[Plugin] Divide Angle v1.0.1 20130621
Postby TIG » Fri Aug 03, 2012 10:42 am
(c) Copyright TIG 2012-2013
You may not use, copy, modify, or distribute this software for
any purpose, without the express prior agreement of the copyright holder:
this full copyright notice must appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
#TIG-divide_angle.rb [manual-install put into the Plugins folder and restart Sketchup]***
Usage:
Select two edges that are not parallel and that could intersect if they don't
already share a vertex.
Right-click to get the context-menu 'Divide Angle...'
Note how this context-menu item is only available if the selection is appropriate.
In the dialog enter the number of divisions + OK [default is '2'].
It must be a positive integer [2 NOT 2.0]; otherwise you are prompted to retry.
Also it must be 2 or more; otherwise there's an error message and it exits.
Guide-lines are now drawn through the two selected edges and the division[s] as
you have specified.
The angle between the edges that is less than 180 degrees is always divided.
Donations:
by PayPal.com to info @ revitrev.org
Version:
1.0 20120803 First release.
1.0.1 20130621 Added to Plugin Store.
***Now available from the PluginStore http://sketchucation.com/resources/plug ... vide_angle
or AutoInstall and manage it using the Plugin Store toolset. http://sketchucation.com/resources/plug ... e-download
Global Moderator
Re: [Plugin] Divide Angle v1.0 20120803
Postby rv1974 » Fri Aug 03, 2012 11:10 am
Outstanding!!!
rv1974
Postby cotty » Fri Aug 03, 2012 11:50 am
Thank you, nice little helper.
And a little visual example:
cotty
Top SketchUcator
Postby Ben Ritter » Fri Aug 03, 2012 5:23 pm
Thank you. You are kind, and generous.
Ben Ritter
Postby Krisidious » Fri Aug 03, 2012 5:30 pm
You Sir are a Rock Star...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby alexschreyer » Fri Aug 03, 2012 8:36 pm
That's a neat helper functionality. I also like the idea of having something like that in the next release as a preference setting.
Cheers,
Alex
Author of "Architectural Design with SketchUp":
http://sketchupfordesign.com/
alexschreyer
PluginStore Author
PluginStore Author
Postby massimo » Fri Aug 03, 2012 8:58 pm
Thanks TIG. :thumb:
massimo
Postby pbacot » Fri Aug 03, 2012 11:16 pm
Wonderful!
Top SketchUcator
Postby utiler » Mon Aug 06, 2012 1:49 am
That's cool, TIG! Til now I have drawn a cline, copy/rotated it and divided by how ever many divisions I needed.... :thumb:
utiler
Top SketchUcator
Postby Elibjr » Fri Aug 10, 2012 8:27 am
Sir, you are a mastermind that makes masterpieces. Thank you! :sketchstatic:
Elibjr
Premium Member
Premium Member
Postby simon le bon » Fri Aug 10, 2012 9:03 pm
added to basic tools.
Thank you Dear Tig++
simon
simon le bon
Postby Dave R » Fri Aug 10, 2012 9:18 pm
Thank you, sir.
Is there a metric version? :lol: Gets hat, coat....
Global Moderator
Postby TIG » Fri Aug 10, 2012 10:39 pm
It's based on a sort of sexagesimal - base 60 - version.
6*60 = 360 degrees in a circle NOT 100...
Then it's all calculated in bloody Radians - 2*PI in a circle...
BUT you enter a ratio anyway :? :? :?
2 or 3 or 4 etc...
:geek:
Global Moderator
Postby Lobster » Thu Nov 15, 2012 9:42 pm
Thanks,
Most useful
Lobster
Postby smicha » Fri Jun 21, 2013 11:36 am
TIG,
This plugin is great but not listed in the plugin store :)
smicha
Postby TIG » Fri Jun 21, 2013 4:55 pm
It will be... :D
Global Moderator
Postby pilou » Fri Jun 21, 2013 5:04 pm
I have missed this one! :shock:
Speedy Galerie
Top SketchUcator
Re: [Plugin] Divide Angle v1.0.1 20130621
Postby TIG » Fri Jun 21, 2013 5:20 pm
Now added to the PluginStore list...
Global Moderator
Postby tabulador » Fri Jul 26, 2013 8:51 pm
Muchas gracias, amigo
tabulador
Postby mirshahi » Sun Aug 18, 2013 10:19 pm
I installed the RBZ file in SU Pro 8 and it does not load. I check the extensions, manually downloaded the extension, still does not show in the Ext. list and, of course, it does not load.
What is the problem???
mirshahi
Postby Dave R » Mon Aug 19, 2013 10:45 am
What do you mean by "install"? Did you just move the rbz file to the Plugins folder? What operating system?
Global Moderator
Postby TIG » Mon Aug 19, 2013 10:56 am
Assuming you have installed the .rb into your Plugins folder [somehow] and restarted SketchUp...
Then please reread the tools instruction son the first post in this thread...
It is NOT an Extension, just a simple tool.
IT only works from the context-menu, and only appears if you have selected two lines that are suitable...
I have reprinted the key paragraph below:
Usage:
you have specified.
Global Moderator
Return to Plugins
Users browsing this forum: 145thanhtrung, ercplrgdo, gwynbleids and 16 guests
