[Plugin] Components to Grid
Postby CadFather » Sat Jun 16, 2012 2:33 pm
This is a plugin by TIG to align all model components to a grid. The menu has a choice of 7 different spacings.
you'll find it in the 'Tools' menu
components_grid.rb
CadFather
PluginStore Author
PluginStore Author
Re: Exporting Components
Postby Dave R » Sat Jun 16, 2012 3:13 pm
Just save the In Model component library as a local collection in its own folder. Now you have all the components as individual files in a folder on your hard drive. Copy it to whatever other disk you want. No plugin needed.
Global Moderator
Postby CadFather » Sat Jun 16, 2012 3:18 pm
..of course! :oops: :P ..thanks Dave - that's brilliant, and it brings me back to the early days when that was exactly how we did things... :thumb:
CadFather
PluginStore Author
PluginStore Author
Postby Dave R » Sat Jun 16, 2012 3:22 pm
:thumb: :lol:
Global Moderator
Postby TIG » Sat Jun 16, 2012 3:25 pm
There is a built-in way BUT if you want it coded then use an iteration of
https://developers.google.com/sketchup/ ... on#save_as
This one-liner, copy/pasted into the Ruby Console + <enter> will export all definitions in the model into the model's folder - named after the definition+.skp
Code: Select all
m=Sketchup.active_model;p=File.dirname(m.path).tr("\\","/");puts"\n\nExporting Components to\n\n"+p+"\n\n";ds=m.definitions;ns=[];ds.to_a.find_all{|d|next if d.group?||d.image?;ns<<d.name};ns.sort.each{|n|puts s=n+".skp";ds[n].save_as(File.join(p,s))};puts"\nDone."
If you want groups or images exported adjust the 'trap' next if...
Global Moderator
Postby CadFather » Sat Jun 16, 2012 3:36 pm
TIG, you do it on purpose! :lol:
CadFather
PluginStore Author
PluginStore Author
Postby CadFather » Sat Jun 16, 2012 4:16 pm
while i'm at it i might ask another question (for which there surely there isn't an old easy answer..)
any way to distribute ALL the components present in the component browser 'in model' - to an imaginary grid in model space?
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Sat Jun 16, 2012 5:16 pm
I already recently did something like this in another thread, where the OP wanted to import SKPs and then show the components laid out.
What you could do with a model's components in code is to iterate the list of definition names 'ns' [as all set/got in my earlier example] and then place an instance of each on a special layer [it makes later deletions easier], thus:
Code: Select all
m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[];ds.to_a.find_all{|d|next if d.group?||d.image?;ns<<d.name};ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom::Point3d.new(0,0,0);x=1.m;y=1.m;r=(Math.sqrt(ns.length)+0.5).to_i;c=0; ns.length.times{|i|puts ns[i]; tr=Geom::Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l;c+=1;if c>=r;p.x=0;p.y+=y;c=0;else;p.x+=x;end};puts"\nDone.";m.commit_operation
The x/y set for a 1m 'square' grid starting from [0,0,0] - with any odd ones on the final row - so adjust this as desired; these new instances are put onto a layer name 'ALL!'; this one-liner is one-step undoable...
Global Moderator
Postby CadFather » Sat Jun 16, 2012 5:51 pm
wow...thank you TIG - just tried it and it's fab! :D :thumb:
tried to make it into a command but no success and yet i'm sure i wrapped it up properly (just in case others find it useful)
compogrid.rb
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Sat Jun 16, 2012 11:07 pm
You miss called the module/method... try it this way
Code: Select all
require 'sketchup.rb'
module CADfather
  unless file_loaded?(File.basename(__FILE__))
    UI.menu('Tools').add_item('Components to Grid'){self.compogrid()}
  file_loaded(File.basename(__FILE__))
  def self.compogrid()
    m=Sketchup.active_model;m.start_operation("ALL!");ds=m.definitions;ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?;ns<<d.name};ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom::Point3d.new(0,0,0);x=2.m;y=2.m;r=(Math.sqrt(ns.length)+0.5).to_i;c=0; ns.length.times{|i|puts ns[i]; tr=Geom::Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l;c+=1;if c>=r;p.x=0;p.y+=y;c=0;else;p.x+=x;end};puts"\nDone.";m.commit_operation
  end #def
end #module
... OR something similar ... ;)
EDIT: typo fixed !
Global Moderator
Postby CadFather » Sun Jun 17, 2012 10:51 am
thanks TIG - works great.
i think there's a small typo here:
should read ds
what's interesting is how fast it is even with lots of components :thumb: :thumb:
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Sun Jun 17, 2012 12:13 pm
You are right - I have now changed the original to 'ds'...
