[Plugin] Curvizard - v2.4a - 24 Feb 19
Postby fredo6 » Wed Jul 11, 2012 10:34 pm
From now on, the information on JointPushPull is maintained on the Plugin Home Page of Curvizard. This is also where you can download the RBZ file.
Requirement: LibFredo6 v8.8a or above
If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
Curvizard is a suite of interactive tools operating on sequences of edges (Contours) and Sketchup curves. The common characteristics of Curvizard tools are:
  • Support Pre-selection mode, with launch from toolbar, main menu, and contextual menu. Option for Auto-exit when launched from contextual menu or pre-selection.
  • Interactive selection mode, where edges can be selected across the boundaries of components and groups (edge picking method is similar to Curviloft’s)
  • Non-destructive approach for most tools. When edges are connected to faces, Curvizard tools try to preserve the faces and their texturing.
  • Most operations can apply to several curves or sequences of edges in one shot
  • Full support of Undo / Redo, via Ctrl-Z
  • Functional enhancements for some tools versus existing scripts (details sections below)
  • Quick Launcher
In the current version, Curvizard supports the following functions:
  • Make Curve (i.e. weld), with option for auto-extension
  • Explode Curves (multiple edges)
  • Cleanup Contour (collinear, small spikes)
  • Simplify Contour (by angle)
  • Smooth Contour (by splines with average angle)
  • Modify Edge Properties (soft, smooth, hidden, cast shadows)
  • Convert to Guides: convert a sequence of edges to a sequence of construction lines
  • Reconstruct Arc or Circle: convert a sequence of edges to a true Sketchup Arc or Circle when this is possible (so you can then change the number of segments)
  • Reconstruct Polygon: convert a sequence of edges to a true Sketchup Polygon when this is possible (so you can then change the number of segments)
There is a Quick Launcher: This is a small floating window which displays all Curvizard tools in a list. It can be invoked from the menu or the toolbar icon. Optionally you can pin the Quick Launcher window on your viewport for subsequent use. By default the window closes when you launch a command.
Curvizard - User Manual - English - v1.4 - 15 Sep 13.pdf
Just drop the attached PDF file into the SU Plugins directory to have it accessible from within Sketchup.
Quick Make Curve on pre-selection of edges
11
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] Curvizard 1.0c - 11 Jul 12
Postby Rich O Brien » Wed Jul 11, 2012 10:37 pm
Looks cool..... :fro:
Rich O Brien
Administrator
Postby Rich O Brien » Wed Jul 11, 2012 10:41 pm
That Simplify tool is stunning :thumb:
Rich O Brien
Administrator
Postby pilou » Wed Jul 11, 2012 10:46 pm
The French curves' doctor! :enlight:
Speedy Galerie
Top SketchUcator
Postby brookefox » Thu Jul 12, 2012 5:39 am
I'm just going to jump right in and say thanks again for epitomizing the way to share a most potent, stealthy tool set, gloved with generous explicating tutorial and annotated pics. You try to make it easier to get with the power of Fredo .
(We can, as a rule, be slow, lazy, impatient... I should know. Sometimes these things need to be said.)
~ Brooke
brookefox
Postby guanjin » Thu Jul 12, 2012 7:19 am
Fredo Hello
Part of the language translation, there is no change
guanjin
I come from China, is to learn
guanjin
Postby small08 » Thu Jul 12, 2012 8:19 am
And the beat goes on,you are something!Some of the best developed suites in SketchUPs toolbox. Not to mention the other gurus. Thank-you...
small08
Postby erikB » Thu Jul 12, 2012 8:49 am
ones again, many thanks for this very useful tool. :thumb:
erikB
erikB
Postby wolfy » Thu Jul 12, 2012 3:01 pm
Great tool! Just what I needed :berserk:
Thanks again Fredo for your dedication and generosity.
wolfy
Postby Daniel S » Thu Jul 12, 2012 3:06 pm
:sketchstatic: :sketchstatic: :sketchstatic:
This plugin could have saved me a lot of time 2 days ago but I´m sure that will save me lot of time and effort in the future.
Thank you!!!
Daniel S
PS: It´s possible to make contours more complex? something like the opposite of simplify contour
Daniel S
Postby Ben Ritter » Thu Jul 12, 2012 4:01 pm
Fredo, thank you again.
