[Plugin] Script selects the line or face.(UPDATED 15/02/16)
Postby sahi » Fri Jun 15, 2012 5:52 am
The script selects the line or face.
The first icon >> click on it - and only the lines stand out >> again click on it >> disables script
The second icon >> click on it - and distinguished only by persons >> again click on it deactivates the script >>
5
sahi
PluginStore Author
PluginStore Author
Re: [Plugin] The script selects the line or face.
Postby Rich O Brien » Wed Dec 12, 2012 5:53 pm
I added a tutorial to this plugin as I think it is an essential tool in SketchUp. :thumb:
Rich O Brien
Administrator
Postby dtrarch » Wed Dec 12, 2012 11:21 pm
Sahi
Just a killer app and thank you very much :sketchstatic:
dtr
dtrarch
Premium Member
Premium Member
Postby mitcorb » Thu Dec 13, 2012 3:56 am
Great concept. Congratulations, sahi. And thank you, Rich, for that video.
Now, a real trick would be to select only vertices. :mrgreen:
mitcorb
Top SketchUcator
Postby Edson » Thu Dec 13, 2012 8:50 pm
sahi,
great plugin! I suggest you change the title of this topic to reflect the exact name of your plugin. otherwise people will have a hard time find it, as was my case. something like [Plugin] selection_edge would work nicely. by the same token, why does the name of the plugin reflect what it does? selection_edge does not tell one that it also select faces.
best regards.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby mitcorb » Fri Dec 14, 2012 12:43 am
How about Plugin: Select/Isolate Edge or Face.
How about Plugin: Discrete Selection Edge or Face.
Either one is all yours-- or none of the above.
-1
mitcorb
Top SketchUcator
Postby sahi » Sat Dec 15, 2012 11:00 pm
Rich O Brien wrote:I added a tutorial to this plugin as I think it is an essential tool in SketchUp. :thumb:
Hi!
Thanks Rich O Brien
PS:I do not speak English so it's hard to explain all the functions of the plug
sahi
PluginStore Author
PluginStore Author
Postby irwanwr » Sun Jan 27, 2013 8:59 pm
[Edited]
Got it. Can see the difference between this plugin with TT Selection Toys.
Thank you Sahi, for this one, Axes Comp and Krug. I think this should be one of my "must have" plugin :)
irwanwr
Postby cityblueskyz » Thu Apr 25, 2013 3:16 am
Thank you very much for sharing
It really is a very convenient plug-in :thumb:
cityblueskyz
Postby pilou » Thu Apr 25, 2013 7:49 am
This sort of selection don't yet existing in another plugins ? ( Selection Toys etc...)
Speedy Galerie
Top SketchUcator
Postby snakeysnape » Fri Mar 07, 2014 8:52 pm
Hi All,
I wonder if anybody else is experiencing it, but this plug-in don't work for me when I use it with SU 2014. Previously in SU8 with select face toggled on even if I triple click a model only face would be selected as expected but for SU2014 edges are included in the selection.
I hope this gets resolved, as its been a real helpful plugin for me.
snakeysnape
Postby sdmitch » Sun Mar 09, 2014 5:39 pm
I have experienced the same results. Works perfectly in SU8 but fails in SU2014 with no errors reported in the Ruby Console.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby cotty » Sun Mar 09, 2014 6:36 pm
snakeysnape wrote:I hope this gets resolved, as its been a real helpful plugin for me.
Until then, you can use Thomthoms selections toys as an alternative for this task.
cotty
Top SketchUcator
Postby sdmitch » Sun Mar 09, 2014 6:51 pm
The code
Code: Select all
edges=sel.grep(Sketchup::Edge); sel.clear; sel.add edges
works in SU2014 but causes a stack error that crashes SU8.
sdmitch
PluginStore Author
PluginStore Author
Postby driven » Sun Mar 09, 2014 8:45 pm
sdmitch wrote:The code...
on mac both
Code: Select all
sel=Sketchup.active_model.selection
edges=sel.grep(Sketchup::Edge).to_a; sel.clear; sel.add edges
Code: Select all
work in v8 and v2014
driven
PluginStore Author
PluginStore Author
Postby sdmitch » Sun Mar 09, 2014 9:08 pm
Apparently my v8 is different because it still crashes with that addition.
sdmitch
PluginStore Author
PluginStore Author
Postby driven » Sun Mar 09, 2014 9:12 pm
my test file had less than 2000 edges so is it a limit?
john
driven
PluginStore Author
PluginStore Author
Postby sdmitch » Mon Mar 10, 2014 1:00 am
No I was using a small sample consisting of 3 or 4 faces.
I did find a solution that works in both SU8 and SU2014 and that was to remove the observer before processing the selection and add it back after while using the selection processing code previously posted.
Code: Select all
   def onSelectionBulkChange(selection)
      Sketchup.active_model.selection.remove_observer self
      get_selection_edge(selection) if(@select_edge)
      # get_selection_edge_smooth(selection) if(@edge_smooth)
      get_selection_face(selection) if(@select_face)
      Sketchup.active_model.selection.add_observer self
sdmitch
PluginStore Author
PluginStore Author
Postby snakeysnape » Mon Mar 10, 2014 10:33 am
Hi Sdmitch,
Sorry but can you post the fixed plugin in here? I am confused as to where to put the selection code.
thanks
snakeysnape
Postby sdmitch » Mon Mar 10, 2014 3:03 pm
snakeysnape wrote:Hi Sdmitch,
thanks
With apologies to Sahi.
sdmitch
PluginStore Author
PluginStore Author
Postby snakeysnape » Wed Mar 12, 2014 6:31 am
Thanks sdmitch,
Thanks also to Sahi hope you don't feel bad we've 'hijacked' your plugin.
snakeysnape
Postby Pu » Wed Jul 09, 2014 10:06 pm
not work. (sketchup 2014)
-1
Pu
Postby ClausGS » Tue Dec 23, 2014 6:24 am
selection_edge.zip
Hi Sahi
Have used this plugin for a long time, but now it do not work in SU 2015 ?
Can you fix that?
Thanks for your great support...
Claus
ClausGS
ClausGS
Postby driven » Tue Dec 23, 2014 2:11 pm
@Claus,
if you open the file in notepad++ and find and replace...
if you have the original version
Code: Select all
 sel.each
to
Code: Select all
 sel.to_a.each
or if you have sdmitch [faster] version
Code: Select all
sel.grep
to
Code: Select all
sel.to_a.grep
this works in v2015 for me...
john
driven
PluginStore Author
PluginStore Author
Postby HirokaMatsuiko2015 » Sun Jan 11, 2015 1:30 pm
thank you for this tool im using it right now
if its possible to request
add shortcut keys with toggling selection tool
right now when paradigm or changing between tools i need to hit ( Face Select > Spacebar ) or ( Edge Select > Spacebar )
i think its more convenient in one keys
like for example if hit X key it will also toggle the selection keys
similar to other 3D software
HirokaMatsuiko2015
Re: [Plugin] The script selects the line or face.(UPDATED)
Postby sahi » Sun Feb 14, 2016 11:35 pm
Updated the plug-in in the first message
sahi
PluginStore Author
PluginStore Author
Return to Plugins
Users browsing this forum: delfostrit, Google Bot, Jacob1999, kvanckocer and 8 guests
