[Plugin] Material Renamer
Postby CadFather » Mon Aug 20, 2012 2:47 pm
is there any script that can change the name of all the materials? say into 'mat001', 'mat002' etc..?
EDIT: here it is, courtesy of ThomThom :thumb: (you'll find it under the edit menu)
TT_materials_renamer.rb
CadFather
PluginStore Author
PluginStore Author
Re: material name change?
Postby thomthom » Mon Aug 20, 2012 3:00 pm
Requires at least SU8M1:
Sketchup.active_model.materials.each_with_index { |m,i| m.name = "mat#{'%03d' % i}" }
PluginStore Author
PluginStore Author
Postby CadFather » Mon Aug 20, 2012 3:05 pm
Good Gracious! thanks master thom, i am as grateful as i am shocked! :shock: :)
EDIT: and i caught that! 8-)
CadFather
PluginStore Author
PluginStore Author
Postby thomthom » Mon Aug 20, 2012 3:08 pm
Undo-able in one step:
Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "mat#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
PluginStore Author
PluginStore Author
Re: [Plugin] Material Renamer
Postby greatoe » Sun Aug 26, 2012 1:00 am
Does this plugin work on a Mac?
greatoe
Postby TIG » Sun Aug 26, 2012 9:41 am
It should... try it...
Global Moderator
Postby bagatelo » Wed Aug 29, 2012 12:52 am
thomthom wrote:Undo-able in one step:
This lines works fine in the ruby console. But the plugin script not.
I loved!!!
bagatelo
Postby bagatelo » Mon Oct 01, 2012 1:32 pm
I have a large collection of materials. Many of these are repeated,
and the names are all messed up.
I wish I could organize my these materials, permanently.
It would be possible to create a function that creates a number X of planes or squares,
according to the amount of material in the scene, and apply each material
in each box? Or just put a material in each plan? Create plans
is very simple.
After we can use the plugin "Material consolidator" to eliminate repeated.
bagatelo
Postby thomthom » Mon Oct 01, 2012 1:40 pm
bagatelo wrote:I have a large collection of materials. Many of these are repeated,
is very simple.
CleanUp can merge material with identical properties.
PluginStore Author
PluginStore Author
Postby bagatelo » Mon Oct 01, 2012 1:56 pm
But it works only in applied geometry or can works in the material editor also?
bagatelo
Postby thomthom » Mon Oct 01, 2012 2:08 pm
Materials in the current model.
PluginStore Author
PluginStore Author
Postby bagatelo » Sat Oct 06, 2012 2:19 pm
It would be possible that the name of the material received something from RGB code and the level of opacity?
bagatelo
Postby bagatelo » Fri Oct 12, 2012 1:56 pm
Could you make a window that allowed us to enter the base name and the number of digits materials renamed?
bagatelo
Postby TIG » Fri Oct 12, 2012 2:08 pm
Just edit mat#{'%03d' % i} >>> "mat001" to be say my_mat#{'%06d' % i} >>> "my_mat000001"
Global Moderator
Postby bagatelo » Fri Oct 12, 2012 3:50 pm
I had seen it, just wanted to not have to edit these items. But that's okay.
It would be possible to get the base name for the materials from file skp name automatically?
bagatelo
Postby TIG » Fri Oct 12, 2012 4:09 pm
If you want to rename all of the materials by their RGBA then it's doable, just more awkward in a one-liner...
mo=Sketchup.active_model;mo.start_operation('Rename Materials',true);ms=[];mo.materials.each_with_index{|m,i|n=m.color.red.to_s+'-'+m.color.green.to_s+'-'+m.color.blue.to_s+'-'+m.alpha.to_s;n=n+'#1' if ms.include?(n);(n.next!)while(ms.include?(n));ms<<n;m.name=n;p n};mo.commit_operation
So you'll get "123-45-67-0.8". If two materials share exactly the same RGBA the second material will get a '#1' suffix to keep them uniquely named.
Global Moderator
Postby TIG » Fri Oct 12, 2012 4:12 pm
...it would be possible to get the base name for the materials from file skp name automatically?
Yes, where the earlier code says
change it to read
m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"
Global Moderator
Postby bagatelo » Fri Oct 12, 2012 4:33 pm
change it to read
GREAT!!! Thanks...
Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
bagatelo
Postby shannakae » Tue Feb 26, 2013 12:58 am
Not sure this has been brought up in this thread or in another, but I am looking for a way to organize my materials within each project. It would be so great to be able to organize them into folders or some sort of system that lets me group items together... I have a ton of materials in the project i am currently working on and have been trying to keep track of them by renaming them etc... but it becomes very daunting to look through them all. For example I downloaded a sketchup 3d file of books for my bookshelves in a family room I am designing... obviously I don't want to re paint all the books with colors in my model... and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library. It would be so great to create a folder or file system to group all the colors that are in the books together so that I don't get them mixed up with my other materials... needless to say it is a hot mess in my materials library. Please tell me someone has created a cool plugin for this or has a solution for me : ) Or am I missing something very obvious???
shannakae
Premium Member
Premium Member
Postby jolran » Tue Feb 26, 2013 1:55 am
and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library..
I hate to ask. You do do know you can purge unused materials ?
In case not. In the Materialpalette, click the house to get to modelmaterials.
The icons furthest to the right(blueish) click and choose purge unused.
Otherwise there is maybe this:
viewtopic.php?t=17587
or this ?
viewtopic.php?t=48933
Take care.
jolran
PluginStore Author
PluginStore Author
Postby shannakae » Tue Feb 26, 2013 2:17 am
or this ?
Take care.
Thanks, i will look those up. I do know about purge un-used (but I did just learn about it the other day so you are not so far off ;) )Thanks! I will look up the two topics and see if there is something there that works for me... I was looking at the open or create a collection section... and was going to explore how that might work for what I am trying to do...
shannakae
Premium Member
Premium Member
Postby bagatelo » Thu Jun 27, 2013 5:07 pm
change it to read
GREAT!!! Thanks...
I want to add a shurtcut for this function. Can you make a plugin for me, please? :oops:
bagatelo
Postby CadFather » Fri Jun 28, 2013 12:33 am
Code: Select all
def matrename
Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "- #{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
if( not file_loaded? "TT_materials_renamer.rb" )
UI.menu("View").add_item("Materials Rename") { matrename.new }
file_loaded("TT_materials_renamer.rb")
CadFather
PluginStore Author
PluginStore Author
Postby bagatelo » Thu Jul 11, 2013 6:29 pm
CadFather wrote:
Code: Select all
def matrename
Great! Thanks!
One thing that would be really interesting would be that this script index materials application in areas with higher per square meter first. Thus, a material that was on all the walls would be in first place. A material that was in small areas (a decorative object for example) would be the end of the numbering.
bagatelo
Postby harvey1 » Fri Jul 12, 2013 1:52 am
Is it possible for this plugin to allow one to rename individual materials. For example, let's say my model is imported into SU as Material 1, and I'd like to rename it Window, and Material 2 to be renamed Door, etc.
harvey1
Postby Pherim » Thu Nov 07, 2013 4:53 pm
This plugin appears to be buggy for me... it seems to be applied as soon as Sketchup has started, so when I open a file by double-clicking it in explorer, the materials get renamed immediately. The same happens when I activate the plugin via the Sketchucation Plugin Store. Will leave it deactivated until the cause is found...
Pherim
Postby JBJDesigns » Sun Feb 16, 2014 4:49 pm
Currently, I have this plug-in disabled (i.e., "tt_materials_renamer.rb" to "tt.materials.renamer.rbDISABLE"). Is there a way to turn this option on or off as needed. Many of my projects are uploaded into Vue 10 Esprit for rendering. I've been "building" a database of materials from SU. When the files are automatically renamed to "mat00", "mat01", etc., it's near impossible to determine whether the material has been saved to it's converted ".mat" format. Your help is appreciated. Jo Ann :D
...you send them to school, you give them books, and they eat the pages...
JBJDesigns
Premium Member
Premium Member
Postby rv1974 » Wed May 07, 2014 12:52 pm
Beware: It runs silently in background on the file opening! I managed to spoil a couple of files with this one :oops:
It should be written on the top.
rv1974
Return to Plugins
Users browsing this forum: metallicatz16 and 8 guests
