it's class: e.is_a?( SketchUp::Edge )
[/quote]
What kind of error and what did you switch to?
As for modules:
http://ruby-doc.org/docs/ProgrammingRub ... dules.html
viewtopic.php?f=180&t=12423#p89313
Many other useful links in this sticky at the Developers section:
viewtopic.php?f=180&t=10142
PluginStore Author
PluginStore Author
Postby GWD » Mon Dec 20, 2010 8:39 am
thomthom wrote:3. e.typename == "Edge" - .typename is very slow because you do string comparisons. Instead, compare it's class: e.is_a?( SketchUp::Edge )
As for modules:
http://forums.sketchucation.com/viewtop ... 423#p89313
http://forums.sketchucation.com/viewtop ... 80&t=10142
ThomThom,
The module works, but when I recplace the .typename with the .is_a? I get the following error:
Error: #<NameError: uninitialized constant FixSolids::SketchUp>
(eval):373
(eval):318:in `call'
(eval):318
regards,
Guy
NOTE:
GWD
PluginStore Author
PluginStore Author
Re: [plugin] fixSolid v1.4 - updated 20/12/2010
Postby thomthom » Mon Dec 20, 2010 9:10 am
Sorry - I made a typo. It's Sketchup - not SketchUp - the thing is case sensitive.
PluginStore Author
PluginStore Author
Postby thomthom » Mon Dec 20, 2010 9:11 am
Btw, here's some stats to how slow .typename is compared to .is_a? viewtopic.php?f=180&t=19576&view=unread#p162235
In case you where curious.
PluginStore Author
PluginStore Author
Postby GWD » Mon Dec 20, 2010 9:29 am
thomthom wrote:Sorry - I made a typo. It's Sketchup - not SketchUp - the thing is case sensitive.
Thanks!
GWD
PluginStore Author
PluginStore Author
Postby vidy » Tue Dec 21, 2010 3:38 am
GWydouw wrote:The plugin works only on SU 8, because the function i use the check if it's a solid is a new function in v8.
thanks for your confirmation :)
vidy
Re: [plugin] fixSolid v1.5 - updated 20/12/2010
Postby kobus » Tue Dec 21, 2010 7:50 am
respect ! where thomthoms inspector was heading I presume.
you should be interested in the future. you will spend the rest of your life there
kobus
Postby thomthom » Tue Dec 21, 2010 8:23 am
You could use the method I use with Solid Inspector - check that all edges have two faces connected. Then it'd work on older versions. Of course for SU8 and newer you want to use the built in version that's very quick.
PluginStore Author
PluginStore Author
Postby Dave R » Tue Dec 21, 2010 12:13 pm
Nice plugin. It could be very useful. I tried it on a model that someone sent to me the other day. It fixed a few things in one component but still left errors. There were a lot of errors in that component to begin with and it certainly would reduce the time required to manually fix it. Unfortunately the plugin doesn't always seem to recognize that a component is not solid. At least it doesn't recognize that the component in the attached SKP is not solid although you can easily see several problems that keep it from being considered solid.
Global Moderator
Postby GWD » Tue Dec 21, 2010 5:09 pm
Dave R wrote:Nice plugin. It could be very useful. I tried it on a model that someone sent to me the other day. It fixed a few things in one component but still left errors. There were a lot of errors in that component to begin with and it certainly would reduce the time required to manually fix it. Unfortunately the plugin doesn't always seem to recognize that a component is not solid. At least it doesn't recognize that the component in the attached SKP is not solid although you can easily see several problems that keep it from being considered solid.
At this moment fixSolid only work on groups not on components. I'll make it work on components to.
GWD
PluginStore Author
PluginStore Author
Postby Dave R » Tue Dec 21, 2010 5:11 pm
Thank you.
Global Moderator
Postby nektares » Tue Dec 21, 2010 7:39 pm
this might become handy when importing external geometry from other apps, thanks a lot!
nektares
Postby Anssi » Wed Dec 22, 2010 12:32 pm
Guy,
You saved my day today! Thanks a lot!
Anssi
Anssi
Postby zapwizard » Fri Dec 31, 2010 6:08 pm
I haven't downloaded it yet, but I am very interested in using this plug-in to help heal solids for use in BSP based video game making.
zapwizard
Postby mariocha » Wed Jan 05, 2011 1:09 pm
Tried it. V1.5 works pretty well.
This is indeed gone be very, very useful.
Many thanks :D
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby niks » Tue Mar 22, 2011 8:18 am
thank you... very nice plugin :berserk:
niks
Postby rubiks » Thu Sep 01, 2011 9:21 am
:ecstatic: SO HAPPY, SO FRAKIN HAPPY. tried everything to fix <2 days> and i just couldn't do it. I find fixSolid. "right click - FIX - DONE" THANK YOU!!!!!!!!!!!!! :berserk:
rubiks
Postby majid » Thu Sep 01, 2011 3:11 pm
:ecstatic: :thumb: :thumb: :thumb: :thumb: worthy and timesaving, esp for me when impoert/export between wings3d and Sketchup in some cases!!!!
i.e when I was modeling this chair part,... it was a big bother... I must use wings for its sud... and SU for boleans... it was really confusing , to me to model this, and find small gaps and fix them when import/export datas
My V-Ray book for architects: https://goo.gl/cz1oRc
majid
Top SketchUcator
Postby fumaru » Fri Sep 23, 2011 12:13 pm
OMG this is awsome.
Great Plugin thanks man.
Thanks to this, I dont need to rebuild my forms when it is just one small line that cause it to go out of place.
I use this in conjunction with Solid Inspector viewtopic.php?t=30504 , this is a great combo.
fumaru
Next
Return to Plugins
Users browsing this forum: Vuitran92 and 14 guests
