[Plugin] Comp2LayerScene
Postby ktkoh » Fri Sep 14, 2012 11:59 pm
This plugin is ready for public use and is aimed at woodwookers that draw models in sketchup to build in their shop. Select a single component, single parent component or 2 or more components and the program is found on the right click context menuThe program is described below:
# Place the Component on a new layer named from the component
# Layer name includes prefix A##- where ## is 2 digit no (01...99)
# All instances of the component will be placed on the new A##- layer
# A second new Drawing Layer named Z-## will be created.
# A copy of the Board will be added to the Z-## Layer for the Drawing Scene
# If user has MakeOrthoViews.rb installed then ortho views are created
# The drawing Scene will be updated
# Added NC2SCENE to make layer and scene for Nested Component
# Added GP2SCENE to make Sub Assembly scene for 2 or more components
# Added C2SCNE to make scene for Component already placed on its Named Layer
# Added SETPREF to allow user to set Preferences [Plugins/Set Comp2Layer Pref]
I have created a youtube demo at: http://www.youtube.com/watch?v=vshabhT-UEA
Edited 4/21/2014
I have released version 2.0 @ the SketchUcation Plugin Store
The program now makes the orthographic views and thus you no longer need the "Make Ortho Views" plugin
The prefix for the layer name is completely optional.
The drawing views are offset so the main view can be on layer0.
I see that many models are drawn with all components visible on layer0
This makes it easy to use the drawing scenes for a model that was drawn without separating components on individual layers
Added the make a new hidden layer command for the users convenience
Thanks to all the help I received from the Developer's Forum
Keith
ktkoh
PluginStore Author
PluginStore Author
Re: [Plugin] Comp2LayerScene
Postby dlwoodworks » Sun Sep 16, 2012 2:55 am
Keith,
I am not familiar with the .RBZ file. How do I install and use it?
dlwoodworks
Postby Gaieus » Sun Sep 16, 2012 5:11 am
Don, I see you have version 8. This is new in 8. Open your Preferences panel (Window menu) and go to the extensions tab. At the bottom, there is a button "Install extension". A file browser pops up which only accepts RBZ files.
RBZ (short for RuBy Zip) is actually a renamed ZIP archive (you can change the extension to ZIP to see what's in there). The "new", convenient way to install extensions (plugins)
Postby dlwoodworks » Sun Sep 16, 2012 6:19 pm
Thank you very much Gal. :)
dlwoodworks
Postby SUCCESS01 » Mon Nov 26, 2012 7:41 am
:ecstatic: thanks ktkoh !!!
SUCCESS01
Postby bidule » Thu Feb 21, 2013 8:33 pm
Keith,
Thanks for a quite useful plugin. I installed it and purchased the standalone MakeOrthoView plugin from smustard. In that version, the generate_ortho_views function is not called by JF.generate_ortho_views anymore but by JF::MakeOrthoViews.generate_ortho_views. Just a find/replace in your Comp2LayerScene.rb works well.
Cheers,
Phil
bidule
Postby bricofranck59 » Sat Apr 20, 2013 12:24 pm
Hello
I am French, and does not speak English very well. To write to you, I used the translator Googgle.
I downloaded from the site Ruby Library Depot K2WS_tools your plugin.
Thank you for this plugin, but in this one, there are two drop-down menu functions that do not work: "M_T joint" and "Tenon".
Is it possible that you can watch what prevents these features to run.
In advance thank you
PS: As this plugin is apparently no longer visible on this site, I will contact you from this post
bricofranck59
Postby bricofranck59 » Thu Sep 19, 2013 11:09 pm
Hello
I will answer from this post, because the email you gave me does not work, and I can not send PM. This is about the plugin K2WS_tools.
Thank you for your reply. In my turn I meet you later, because as I had no answer, I was not going on the site.
My problem is solved. I struggled to find the solution.
Let me explain:
I wanted to use your plugin with menus and dialogs in French because I confess that at school I did not much like to study languages​​. I regret it now.
I do not know anything about the Ruby script, but I know you could edit transforming the extension "txt".
I fumbled a lot and spent a lot of time but I got there. But there were menus that did not work, and I thought that it came from your program. This is why I wrote to you.
I do not know if you can give me an explanation, but it did not work because the program does not accept focus on "e" at the end of words such as with the French words "square", "end" "degree". I searched a lot to find it. Is this normal?
In any case, your plugin is great and helps me a lot for my hobby is carpentry. Again thank you for it.
Bricofranck59
PS: Why this plugin no longer appears in your library?
and I used the google translator to write you.
bricofranck59
Postby ktkoh » Tue Apr 22, 2014 1:08 pm
Released Version 2.0 To the SketchUcation Store or see original post for new file:
Note: If you are using an older version of SketchUp (7) change the rbz extension to zip to use the file
1. The program now makes the orthographic views and thus you no longer need the "Make Ortho Views" plugin
2. The prefix for the layer name is completely optional.
3. The drawing views are offset so the main view can be on layer0.
4. Added the make a new hidden layer command for the users convenience
Keith
ktkoh
PluginStore Author
PluginStore Author
Postby jimhobza » Sun Dec 14, 2014 1:01 am
Comp2LayerScene: It would be nice if it created all 6 views instead of just 5. I work around it by pre-positioning the component, but it would be easier to delete the not-needed ortho view if all 6 were created.
K2tools: I love the dovetails.
The domino tool has bug(s) that make it not useable.
I have not tried the othere but have heard of similar problems with the motice/tenon so maybe you should check it.
Thank you.
Jim
jimhobza
Postby ktkoh » Tue Dec 16, 2014 12:40 am
I guess I could add the 6th view. I never needed it in any of my models. One way around this problem is to select the preferred view for your main view and delete the rest then use DwgViews from the drop down menu to create the remaining 4 views.
About problems with the K2WS_Tools I have not had any feedback but would be interested in the problems you see in the program. With out a description and or model you leave me in the dark. If any of the tools had problems I would have expected the dovetails. PLEASE reply on the forum or message or by email kbkrueger2@gmail.com I recently had back surgery so I am out of the shop and looking for things to do that require no physical labor.
Keith
ktkoh
PluginStore Author
PluginStore Author
Postby chrisconcise » Sat Aug 22, 2015 5:55 pm
Very nice extension!, we use this a lot now, I would love to speak to you about creating a variation of the extension for a more specific application, not quite too sure how to contact you privately, let me know if you have some time to further discuss your availability, Good job on the extension.
chris.concise@gmail.com if you have time to contact me
chrisconcise
Postby gudio83 » Tue Jan 17, 2017 3:27 am
Dear Keith Krueger,
can you update the plugin for Sketchup 2017.
I've tried on two PCs, Sketchup 2017 x64, Win 10
The only thing that work its dwg views. Comp2Scene and comp2scene\layers creates only assembly scene.
gudio83
Return to Plugins
Users browsing this forum: dezmo, Revoori99 and 7 guests