Ben Ritter
Postby jeff hammond » Thu Jul 12, 2012 5:53 pm
Daniel S wrote:PS: It´s possible to make contours more complex? something like the opposite of simplify contour
you can do things like that with fredo's BezierSpline
select the lines then right click -> BZ convert to…
and pick one of the different splines depending on desired curve (catmull, Bspline, Fspline, etc)
dotdotdot
jeff hammond
Global Moderator
Postby notareal » Thu Jul 12, 2012 6:41 pm
Looking great!
notareal
Thea Render Support
Thea Render Support
Postby Daniel S » Thu Jul 12, 2012 8:09 pm
Yesss!! :berserk: :berserk: :berserk: I didn´t remember that option :oops:
Thank you!!!,
Daniel S
Daniel S
Postby cotty » Thu Jul 12, 2012 9:40 pm
Thank you very much for another wonderful plugin.
(a donation is on the way "as a sign of reward and recognition")
cotty
Top SketchUcator
Postby fredo6 » Thu Jul 12, 2012 9:47 pm
This is planned, as Smooth Contour.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby EarthMover » Thu Jul 12, 2012 9:57 pm
This is great. Thanks Fredo! :thumb: Would also like to see a divide (length & increment) curve, comparable to the one in BZ Convert, except that respects angles in the manner of your simplify tool. Simply put, a polyline divider that respects corners over a certain degree.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby JClements » Fri Jul 13, 2012 12:42 am
A very BIG THANK YOU.
Of course another request :)
What if a selection consists of segments, who by definition (equal length, connected segments with equal angles at their vertices), define a native SU arc or circle. Could they be converted into SU arcs or circles?
This could be very useful when editing imported DXF files.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
Postby cuttingedge » Fri Jul 13, 2012 5:36 am
Fredo, We applaud your passion in perfecting tools to keep Sketchup afloat in the competition of 3d modelling softwares. Such a wonderful plugin indeed.
cuttingedge
Postby ken » Fri Jul 13, 2012 1:29 pm
Fredo
I have your new plugin and it shows that it needs to be updated, screen shot illustration below, however, I believe I have all the required files. Note, I renamed the folders with a leading "1" so they would be grouped at the top of the list so I could show all directories in the illustration, I remove the "1" when using Sketchup. I have one folder, curviloft_dir_12Ken, which I have renamed,as it appears not to be needed for curvilof and adding "ken" to the end of the folder name is my way of trying to determine if the folder is required.
Could you please look at my directory and try to help me to find out what is going on with the updated plugin.
Thanks you in advance
Ken
ken
Premium Member
Premium Member
Postby Edson » Fri Jul 13, 2012 1:33 pm
this is fantastic! one more great plugin from one of the greats! :bounce: :thumb: :ecstatic:
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby ZFRPS » Sat Jul 14, 2012 1:45 am
This plugin very useful !
but...
When I was in the test of time, some is not stable, very bad,Don't know why!
sketchup is bim
ZFRPS
Postby ZFRPS » Sat Jul 14, 2012 1:47 am
sketchup is bim
ZFRPS
Postby fredo6 » Sat Jul 14, 2012 8:23 am
@zfrps
The Simplify tool does not analyze the cylinder. It just simplifies each circle independently. Then it eliminates edges which have their two bordering faces coplanar. So, sometimes the simplified contours matches, sometimes not.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Sun Jul 15, 2012 9:44 am
Ken wrote:I have your new plugin and it shows that it needs to be updated, screen shot illustration below,
That does not say Curvizard needs to be updates - the blue means no update information is availibile. If there is an update for a plugin it's highlighted red and the status will say "Update availible" (or similar) Note that in your screenshot it says nothing. No update is availibile.
PluginStore Author
PluginStore Author
Postby ZFRPS » Sun Jul 15, 2012 9:59 am
Thanks Fredo !
sketchup is bim
ZFRPS
Postby mitcorb » Sun Jul 15, 2012 7:17 pm
Thank you once again.
mitcorb
Top SketchUcator
Postby Oxer » Thu Jul 19, 2012 12:46 pm
Thanks Fredo for this new plugin!! :thumb:
I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
Curvizard_SP.lang
http://www.oxervision.blogspot.com/
Oxer
Postby ideas_arte » Fri Jul 20, 2012 4:09 pm
@Fredo, Thanks for the useful plugin
@Oxer, gracias por la traducción, Saludos!
ideas_arte
Postby fredo6 » Fri Jul 20, 2012 11:23 pm
Oxer wrote:Thanks Fredo for this new plugin!! :thumb:
This is a bug (not just for Spanish). Thanks for signaling.
I fixed it and your translation will appear at next release.
Fred
fredo6
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: gabgigliotti, mpaplow, pius222 and 251 guests