Global Moderator
Re: [Plugin] Exporting Components
Postby CadFather » Sat Jun 23, 2012 10:30 am
Hi TIG - is it possible to have all the components placed along the red axis? i tried modifying the script but i always get the components on top of each other.. :roll:
CadFather
PluginStore Author
PluginStore Author
Postby TIG » Sat Jun 23, 2012 10:41 am
This [simpler] version spaces the component-instances 2m apart along the red/x axis [no stacking into a 'square']
Code: Select all
module CADfather
        m=Sketchup.active_model;m.start_operation("ALL!"); ds=m.definitions; ns=[]; ds.to_a.find_all{|d|next if d.group?||d.image?; ns<<d.name}; ns.sort!; l=m.layers.add("ALL!");puts"\nLaying out ALL Components...\n\n"; es=m.active_entities; p=Geom::Point3d.new(0,0,0); x=2.m; ns.length.times{|i|puts ns[i]; tr=Geom::Transformation.new(p); n=es.add_instance(ds[ns[i]],tr);n.layer=l; p.x+=x};puts"\nDone.";m.commit_operation
      end #def
end #module
If the Ruby Console is open it reports what it's doing...
Change the x=2.m for a different spacing in red/x if desired...
Global Moderator
Re: [Plugin] Components to Grid
Postby CadFather » Sat Jun 23, 2012 11:12 am
Thanks TIG - much appreciated - i'll try integrating it into the grid plugin.. :thumb: :)
CadFather
PluginStore Author
PluginStore Author
Postby gullfo » Sat Jun 23, 2012 4:47 pm
TIG script examples - an interesting side effect - if you have a component made of other components it pulls it apart and distributes them... in this example i have a DC component of an acoustic window which has frames and seals as sub-components. in a way, this could be handy for creating a "how to assemble" guide because it pulls it apart in order of nesting...
otoh this may not be a desired effect for the script in the end...
gullfo
Postby TIG » Sat Jun 23, 2012 9:01 pm
The OP asked for all components to be displayed on a grid.
The code is very adaptable.
It ignores Groups and Images although it could as easily display those as well, or instead.
This version displays just components that have instances that are either in the model's entities or inside a non-component-entities context [i.e. inside a group that is not itself inside a component definition]
Code: Select all
    module CADfather
            UI.menu('Tools').add_item('Components to Grid'){self.compogrid_used()}
          def self.compogrid_used()
            ds=m.definitions
            ns=[]
            def self.recurse_parent(c)
              begin
                return c.parent
              rescue
                return nil
              next unless d.instances[0]
              next if d.group?
              next if d.image?
              skip=true
              d.instances.each{|i|
                if i.parent==m
                  skip=false
                  break
                elsif i.parent.group?
                  i.parent.instances.each{|g|
                    c=g
                    while c
                      c=self.recurse_parent(c)
                      if m==c
                        skip=false
                        c=nil
                        break
              next if skip
              ns<<d.name
            ns.sort!;
            x=2.m
            ns.length.times{|i|
              puts ns[i]
              n.layer=l
              p.x+=x}
            puts"\nDone."
            m.commit_operation
          end #def
    end #module
Global Moderator
Postby Amazing Artist » Tue Jul 02, 2013 10:42 pm
TIG Thanks
That's my story, and I'm sticking to it!
Amazing Artist
Postby pilou » Wed Jul 08, 2020 12:14 am
For SU 2017 Make
Incompatible with LightUP! :o
Curiously icons of LightUp apear!
And LightUp Disconnected
don't take a selection but all components on the scene! :o
Here must be display only "XTE" Selected : that is not the case! ;)
All is recalled! (even the top view text who is not visible at the Plugin call! )
Speedy Galerie
Top SketchUcator
Postby juju » Thu Jul 09, 2020 12:29 pm
pilou wrote:For SU 2017 Make
Pilou, are you OK? I don't see what this has to do with the thread above? Perhaps start your own thread or look for the thread this is supposed to be in?
juju
Premium Member
Premium Member
Postby pilou » Thu Jul 09, 2020 1:50 pm
It's not the thread about Plugin "Components to Grid"?
What better place to report that it is not compatible (for me in any case) with Light UP ?
And it has curious behavior with the selection Components ? (for me in any case)
Out of that i just reinstall SketchUp and must verify if above is always true!
It will be my first Plugin to reload from a little thousand! :)
Speedy Galerie
Top SketchUcator
Postby pilou » Thu Jul 09, 2020 2:23 pm
Alas not better ! :cry:
My SketchUp is absolutly new! Only "Component on Grid" installed! :ugeek:
So no conflict possible! (like Light Up above) ;)
If i add new volumes : the same! that is making snowball ! All is redrawn! :o
Speedy Galerie
Top SketchUcator
Return to Plugins
Users browsing this forum: milenoliegsalz and 11 guests
